10-06-2014, 05:54 PM | #11 |
Re: RnD Fabrication 1973-1987 Chevrolet & GMC C10 / C20 / Suburban Radiators!
the standard fans are private label fans we have made for us. We also can get Derale, Spal, and several others depending on what your budget / needs are. The more power you make and the less space available, the more they cost as a general rule. But with the C10's, there is a ton of room so our standard fans are usually more than adequate. If the engine is built, we just need details about the build / use of the truck to know what to recommend.
Tags |
radiator, rnd, rnd fabrication, rnd radiator |
