11-07-2014, 12:46 PM | #1 |
69 pro touring/ autocross.
Sold my 68 step ls1 truck and decided I wanted a little nicer truck with a great handling suspension and of course ls drivetrain. The truck as I bought from a friend . He has already put rockers in and started shaving the firewall .
Got my ride tech front adjustable coilover suspension. Installing a high hump tunnel . Truck will have a built t56. Cut holes in crossmember and welded in 4" pipe to rout exhaust through. Welded up my trailing arms Got a factory core support with the truck that was in pretty good shape with the exception of minor rust on the bottom so I made some patch panels and welded them in. Got some in rail notches and started fitting them in lastnight. On the way I have a complete new bed 18x10 wheels front and rear , my t56, and I pick up a 2004 ls1 on Tuesday. I've got started on my engine wiring harnes. This is just a mock up motor. I'll be running this holley intake with a adapter I made to run the t.b. vertical using a round carb style air filter assembly. |
11-07-2014, 12:50 PM | #2 |
Re: 69 pro touring/ autocross.
11-07-2014, 01:35 PM | #3 |
11-07-2014, 01:56 PM | #4 |
Subscribed, will be keeping an eye on this. We have similar plans and are in about the same stage of the build.
11-07-2014, 05:19 PM | #5 |
Cool idea with the throttle body, never seen that done. Hope it will clear your hood...Looking good.
Brannon Yazell 67' C10 mated w/ a 01' Silverado, extreme custom 2015 Chevy 2500 Z71 LTZ Crew Cab MSA, Motorsports Authority, Rigid Industries, Magnaflow, Michigan Metal Works, Raceline, BASF, Street Trucks http://67-72chevytrucks.com/vboard/s...d.php?t=624964 |
11-07-2014, 07:17 PM | #6 |
I'm in on this
11-07-2014, 08:11 PM | #7 |
11-09-2014, 07:49 PM | #8 |
11-15-2014, 04:18 PM | #9 |
Got a little work done this morning. Made a trans x-member and got my headers test fitted. Also this week I picked up my motor. It's not in aby pictures but it's a 2004 ls1 go block that was built by a local well known engine builder Gary Grimes aka Grimes twister engines. It has roll master adjustable timing set crane cam , arp throughout , can't Remer brand but also aftermarket pistons and rings.
also made some coil relocation brackets. |
11-15-2014, 04:36 PM | #10 |
I am doing this also and bought a small section of pipe to use. It 1/8 in thick but it looks like you used something a bit thicker. Do you think 1/8 will work?
Mike 1971 C10 350 1969 C20 396 1979 Corvette L-82 |
11-15-2014, 04:59 PM | #11 |
I'm sure 1/8 would be fine. This is just what I had.
11-16-2014, 06:45 PM | #12 |
11-16-2014, 06:55 PM | #13 |
Cruzzzn' Vet
Nice buildup, I would go with stouter trailing arms
11-16-2014, 06:59 PM | #14 |
Nice build. Going to tag along.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
11-18-2014, 01:10 PM | #15 |
11-18-2014, 06:18 PM | #16 |
What tranny are u using
68 |
11-18-2014, 07:36 PM | #17 |
T56
11-18-2014, 07:44 PM | #18 |
Great build! All the parts we sell... Nice to see this combo being done, great job!
Keep the pics coming! MCB
MCB - Matt's Classic Bowties 5360 Gateway Plaza Dr. Benicia, Ca. 94510 925-828-5555 www.mcbparts.com Email: forums@mcbparts.com Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts Hours: Monday to Friday 8am - 4pm Pacific We ALWAYS enjoy talking to our customers! We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking! |
11-18-2014, 11:07 PM | #19 |
What headers are you running?
11-19-2014, 08:00 AM | #20 |
They are from Gibson. They come in stainless or ceramic coated. I'm very pleased with the quality. I am using an abnormal motor mount setup for these trucks so I can't vouch how they would fit in most other situations. The headers are made for our trucks though.
11-19-2014, 08:26 AM | #21 |
Nice looking start. I'm in.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
11-19-2014, 10:52 AM | #22 |
Boosted Member
Cool build.
Not sure if it will be an issue, but I built a trans crossmember for a LS swap G-body a few years ago, similar to what you've built, and the "channel" section of it where the exhaust passes under just didn't have enough strength for my liking. Seemed stout on the weld bench, but with the weight of the trans on it, it had to much flex. Not sure if that will be a problem with yours or not, since yours appears to be quite a bit wider and gussetted nicely, but something to be on the watch for.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
11-19-2014, 11:53 AM | #23 |
I've thought about that. I might add some more gussets under the exhaust arches to add some strength. Thanks for the input.
11-19-2014, 03:45 PM | #24 |
Are you planning to use coilovers front and rear, or are you going to use just a spring and shock combo in the back?
Can't wait to see the 18x10 square setup, I have been trying to figure out what I want to go with. |
11-19-2014, 04:03 PM | #25 |
Just coilover in front. With rear drop springs. Gonna mount rear shocks outboard of frame. Wheels should be here next week hopefully.
