07-15-2014, 04:16 PM | #1 |
Should I replace this or heat it and straighten? (Trailing arm bracket)
After picking my frame up from the sand blaster, I noticed this bracket bent (see pic). I suspect his forklift hit it. So my question-- Should I heat it and straighten it or cut the rivets off of both of them and use bolts to bolt both of them back on to have them matching? If so, what size bolt do you think will hold up in this spot??
07-15-2014, 04:27 PM | #2 |
Re: Should I replace this or heat it and straighten? (Trailing arm bracket)
Heat and bend not a critical bracket , save your money and continue on . just make sure it's close and your panhard bar will do the rest !
07-15-2014, 05:23 PM | #3 |
I would try a BIG crescent wrench first with out heat and see how it goes
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
07-15-2014, 05:24 PM | #4 |
OK. I have a parts truck that I can go rob one off of so it would just be a couple hours of labor to break down the suspension on parts truck.
07-15-2014, 07:29 PM | #5 |
x3 for bending it back.
project: "my happy mess" |
07-15-2014, 07:50 PM | #6 |
I would put masking tape on it, and then use a big crescent wrench like 67 above mentioned. You can probably get it bent back and save the paint.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
07-15-2014, 08:05 PM | #7 |
Project Junkie! Fishing Poor!!
Big crescent wrench will do the trick. However I do not think you will save the paint.. Too much bend... WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
07-15-2014, 08:09 PM | #8 |
I will try to just bend it back. Thanks guys. I just painted it because it was trying to rust over night. I can touch it up when I paint the rear end and other small parts.
07-15-2014, 08:15 PM | #9 |
Try putting a rag over it and bend. There might be a chance the paint stays. A crescent wrench might fit, or a large pair of vice grips. If it doesn't turn out like you'd like, you've always got the spare from the other truck.
07-16-2014, 06:47 AM | #10 |
boy, if you look at the top of the frame where the bracket is riveted, it seems to be bent also, is that a factory bend? That would really tick me off... But I would also straighten it..
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
07-16-2014, 06:56 AM | #11 |
hamjet
I believe what your seeing on the frame is factory, the bend is in the wrong direction for it to have happened when the bracket got bent ! Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
07-16-2014, 01:08 PM | #12 |
That's the crossmember, not the frame.
