Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 03-08-2014, 06:25 AM   #226
Re: Project Family Hauler
Very Nice!
Palf70Step is online now   Reply With Quote
Old 03-08-2014, 11:04 PM   #227
pickup67man
pickup67man's Avatar
Originally Posted by Dieselwrencher View Post
That looks awesome great work?
Originally Posted by swamp rat View Post
Lookin good!
Very Nice!
Thanks. Soon I will be back to the suburban. Unless my dad is ready for floors in his Corvair first.
Travis
2005 K2500 Duramax (hauls the junk home)
1967 Chev C10 (hauls a$$)
1970 Suburban (Yukon XL 4 door)
1968 GMC 3/4 ton (sheetmetal only, chassis gone)
2005 Malibu (wife's car, still a Chevy)
New Home for Chevys (Moved in and working)
pickup67man is offline   Reply With Quote
Old 03-31-2014, 12:49 AM   #228
pickup67man
Little side project is done. I will be back to the suburban soon.
Travis
Old 03-31-2014, 12:51 AM   #229
pickup67man
Fuel filler is done too.
Travis
Old 03-31-2014, 10:22 AM   #230
fear_nothing
fear_nothing's Avatar
The bed looks awesome, what kind of wood/finish did you use. Great idea on the hidden fuel filler too
fear_nothing is offline   Reply With Quote
Old 03-31-2014, 03:18 PM   #231
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Holly cow, that looks amazing! Great work!
Ryan
1969 Chevy milk truck
Old 04-04-2014, 11:55 AM   #232
pickup67man
Thanks. The wood is padouk. I used a clear gloss marine spar varnish. That is 6 coats. The fuel filler was fun. Trying not to scratch the paint.
Travis
Old 05-10-2014, 11:03 AM   #233
Onelefttoget
Hello guys I want to say hi I live out in yelm if you guys would like to get toghter say hi I will be in Puyallup today helping my daughter move in my 70 suburban panel
Onelefttoget is offline   Reply With Quote
Old 06-07-2014, 02:27 AM   #234
pickup67man
If you want to find local get togethers check out northwest c10s on Facebook. We have local meets to check out every ones trucks. Not a car club, just a bunch of Chevy truck owners.
Travis
Old 09-30-2014, 01:14 AM   #235
HSRACER
HSRACER's Avatar
Any updates?.?..
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 10-27-2014, 02:16 AM   #236
pickup67man
Originally Posted by HSRACER View Post
Any updates?.?..
Just finishing a small addition to my garage so my finished truck will be better protected from the dirt. Then I can work on it again.
Travis
Old 10-28-2014, 03:59 PM   #237
04sshd
04sshd's Avatar
nice work, subscribed!
1968 Chevy C-10 Suburban - 350/350
1969 Chevy C-10 Panel Delivery - 454/400
1972 GMC K1500 Jimmy - 350/350/np205
1978 Chevy Corvette Silver 25th Anniversary
reddit.com/r/chevyc10 <-Join it!
04sshd is offline   Reply With Quote
Old 02-01-2015, 10:18 PM   #238
twistedchevy
Bump
twistedchevy is offline   Reply With Quote
Old 02-01-2015, 11:26 PM   #239
swamp rat
swamp rat's Avatar
I saw him breathing on Facebook the other day.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-08-2015, 07:22 PM   #240
pickup67man
I have been working on it slowly. Mostly rust repair to the passenger side. I also found out why the back door didn't fit right. The body bushing just in front of the rear tire was missing, causing the body to sag 3/4". Because of all my rust it really twisted the body.
Here is where I left off.
With the body mount corrected the doors open and close better.
The floor is done behind the B pillar.
I tack welded the front floor patch.
Then I ground down all the welds and painted the bare metal.
I rebuilt the bottom of the B pillar and removed the suburban part of the rocker panel.
Then I grafted it onto the truck rocker panel.
Next I will finish the bottom of the B pillar and be playing with the rocker panels. Also need to make the back door latch.
Travis
Old 02-08-2015, 10:02 PM   #241
swamp rat
swamp rat's Avatar
Good thing you caught that body mount befòre ya got too far along.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 01-02-2016, 09:53 PM   #242
pickup67man
Time flies with out updates. Got burned out on bodywork, then busy for the summer. Bought a donor vehicle from an auction to use. Not sure if it will yet.
Stripped and sold all the parts I didn't need then rolled the frame into the garage.
The wheelbase was 135" and I needed 127" so I took 8" out of the middle.
Then I rolled the old frame out and the new frame under only to find the engine is set back farther in vans and it hit the firewall. So I pulled the engine out so I could position the frame correctly.
Then cut off the motor mount stands and moved them forward 2 1/2" so the engine would clear the firewall. The drivers side had to be notched around the front differential mount.
After all that work I don't like how the frame hangs way below the body. Instead of being inside the body supports it is under them. Add to that the frame is 1 1/2" taller and it is very visible.
Any ideas to make it fit better would be welcome. Or I am putting the original frame back under.
Travis
Old 01-03-2016, 02:25 PM   #243
fear_nothing
Looks like you've really put in a lot of well thought out work. How many times have you pulled the engine / put it back in? Looking good so far
Old 01-03-2016, 09:57 PM   #244
pickup67man
The engine has only been in and out 3 times since the frame went under.
Travis
Old 01-03-2016, 11:41 PM   #245
jbclassix
Junk Yartist
jbclassix's Avatar
wait, what! how did I not get update notifications on this!
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 01-04-2016, 09:30 PM   #246
Dieselwrencher
Nice work! I have no real helpful ideas on how to hide the frame from showing. Step tubes are my only idea. That might hide it some what.
Ryan
Old 01-05-2016, 12:07 AM   #247
Average Joe
Average Joe's Avatar
Channel the body over the frame?
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 01-05-2016, 01:34 AM   #248
jbclassix
Junk Yartist
jbclassix's Avatar
I gotta say, from the pictures, the frame doesn't stand out that much. being that it's fully boxed, I like it. being a van frame, it does seem more of a challenge. for the crew we just said screw it, cut the floor and set the cab where we wanted it, then built a whole sub framed floor to fit the newer frame. for my burb, I plan on keeping as much of the donor floor as possible. being that you're burnt out on body work, I can understand not wanting to dive into any more mods. I imagine the van floor sat way too high to have a flat deck and clear the power train, so my suggestion would be just snip bits out of the way of the body until it sits where you want, then built a subframe for the floor where needed. this may give you better mounting points later as well. since its 4x4, how much of the frame do you really need to hide?
-Jeremy
Rebuilding an NP205
Old 01-08-2016, 03:20 AM   #249
pickup67man
That's what I was thinking.
Going to modify the floor. Not the floor itself but the floor supports. They run right above the new frame so why not move them. I cut some out of a junk cab to test fit. They will sit just inside the new frame and since that is where the body mounts are I can make the mount brackets sit at any height. This will lower the body about 2 1/2". The rest of the body should be fine.
By the way it's not a 4x4. It's AWD. They sit lower and it sounds sportier.
Travis
Old 11-13-2016, 11:16 AM   #250
NurseBen
NurseBen's Avatar
What's the latest on this? I don't want to be the only one using an AWD van for a frame swap, that's a bad sign! Mine is almost finished so if you're still pressing forward I could offer up some advice on lowering/steering/brakes, the things that took me the longest to figure out. Best wishes, Ben.
NurseBen is offline   Reply With Quote
