Old 08-13-2019, 03:03 PM   #1
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Project Screamer - '72 GMC K2500 + DD 4-53T
Nice work on the bumper mods on the frame. That looks great. That's awesome they are cranking out the paint work too! Maybe you can drive it around before your weather starts to turn.
Ryan
1969 Chevy milk truck
Old 09-20-2019, 09:16 AM   #2
regan wilson
regan wilson's Avatar
Those body panels are surprisingly clean. It should turn out really nice. Does this mean you will be driving by the Spring? I'm ready for videos.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 09-20-2019, 12:33 PM   #3
burnitg
Yes, I’m on track to be driving it by spring. One never knows...
I haven’t posted any videos. It will be a learning experience for me.
burnitg is offline   Reply With Quote
Old 09-25-2019, 02:48 PM   #4
burnitg
4-53T All Painted and Ready to Run...
I've painted and reassembled the engine.
Name:  4-53T Painted - right front.jpg
Name:  4-53T Painted - left front.jpg
Name:  4-53T Painted - right rear.jpg
Name:  4-53T Painted - rear.jpg
He's ready to run.
Old 09-25-2019, 03:34 PM   #5
Lemield
Lemield's Avatar
That is a thing of beauty!
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 09-25-2019, 07:00 PM   #6
OutlawDrifter
Very nice!
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 09-26-2019, 07:23 AM   #7
regan wilson
Looks awesome. Detroit Green
Old 09-26-2019, 12:01 PM   #8
lower50's
lower50's's Avatar
Very nice and clean. Did you paint it all together or apart?
Ps: I think your fan belt is a bit loose.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 09-26-2019, 04:40 PM   #9
burnitg
A mix, i removed the water pump, oil cooler, oil pan, rocker cover, turbo and exhaust manifold. The remainder, I painted together. I had the exhaust manifold and turbine housing ceramic coated.
I left the belt loose because I can’t set the vertical height of the fan until I have the engine in the truck and the fan shroud installed.
Old 10-19-2019, 03:12 PM   #10
burnitg
Painted!
The old Jimmy is painted. I drove down to Denver yesterday and picked him up.
Name:  On the trailer headed home.jpg
The paint job is GORGEOUS! I don't think he looked this good when new.
Name:  Painted tailgate.jpg
I had the bottom of the cab coated with Lizard Skin to help mitigate the noise from the engine and transmission. I used Lizard Skin on the bottom of my UNIMOG cab. It made a big difference.
Name:  Cab Lizard Skin.jpg
He's going to sit on the trailer for a while. I'm still working on the chassis and drive train.
Old 10-19-2019, 04:27 PM   #11
kipps
Any chance you're going to make a custom SPID sticker for the truck? Make up your own RPO codes for the detroit and other custom bits? It'd be interesting to see GM truck aficionados try to make sense of that one!
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 10-20-2019, 01:53 PM   #12
burnitg
I have considered making my own SPID sticker. I have the correct option code for the 4-53T from the 1979 C-70 that I pulled it from. I’ll have to create my own code for the Fuller transmission since it wasn’t offered. I won’t do anything until the truck is back on the road.
Old 10-30-2019, 01:45 AM   #13
Average Joe
Average Joe's Avatar
That would be very cool!
1967 C10 Suburban 454/TH400/3.07's
An Average Joe and His 'Burb:
http://67-72chevytrucks.com/vboard/s...d.php?t=775843
Average Joe is offline   Reply With Quote
Old 11-03-2019, 08:29 PM   #14
burnitg
The engine has landed!
I finished the brake and fuel tubing and dropped the engine into position in the chassis.
Name:  4-53T in the chassis.jpg
It sure looks good.
Old 10-20-2019, 06:27 PM   #15
regan wilson
Man that looks awesome Burn. I can't wait to see it together.
Old 11-04-2019, 07:32 AM   #16
regan wilson
Yes it sure does.
Old 03-13-2020, 09:24 AM   #17
regan wilson
Any updates?
Old 04-23-2020, 11:43 PM   #18
Dieselwrencher
Man the body looks beautiful!!! When you get to the spid, member chipflyer makes them and he will custom make you one as well. The engine and chassis look sweet too!
Ryan
Old 12-04-2020, 05:50 PM   #19
lower50's
lower50's's Avatar
Updates? Hope things are good.
1951 MG TD
Old 02-23-2021, 05:17 PM   #20
kipps
Any updates? I've been pretty excited about this build, and want to see it continue.
Old 04-07-2025, 05:29 PM   #21
kipps
Bump to the top again -- any updates?
Old 11-06-2025, 09:06 AM   #22
Dieselwrencher
Burnitg, I hope all is well and the truck has been done for a while?
Ryan
Old 11-06-2025, 10:05 AM   #23
OutlawDrifter
Looks like he hasn't logged in for over 5 years!
1991 Z/28, 6.0L/T56
