Old 03-02-2015, 09:30 PM   #1
400/400
Re: Minnesota Daily Driver
I was happy with how they turned out and started on painting the firewall.
1979 K25 350/SM465/205/44HD/14FF
1985 K20 400/400/208/10/14
1987 V10 TBI350/700R4/208/10/10
'85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968
400/400 is offline   Reply With Quote
Old 03-02-2015, 09:33 PM   #2
400/400
Also, I had chiseled out the dry seam sealer from the cowl and re sealed it. The cowl was painted with the firewall.
Old 03-02-2015, 09:40 PM   #3
400/400
Previously I had mentioned adding a stereo around Christmas. I made a board to mount the sub and amp on and got it in behind the seat. There were also 6x9's powered off the amp installed in the original locations behind the seat.
Old 03-02-2015, 09:44 PM   #4
400/400
Also got my mud flaps installed around that time. They do a good job of keeping the winter slop off the truck.
Old 03-02-2015, 09:46 PM   #5
400/400
Then it was time to haul some lumber. The truck rides pretty well with 600 + pounds in the bed.
Old 03-03-2015, 12:00 AM   #6
y5mgisi
Second Chance Program
y5mgisi's Avatar
Thanks for the continuation!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 06-03-2015, 08:18 PM   #7
400/400
It's been a couple months since I posted about the build. Here's some more....
Once I got the cowl painted, it was time to set the box on the frame. It had been stored upside down so I could paint the under side so the 1st step was to get it vertical.
Old 06-03-2015, 08:24 PM   #8
400/400
Then came the fun part, getting back down without damaging the lower bed sides. With some carful use of wood blocks we were able to get it down. I was fortunate to be able to borrow a bobcat to set the bed back on the truck.
Old 06-03-2015, 08:33 PM   #9
400/400
I also found a couple more pics that show what I started with, as far as the rust went on the rockers.
Old 08-30-2015, 05:09 PM   #10
400/400
Been a few months since I posted on the build. I've been driving the truck daily for about a year with a bit over 10,000 miles on the rebuild.
I decided to go to an electric choke vs the divorced choke. So I rebuilt the carb that was original to the truck.
Old 08-30-2015, 05:12 PM   #11
400/400
I also found this pic of the 1st time the bed was put on the truck.
Old 08-30-2015, 05:47 PM   #12
Zane M
Amazing work. Thank you for sharing.
Zane M is offline   Reply With Quote
Old 08-31-2015, 03:09 AM   #13
MTCK
MTCK's Avatar
Looks awesome. Glad you have been racking up the miles.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 09-02-2015, 06:07 PM   #14
400/400
Thanks. It's been a fun vehicle. A lot of people like to stop and chat about it in parking lots.
Old 09-02-2015, 06:09 PM   #15
400/400
Made a bit more progress on the finishing touches today. Got the new AC components in and charged. Man it's nice having working AC.
Old 10-07-2015, 07:26 PM   #16
400/400
Helped a fellow car guy get his new project home today.
Old 09-02-2015, 06:05 PM   #17
400/400
Thanks!
Old 01-03-2016, 03:24 PM   #18
400/400
Also swapped the steering wheel for one out of a late '80s/ early '90s. I think it gives a bit more room.
Old 01-03-2016, 04:54 PM   #19
MTCK
MTCK's Avatar
Looks good. I like the handles. The wife unit would be very happy with a couple of those.
I think you are right, our plow controls look identical.
-Marcus
Project Plow Truck
Old 01-04-2016, 08:14 PM   #20
400/400
I like the handles because they give you something else to grab on the drivers side. I made a habit of not grabbing the wheel as it's hard on the column so it was kind of a trick to hop in before the handles.
Old 01-04-2016, 08:17 PM   #21
400/400
Back to the build.
After fitting the doors it was time to install the rubber floor liner.
Old 01-04-2016, 08:23 PM   #22
400/400
Then I threw the seat it and started gathering parts to bring it to the body shop.
Old 01-19-2016, 10:50 AM   #23
LF_MN_71GMC
LF_MN_71GMC's Avatar
Hello from Isanti,
This is great work, I'm waiting for a good snow to get my square out to plow for the first time. It has a 4" lift and I have not modified any of the A frame brackets, I hope it's not tippy.
1971 GMC 4x4 half ton np 205
1969 chevrolet camaro
1984 K10; 4" lift; sbc;
Build link
http://67-72chevytrucks.com/vboard/s...d.php?t=647172
LF_MN_71GMC is offline   Reply With Quote
Old 01-19-2016, 09:14 PM   #24
400/400
Originally Posted by LF_MN_71GMC View Post
Hello from Isanti,
Thanks. Yeah not much snow yet. If your plowing fresh snow the blade shouldn't be too tippy. It's worse when there's a layer that's already been driven on. I've only put it one once this year so far. May use it this weekend to clean up some drifting.
Old 01-19-2016, 09:17 PM   #25
400/400
Replaced the t-stat. Noticed the truck wasn't getting up to temp. Not a great thing when it's around 20 below.
