![]() Join Date: Aug 2014
Re: Restoring Rusty
AND ALL BACK TOGETHER IN 72 HOURS!!!
but didn't get to start it cause I finished after 11:00 PM and it would have been way too loud!!! |
Re: Restoring Rusty
Nice job!
Craftsman isn't what it used to be...or maybe it is. I had a Craftsman electric impact that did it's job for a bunch of years. The ring that holds sockets on was always kind of a pita though and would stick one on or spit one off at random. When I was checking out junk at HF one day, I took a look at their impact and doggone it...except for the color it's exactly the same unit. So when the Craftsman crapped out, guess which one I bought?
Romans 10:9 - The Truth |
Re: Restoring Rusty
You can say that again, the plastic handle on the new one feels like it will shatter at any time. I swore I would not buy Craftsman any more but I really had no place to turn but Sears, maybe Lowes I guess, but aint they all Chinese.
Re: Restoring Rusty
I've got an old craftsman torque wrench that has a ponter on it instead of the click style now. I got it when I was in high school. I'm guessing it's still accurate after all these years.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
Re: Restoring Rusty
how in the world do you use that when you are hanging upside down under the car by your feet in the dark with the sun in your eyes while its raining, with the clicker you hear the click, ha ha
Re: Restoring Rusty
Well honestly it ain't easy really. You just have to be ready to jump out the way.
Re: Restoring Rusty
So, get that thing on the dyno so we can see the fruits of your labor!
Re: Restoring Rusty
Re: Restoring Rusty - Summit Epic Fail
So Summit finally sent me a replacement water temp gauge for the one that broke after only a couple weeks, but you won't believe this
so I send in my old GREEN water temp gauge with a filled out form with the part number and the box checked for please exchange it for the same part number, explanation stopped working after a couple weeks a week later, I get a refund for about $9 bucks, I call them up and say whats this for, it's for the Sending Unit you returned to us - um no I didn't my sending unit is still in the truck, oh so sorry we will send you your gauge a few days later get an email, we just shipped you your Oil Pressure Gauge I kid you not, so I email them, guys this is in regards order/return number blah blah blah, I don't want an oil gauge a few days later get an email, "What do you want" so I reply please replace my water temp gauge with a water temp gauge part number blah blah blah and today this is what i got, a friggen RED Water Temp Gauge I have completely lost faith in humanity! |
Re: Restoring Rusty
I T ' S A L I V E so it fired right up on the first try I kid you not, but it would not keep running unless my foot was on the gas pedal so I bumped up the timing advance and that made it happier (turns out it was at only 6 degrees when I eye balled it) I bumped it to 10.5 since that's as far as my dizzy would rotate before the vacuum pod hits the intake manifold - if anyone knows how to remedy that situation please let me know I also increased the idle speed screw cause it was trying to idle below 500 RPM, so I bumped it to a happy 750 RPM then I alternated reving it up for maybe 30 seconds at 1500 then back down, then to 2000 then back down, then to 2500 then back down, rinse, lather, repeat man does it sound smooth at 1750 I swear you would think it's a Cadillac motor under the hood, ha ha here's a sound bite for you all, and thank you so much for reading, follwing, and pulling for me and Rusty, we sure appreciate it 1974 GMC / Chevy C10 Idling After New Rings & Resonators Only Exhaust |
Re: Restoring Rusty
Glad to hear it went well with the ring job. It sounds really good..
The 454 in my truck could use some help too. I smoke out my neighborhood when the outside temperature is around 60 degrees or lower. Once my engine warms up it's good. Either my rings or cylinders are worn out. I'm liking your festive gauge package is it Christmas in October? |
Re: Restoring Rusty
ha ha, not for long I got tired of the red gauge display making me think I am in the red sort of speak so I yanked it and sent it back to Summit for an exchange, I did buy a green one originally after all so I expect an exchange for a green one - is that too much to ask? ha ha
#13 | |
Re: Restoring Rusty
Re: Restoring Rusty
Sounds like the distributor is out a tooth. Just pull it, turn it a tooth, turn the oil drive about the same amount with a LARGE flat-blade screwdriver, and plunk it back down.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#15 | |
Re: Restoring Rusty
I think you are right about being a tooth off, I just drove the truck in to work today and it had no power in 3rd gear, I thought it was running too lean, but even when I turned the idle mixture screws out more the problem did not go away. This would obviously explain why my distributor vacuum pod hits the intake manifold earlier than normal. What a shmuck I am, I will limp it home and drop it in proper, perhaps even do it sober this time, ha ha |
#16 |
Re: Restoring Rusty
What's your cam specs on this motor? I have been reading the last dozen or so pages but haven't found the time to start at the beginning, its a little lengthy.
![]() 10 degrees is usually a good amount for a typical 350. That's your max mechanical advance and at what RPM?
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15 GM 4 bolt 880 roller block, 062 Vortec Heads Comp Cams XR258HR-10, MSD Street Fighter HEI Edelbrock: Performer Intake 2116, 1405 Carb Long tube headers, 2.5" duals to Flow Master Super 40's Vortec Engine Build |
#17 | |
Re: Restoring Rusty
GM P/N 24502476 212° / 222° Duration .290" / .307" lobe lift .435" / .460" valve lift 112° lobe seperation 108° ATDC intake 116° BTDC exhaust |
#18 | |
Re: Restoring Rusty
Note To Self: some day do a study of timing advance and the correlation to truck gitty up Last edited by Gregski; 10-20-2016 at 09:52 PM. |
#19 |
Re: Restoring Rusty
My cam is 231°@050, with 108°LSA. I run 20° base, with 16° mechanical, and 12° vacuum at the manifold.
#20 |
Re: Restoring Rusty
My cam is 192/200°@050, with 108°LSA. I run 16° base, with 20° mechanical, and 15° vacuum at the manifold.
Rich Weyand 1978 K10 RCSB DD. |
#21 |
Re: Restoring Rusty
so a quick update, well it turns out I am not a shmuck and the distributor was in there correctly, see the before and after pics of when I re stabbed it today, they look identical and that's the best way it goes to be at #1 TDC, I even took the driver side valve cover off and spun the engine around and watched the #1 intake valve go down and back up, etc.
#22 | |
Re: Restoring Rusty
All your fueling is going to be dependent on your timing - if you're not running the same base timing as you were before, your fueling will be off. Get your base timing back to where it was, and you ~shouldn't~ have to muck about too much (other than you might have a lot more vacuum and compression now).
#23 |
Re: Restoring Rusty
without my Air Fuel Ratio since the O2 sensors went on a frits and both read 22.4/22.4 I felt like a fish out of the water, but I tried to tune what I could, so I checked the float levels and they were a bit too high, so I adjusted them down a bit so that fuel only dripped out when I hip bumped the fender of the truck, I also screwed the idle mixture screws all the way in and watched the truck die, then I backed them both out 1/2 a turn plus it wanted another 1/4 turn out, that seemed to make things a tiny bit better I think
then I spent a couple hours fandangling with those BOSCH LSU 4.9 oxygen sensors and, calibrated them and re calibrated them, then cleaned them with some brake cleaner and a gold color bristle wire brush and finally one of them woke up and decided to work Now I had some feedback, so I took it for a spin and Idle mixture was good in the upper 13s, but WOT was lean high 14s sometimes 15s, so I think it's time to go to bigger jets currently I am running 62 primary jets and 65 secondary jets, I believe the carb comes stock with a 64/69 jet combo so I may inch my way up to that, maybe try 63/67 first this would make sense as we now have two more hungry cylinders to feed! Last edited by Gregski; 10-07-2016 at 10:04 AM. |
#24 |
Re: Restoring Rusty
I noticed that you didnt use a vortec specific intake gasket. Any reason for that?? Does the paper gasket seal just as good?? I only ask because I'll be replacing mine soon and the redesigned vortec intake gaskets are too expensive!!
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73 |
#25 | |
Re: Restoring Rusty
"Designed for GM Vortec, ZZ4, Edelbrock E-Tech cylinder heads. End rail seals are not included. Installation to be done with a bead of silicone at the manifold ends. Dual bolt pattern. No exhaust crossover openings. Not for use on 1982-85 fuel injection. Gaskets fit many O.E. and aftermarket heads." |
