1970 C50 Brakes
Hi all,
new to the forum - I've got a 1970 Chevy C50 dump that I acquired with some property. It's been sitting for a while and I am going through it to get it running and stopping. Engine is almost there - still going through carb and sticky valves - bad old gas. Now I am over to the brakes - I have none - pedal to the floor. Booster falling apart. Before I start getting into some bucks for obscure parts, I read in another thread to consider replacing the single MC and remote booster with a standard firewall mounted dual circuit MC/Booster. Is this a good idea? any pointers on years and parts from donors? How do I ensure I maintain the load capacity of the truck (with the DMV?) Thanks for your help, BT |
Re: 1970 C50 Brakes
Breaks are the most important part of a truck with steering coming in a close second.
Running Hydroboost is highly recommended. But, I can tell you right now that the DOT does not like any modifications so you need to ask yourself what you will be using this truck for. On the state level you should contact more then one shop that does inspections to get a unbiased opinion to see if your are going to have trouble with the updated and improved system. As far as maintaining the pressure with hydroboost. You will. If you are using vacuum/hydro then hydro boost will make enough if not more pressure then the stock system. There is nothing wrong with running vacuum/hydro. It is a good system and can be maintained easily enough. Just be glad you have a Chevy. I have restored a few old trucks to stock "show points" condition before. Short version is that I will never do another air/hydro Power Wagon again. The less expensive dual circuit in my current 67 "points" project was bought based on the nightmare finding air/hydro parts and getting bent over by the big 4 who still sell parts. I would suggest moving up a few years when you replace the master cylinder to give you a dual circuit and don't think one person except for a points judge at a show is going to say anything bad about the upgrade. The rest of the system is good in stock form. Just replace the wear components and call it done. |
Re: 1970 C50 Brakes
Replace both the vacuum booster and the dual master cyl as a set. Is your booster under the cab or on the firewall? If under trash it and put your new on on the firewall.
Be prepared to spend some cash on the wheel cylinders, there are two for each backing plate and they are large. Your going to need a friend to remove the drums or you will forever have back issues. Replace all of the steel lines, along with the ones that run from the top wheel cylinder to the bottom wheel cylinder. I have told myself that I will never do this again I am swapping front and rear axle to get disk brakes on my current 67 C50.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
Re: 1970 C50 Brakes
Should I put the booster on the firewall like a conventional car/light truck - between the pedal and MC? Right now, it's under the cab and it's spent...
Current MC is a single circuit. If I go dual, can you recommend a MC and booster to use - year of donor vehicle? How would I split the system? The 70 C50's have an odd split where the fronts and one of the rear cylinders is one circuit, and the other rear cyl is the secondary circuit. Do it that way? diagonal? Front/rear? don't think I'm ready for discs just yet - maybe later... Thanks for the headsup on the drums though - everything on this truck is heavy. Thanks again, BT |
Re: 1970 C50 Brakes
Spilt it front and rear.
Yes Booster on firewall I am using a TopKick Master and booster but I am using hydroboost Do you have power steering? If so you can use it too. But Ill look around and see what may work with a vacuum booster I had a 72 C50 with the booster under the cab and a second master down there too. all though mine was still all one system. Loose one brake seal and it's all over. Post a photo of your truck! Here is my first one (sold) and my current one.
Re: 1970 C50 Brakes
I do have power steering so hydroboost would be an option. I want to keep the GVWR if I can and the dump bed and maybe put this thing to use
![]() Nice trucks - I'll get a pic soon - mine's still a little rough... thanks |
#7 | |
Re: 1970 C50 Brakes
http://sarasota.craigslist.org/cto/4582688095.html
Re: 1970 C50 Brakes
Is your MC like this? My C50 has the Hydrovac system. Parts aren't quite as obscure as one might think. I can't speak for the other type setup with the booster on the firewall. I am pretty sure that the pressures are different between the two systems.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
#9 | |
Re: 1970 C50 Brakes
Re: 1970 C50 Brakes
That's a great truck. It's got the right frame and axles, trans and air brakes to not be a pickup, no?
Re: 1970 C50 Brakes
Yup, same single circuit MC and same 350 small block. Booster under the driver side cab.
I've found most of the parts at Carquest here but since they're all bad on my truck, instead of sinking money into an outdated braking system on a truck where originality doesn't count, thought I'd investigate a more modern layout. Doesn't have to be hydroboost, but that does seem cool- my diesel pickup has a similar layout. I just wanted mostly to get a more failsafe dual circuit system. If I can save a little with a more common booster or a hydroboost, and get better braking, all the better. thanks |
Re: 1970 C50 Brakes
There is a thread or two over on stovebolt that you might want to look at. Here's one. http://www.stovebolt.com/ubbthreads/...gonew=1#UNREAD
#13 | |
Re: 1970 C50 Brakes
Which year top kick MC and GVWR rating if you don't mind me asking? I have to modify my diver side valve cover on that big Detroit to clear the MC if I use a Hydro-boost and MC from an 87 C-50. Its a little hard to see as the picture is fuzzy but you get the idea.... I have all new brake lines run for a dual line system and just need to figure out this last piece for brakes...
--------------------------------------------------------------------------- 72 GMC K5500 Napco 4x4 8V71/RTO-9513/T-1138 71 Corvette Wide Body 502 Ramjet 83 HD XR1000, 99 HD XL1200S, 84 YAM RZV500R 05 MB E55 AMG, 12 45th Camaro SS stick vert Last edited by 84rzv500r; 08-18-2014 at 01:05 PM. Reason: add pic |
Re: 1970 C50 Brakes
Here is the HydroBoost from an Astro I have on my 67 C10. I may try this on my 67 C50 depending on the cost of the TopKick version.
#15 | |
Re: 1970 C50 Brakes
#16 |
Re: 1970 C50 Brakes
ok,, that what i thought... I run a similar set up on my 71 corvette and wilwood calipers. think the issue will be master cylinder piston size/volume... have seen is the cars and small trucks run 1 inch to 1.125 MC bore and the larger trucks run from 1.250, 1.50, or 1.75 depending on the brake system.
It's a pascal's law thing. I am going with a 1.75 MC and a hydroboost from 87 C-60 that has the same brakes as my truck. Thanks for the info. ![]() ![]()
--------------------------------------------------------------------------- 72 GMC K5500 Napco 4x4 8V71/RTO-9513/T-1138 71 Corvette Wide Body 502 Ramjet 83 HD XR1000, 99 HD XL1200S, 84 YAM RZV500R 05 MB E55 AMG, 12 45th Camaro SS stick vert |
#17 |
Re: 1970 C50 Brakes
Yea, that sounds like a good plan. And would like to know how that goes.
By the way my Daughter used to live in WPB now married in Coral Springs. When I get down that way Ill see if I can drop by, love to the the truck and the vette. I have a vette buts it's an 04 Z06, not a classic but still a fun car!
#18 | |
Re: 1970 C50 Brakes
#19 | |
Re: 1970 C50 Brakes
#20 | |
Re: 1970 C50 Brakes
#21 |
Re: 1970 C50 Brakes
Thanks guys!
I'm liking the hydroboost solution more and more. Looks like 79-87 hydroboost may be the simplest way to go - I don't want to do an axle or spindle swap just yet or should I go ahead and bite that bullet too? Would you do discs front/drums rear? Or can I do a 87 M/C and booster and keep my existing wheels and drums as is? Thanks again. |
#22 |
Re: 1970 C50 Brakes
On the 87 C50's , there are a few setups, vacuum boost, hydroboost, and "dual power" vacuum and hydroboost. I think I want to go with the "Hy-power" option which is hydroboost only - how can I learn more about the applications for 87 and if this option is sufficient for my weight rating (22,000 GVWR). Is this hy-power booster driven by an electric motor then on top of the hydraulic feed from the power steergin pump?
Pics would be most helpful! Thanks guys.. |
#23 | |
Re: 1970 C50 Brakes
Low pressure Return hose from the booster to the steering gear to the pump
#24 |
Re: 1970 C50 Brakes
Thanks! I'm good with the hose routing, what I'd like to see is the actual hy-power booster and m/c installed on the firewall. Is there no electric motor like on the smaller cars and trucks? Why did GM offer the "hy-power" and the "dual power" options where the dual power also has a vacuum booster?
#25 |
Re: 1970 C50 Brakes
Electric motor? I have an hydroboost on my 67 and trust me there is no electric anything on it.
