08-22-2023, 04:39 PM | #1 |
Re: I am from the Desert
I have a strong feeling we may be related, cause' that sounds like something I've said at least a few times in my life.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
08-24-2023, 08:42 PM | #2 |
today we put the grill on,, hood hinges and hood had the cowl on but removed it ....GAPS and adjusting the hood my Cousin doing a hinge ( body and fender guy all his life then managed a fairly big dealership body shop) He and I struggled with the hood latch and gaps put it all together and took it apart He is OCD like the rest of us ( you didn't think I could do all of this alone and called it a day... will get back at it Monday and get as close as we can at least as good as the GENERAL did back in the day...progress...
PS I will tuck the harness behind the fender ....some day
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
08-27-2023, 09:01 PM | #3 |
closer but no cigar.... sent the buddy buckets back to upholster to much foam .... mocked up the C H E V R O L E T hood needs to go back to paint for a re doo bumper showed up with a scratch and a dimple from UPS box damaged in the same spot as the ding.........patients .....patients
09-02-2023, 09:23 PM | #4 |
snuck in a little interior work
09-02-2023, 09:34 PM | #5 |
two shows here Labor Day weekend one 5 minutes from the house Lead East 50s show last night and another a half hour Dead Mans Curve spent the day there I guess over 2000 cars truck etc.
09-02-2023, 10:36 PM | #6 |
You're so close to being done man! That 56 Chevy is gorgeous.
09-03-2023, 08:05 PM | #7 | |
I have to travel be back this Friday and hit the body shop get them moving on the bed
09-24-2023, 09:22 PM | #8 |
bumper and headlight bezels installed hood going back to body shop
10-10-2023, 08:10 PM | #9 |
finally got my buddies back ...put them in temp good fit now, he took about 3 inches of foam out tapered the backs my head not touching the roof and belly room too ...had to take her around the hood no tags no lights
10-11-2023, 06:54 AM | #10 |
Looking great! That's one funky shift lever. Looks like it's made to fit perfectly around a bench seat.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
10-11-2023, 04:37 PM | #11 |
Late to this thread, but man, your work is awesome!
1987 V20 farm-hand rescue 1998 C2500 lot-rot rescue |
10-11-2023, 08:03 PM | #12 |
thanks Shifty for the kind words ....sometimes i think its OCD other times its just plain rewarding when you get it the way you visioned
10-16-2023, 09:35 AM | #13 |
Nice work, great color combination coming together nicely
Keep the pictures coming it entertained me
10-17-2023, 09:20 PM | #14 |
thanks Jim
10-11-2023, 07:59 PM | #15 |
you are spot on when the buddy bucket is mounted properly its almost like a bench Hurst is nice enough to make them to get around benches
10-19-2023, 09:12 PM | #16 |
got lights......
10-24-2023, 09:21 PM | #17 |
small steps cab light visors rearview
10-28-2023, 10:09 PM | #18 |
carpet day
10-29-2023, 10:16 AM | #19 |
Did you make your own powder coating system?
10-29-2023, 08:50 PM | #20 |
Nice work as usual, jess
10-29-2023, 08:54 PM | #21 |
10-29-2023, 08:53 PM | #22 |
use Eastwood powder coating gun and their powders ... a residential used electric oven ....I have a blast cabinet from harbor freight .....prep like everything else is most important I set them up with wire hangers on the oven grill shelves apply the powder bake @ 400 for 20 mins and usually I have a nice finish here pictured mirror brackets and outer steering shaft I coated with EXTREME CHROME powder ...one of my favorites ...limited to size of parts you can coat by the size of your oven .... a few years ago I made an oven with electric hot plates and round 10 inch forced hot air duct for long slim parts like cross members center lines etc. just having fun ....its faster more durable and a lot less clean up than painting
10-30-2023, 09:50 AM | #23 |
Active Member
Looking good!
Scott 1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
10-30-2023, 09:40 PM | #24 |
11-13-2023, 09:21 PM | #25 |
double pulley installed no more belt noise
