Washer pump
Ever have one of those moments when you wake up in the middle of night, sit straight up, and realize you've solved a problem that's been stymieing you? I had that last night, but I don't know if I'm right yet. I even emailed myself so I wouldn't forget.
Anyhow, as I near completion of my complete reassembly I've discovered my washer pump doesn't work. I siphoned water right up to it so it doesn't have to work to prime itself, but no luck. I'm wondering now if the washer nozzles got plugged with media when I had them in the vibratory tumbler. That's my hope and my "big idea". Easy enough to check. Before I do, though, a question: I can -hear- the pump operating. It does it's little thing. I've heard that if the 'cam' isn't aligned with the motor the pump won't work, but would I still hear it? That's the question - I'm trying to rule out the pump cam as an issue based on the fact that I can hear something going on in there... I really don't want to replace it. I have AC so it's a nightmare of packaging with the crazy air tubes, vents, radio, speaker, washer pump, instruments and everything packed in right there.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#2 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: Washer pump
Sounds to me like you may need that little 9.00 washer pump gasket repair kit that is easy to install with the radio out of the truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: Washer pump
Can you get to it with the radio out on an AC truck? That particular AC hose you don't want to remove as it runs all the way to the driver's side vent.
![]() Join Date: Jan 2001
Re: Washer pump
Unless you're trying to keep your truck bone-stock, one of the cheapest and most effective upgrades is an S-10 washer bottle with the integral pump. They work great and have a lot more pressure than the original pumps in our trucks. You can wire them into the original switch, too.
#5 | |
Re: Washer pump
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
#6 | |
Re: Washer pump
Great idea. Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
Re: Washer pump
I've been intrigued by the S-10 part but do want to keep as close to 100% stock appearing as possible. Not that I've not made any concessions, but the windshield washer pump isn't like 3-point belts or disc brakes where I have a safety incentive (outside muddy roads, I guess).
Could it all be stuffed into a 1960s washer bottle and wired discretely, or would they be far too different in size, etc?
![]() Join Date: Mar 2012
Re: Washer pump
i just hooked up the universal pump from NAPA works great it is the size of a D Battery and cost around 25 bucks, toggle switch under the dash , a lot easier than trying to mess with the factory one
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Re: Washer pump
I do not know but its right there with the radio removed in a non A/C truck.
#10 | |
Re: Washer pump
![]() Join Date: Dec 2011
Re: Washer pump
I know you have some history with anti freeze bottles, you didn't use the windshield washer fluid jug in a pinch..didja? Just kidding.
