Old 01-13-2004, 12:09 PM   #1
KEH
Better late than never
KEH's Avatar
Should I drill holes in mufflers?
The shop that installed my exhaust mounted my mufflers in the vertical position. I don't know if this is good or bad, but a guy from Midas saw it and said it was stupid. He said they would build condensation and rust out. He told me to drill small drain holes in the low points of the mufflers.
I guess it sounds logical to me. What do you guys think?
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 01-13-2004, 12:14 PM   #2
PR454SS
PR454SS's Avatar
can you turn them in anyway? sounds like they put the wrong muffler on your truck, or just making sure they get repeat business
If the truck isn't used with a camper or anything so you don't worry about fumes I guess it would be okto drill small holes, just sounds like adding to the problem to me.
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Old 01-13-2004, 12:15 PM   #3
Primed67
Primed67's Avatar
I have had mufflers mounted like that and never had a problem. I had to mount mine like that because of space and clearance issues. If you drill holes in the mufflers your exhaust will be louder because the exhaust is escaping out the holes you drilled.
1969 Chevrolet SWB Stepside
1959 Chevrolet apache * Sold
1967 Prostreet Chevy SWB Fleetside *Sold
2014 1/2 ton Crew Cab Chevrolet 4x4
Primed67 is offline   Reply With Quote
Old 01-13-2004, 01:22 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Most stock mufflers have a small 1/8" hole drilled at the lowest point at one end. It won't make it any louder, but it will be another spot that it will start to rust...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-13-2004, 01:29 PM   #5
junkyardjohn
junkyardjohn's Avatar
I THINK I'LL HAVE TO RAISE THE B.S. FLAG ON THIS ONE
NO MUFFLERS THAT I HAVE EVER OWNED HAVE HAD ANY HOLES DRILLED IN THEM TO LET MOISTURE ESCAPE. SOUNDS KINDA LIKE DRILLING HOLES IN THE BOTTOM OF YOUR BOAT TO LET THE WATER OUT. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 01-13-2004, 01:52 PM   #6
cdowns
cdowns's Avatar
OK I'M GOING OUT TO DRILL HOLES IN MY BOAT GOOD IDEA
Old 01-13-2004, 02:12 PM   #7
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
If you drive more than 35 miles a day don't worry about it. Most of all mufflers have a aluminized coating on the inside and the outside to help them resist rust. Driving more than 35 miles a day will heat the muffler up enough to evaporate the condensation build up.
67Fleetsidedream is offline   Reply With Quote
Old 01-13-2004, 02:20 PM   #8
Rooster's 67
Rooster's 67's Avatar
ok...ok.....ok factory mufflers and alot of aftermarket replacement(stock style) have a small 1/8 inch or so hole at the lowest point in the muffler. to drain condensation out of the muffler. If you drill a small(1/8 inch) hole at the lowest point it will drain condenstion but at the point you drill the edge of the hole will have the aluminization removed and will allow that hole to rust. And true if you drive enough miles at one drive cycle it will help to evap the condensation in the muffler, and the oils and the lubes. short trips are hard on vehicles and will put them into the severe use catagory on most any manufacturers maintence schedules.
Drill if you are worried dont if your not.
your not goung to cause the world to fall off of its axis either way.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 01-13-2004, 02:24 PM   #9
Rooster's 67
junkyardjohn........I guarantee that the 84 you own had moisture release holes in the mufflers from the factory
and most boats do have a hole at the lowest point to let water out,,,,,but MOST people plug them before floating their boat.
Old 01-13-2004, 03:30 PM   #10
67chevemall
67chevemall's Avatar
Sounds like advise for the dumb a55 ricers that spend $1000's on a lound exhaust for a civic!
If they were smart enough they would just drill a flippen holes in the stock exaust or muffler!
Don't drill holes man re do it!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 01-13-2004, 03:39 PM   #11
Grim Reaper
Re: Should I drill holes in mufflers?
And they are not going to condinsate laying flat? I have as yet to see a muffler that doesn't have some sort of lip that is going to preven any water from colecting not to mention most mufflers are mounted before the axle and have to route the pipe up over that.
If you have more then a teaspoon of water collect in your muffler when you shut it down you got a lot bigger problems then condisation. You got a blown head gasket or your truck is in the lake.
Mufflers need some sort of volume to do their job. THe reason they are flat is to alow them to tuck up to the floor of the vehicle. It doesn't really matter what way they mount as far as performance.
As for the condinsation that they do produce. That 500 degree air moving through it will change it to vapor and move it out just like the heat in the crank case does for the condisation in there.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 01-13-2004, 04:47 PM   #12
67chevemall
Grim Knows!
Old 01-13-2004, 04:56 PM   #13
Russell
Professional Grade
Russell's Avatar
"MOST" people, hehehe, that was an interesting boat launch....
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 01-13-2004, 05:02 PM   #14
stingray72
Red Headed Step Child
stingray72's Avatar
Don't laugh... I did it.. Got 1/2 way across the lake when I noticed the boat wasn't planing to well. Let off the gas and got drilled by 50 gallons of water. Lucky for me my boat is a Direct drive and the plug is installed under the engine right behind the drivers seat. I got a good bath but got the plug in before the boat went under. Bilge pump got a good workout
BTW... I laugh at myself for this one to this day
"Dinner, the perfect break between work and drunk"
-Homer Simpson
stingray72 is offline   Reply With Quote
Old 01-13-2004, 06:36 PM   #15
Maximum Overdrive
December 21, 2012
Mine has holes but I wouldnt say they are drain holes.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 01-14-2004, 12:30 AM   #16
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have seen plenty of mufflers with the aformentioned drain holes. Both OEm and replacement style. I have never seen them cause any noise either. Not a single one.
If you decide to poke holes in your mufflers, spray a little high temp header paint in the hole. 1200 degree paint should hold up way back there...even 500 degrees amy be a bit high of an estimate.
Old 01-14-2004, 12:37 AM   #17
Hooter
My other Love
Hooter's Avatar
I dont think it is gonna make your mufflers last any longer, mayvbe a year or two more, they'll rust out, eventually, especially if you drive it in the winter, of course the best way is to go stainless steel but it is pricey, unless you work at a mill and get it all for free
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 01-14-2004, 12:49 AM   #18
Blue Beard
Blue Beard's Avatar
my 2000 has a hole in it ........weeps water (condensation)
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-14-2004, 01:44 AM   #19
Rod
Hmmm.. well up here if you want lifetime warranty on your exhaust muffler they center punch a hole in it at the lowest point at rear.. one year warranty = no hole... same muffler either way. Thats what I noticed.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 01-14-2004, 02:18 AM   #20
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally posted by junkyardjohn
NO MUFFLERS THAT I HAVE EVER OWNED HAVE HAD ANY HOLES DRILLED IN THEM TO LET MOISTURE ESCAPE. ....
OK, Ill be specific then. NO the holes aren't "drilled" in them, they are punched or stamped in them.
Do us favor and go look at a few stock mufflers before you call my response bullsh!t. Do us another favor and turn YOUR CAP LOCK OFF
Old 01-14-2004, 02:24 AM   #21
chevymad
Anybody ever hear a ford exploder with the stock steel muffler? Drain holes right in the middle. After it rusts a bit they tend to make a whistling noise. I've had many people come in wondering whats wrong with their ford.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop
70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress
chevymad is offline   Reply With Quote
Old 01-14-2004, 03:46 AM   #22
BUXMAN66
go bucks!
it's a ford ding-dangit!! god this is a funny thread!!!
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 01-14-2004, 07:59 AM   #23
junkyardjohn
NUTUTRUX. HMMMMM -- I CRAWLED UNDER ALL 8 OF MY TRUCKS..... & NOT A SINGLE DRAIN HOLE TO BE FOUND IN ANY OF THEM (& MOST HAVE 2 MUFFLERS) BUT MY NEWEST TRUCK IS 22 YEARS OLD, & THEY'RE ALL CHEVYs OR GMCs. I ALSO HAVE 4 BRAND NEW IN THE BOX FLOWMASTER 40s SITTING HERE WITHOUT ANY DRAIN HOLES. ALSO A PAIR OF HOOKER AERO CHAMBERS & NO HOLES. MAYBE IT'S A RECENT THING, OR JUST ON DODGES & FORDS??
AS FAR AS ME TYPING IN ALL CAPS (NOT THAT I FEEL THE NEED TO EXPLAIN MYSELF TO YOU) I'M HANDICAPPED & ONLY TYPE WITH ONE FINGER ON MY LEFT HAND, & FIND IT A REAL PITA TO SWITCH FROM LOWER CASE TO UPPER CASE ALL THE TIME. IF IT BOTHERS YOU TERRIBLY..... PLEASE PUT ME ON YOUR IGNORE LIST(IT'S UNDER USER CP) & MY POSTS OR REPLYS WONT SHOW UP TO YOU.
DRIILING HOLES IN YOUR MUFFLER (& BY ALL MEANS DO IT) SEEMS LIKE TAKING A BATH WITH YOUR SOCKS ON TO ME. OUT HERE EXHAUST SYSTEMS LAST 8 - 10 YEARS AS COMPARED TO 2 YEARS WHEN I LIVED BACK IN MICHIGAN.
junkyardjohn
DON'T RENT U-HAUL
Old 01-14-2004, 11:48 AM   #24
Huck
Huck's Avatar
And to think I spend hours trying to seal up holes in my exhaust with a welder---only to find out I should be making holes!? Actually I have done the hole thing and am not sure that it really makes a big difference as mufflers are internally designed to muffle---and are NOT designed to drain condensation to any pre determined spot so you will probably be doing a superficial thing with drilling a hole for the lowest point. Condensation will still collect water within the baffles that gravity will not drain.
My personal preference is to leave the SOB alone as after a while I kind of want a change of tone and another muffler anway. AND I don't want to hear a cherp,peep,sush,pop etc. from the exhaust that I caused. I got enough from my crappy welding already!!
Huck is offline   Reply With Quote
Old 01-14-2004, 11:54 AM   #25
N2TRUX
Happy to be here
N2TRUX's Avatar
Naaa, your post don't really bother me with the cap lock thing. At least now I know why. Normally I find your responses very informative and polite. That's why I was surprised when you got on my reply as bullsh!t that way.
I do have a lot of late model stuff, but I can vouch for at least one older GM vehicle haveing the hole in a stock muffler. The first time I saw the drain hole in question was on my 84 Z-28. It had one in the factory muffler and it always puked black carbon crap across the muffler.
I know my 95 and 97 Silverado had the same hole in itheir muffler too...
BTW- I'm not handicapped and I only use two fingers to type
