Blood Sweat and Tears.. 67 Build Thread
Ok, here we go...
I just started on the tear down today a little bit by going straight to some spots on the body that I knew was already worked over the wrong way. I just didnt know how wrong it was until I broke out the grinder... I have never seen so much bondo in my life... The front roll pan was a home made deal using extremely thin sheet metal and TONS of bondo. The tailgate was smoothed (I use the term loosely) with the same thin sheet metal and bondo, but is going in the book as a lost cause after pulling the sheet off from the inside that was covering some bad cancer. I decided to not even waste my time on the out side knowing it is probably just as bad. Stay tuned for more of the tear down...
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
Re: Blood Sweat and Tears.. 67 Build Thread
Pulling the front clip off tonight and hit a brick wall with the wiper arms... of all things lol
I sure would like to have a word with the wiper arm engineer guy from back then right about now. Any suggestions on how to not mangle them trying to pry them off while dealing with the clip?
![]() Join Date: May 2013
Good luck with your build. The truck looks good, but I guess looks can be a bit deceiving. Glad you're willing to do it right.
Rich J. 1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD ![]() 2002 Chevy Tahoe 4X4 5.3L SOLD 2015 Chevy Silverado Crew 4X4 5.3L |
Thanks man. It is incredibly solid. All the bondo Ive removed was only covering dents. I only had one bolt in the front clip that wont come out and its the lower front fender bolt by the rocker panel
The wiper arm should have a small tab on the bottom at the splined shaft. Pull it out lightly with a screwdriver or hook tool and then work the arm off the shaft. Sometimes they can just be gently pried off (most of the tension is from the spring inside the arm holding the arm to the windshield).
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
#6 | |
Little bummed to find out I dont have a 4 bolt main and its from a 85 to 94 truck... I knew it was newer because of the metric bolts hear and there. Oh well.
Any way, the front clip is off and I see it has been in a bit of a wreck at some point.. the right front fender is from a 68 and the radiator support is bent up a bit on that side.. the deflector is bent up as well. The frame horns look to be straight though so thats some good news... I should be able to go get the Vette suspension this weekend and maybe order a few other parts. I have a couple friends that collect 67 c10s, blazers, and burbs that I can get some stuff off of. they get all their parts from the Mid-West and anything I get from them should be rot free. I know they have a core support so thats a start. Ill be selling some stock stuff like the hood and front suspension with cross member as I pull it off and also have a sweet like new bench seat thats comfy as hell Ill sell too. More updates coming soon.
Whats a short bed weigh? Just the bed... Anyone know?
Looked like a real nice truck to start with. Amazing what paint can hide. Still looks like a good start. I'm not sure of the bed weight but I remove and install mine with an engine hoist and two yellow ratchet straps cris crossed.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
Thanks. It really only has a few spots that need re-worked on the body. There is no patching of any rust on it it needs. Right front fender and the core support and driver side cab corner and tailgate is all I will have to patch or replace. Left side bed rear corner had a few small dents that need more metal work and less bondo. The wiring needs replaced because of dry rot and crispy wires but Should be a pretty easy build. The suspension is the only Real challenge.
Nice start! Man when my truck started i NEVER expected to find so much rust. But shes rust free now
1970 K20 1967 Blown Stepside 2016 Chevy 2500 Duramax 1989 Jeep Cherokee 1995 S-10 2014 Infinity Q-50 AWD 1970 Chevy K20 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=634164 1967 stepside rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=684913 Shop build http://www.garagejournal.com/forum/s...d.php?t=225559 |
#12 | |
Pulling the bed off in a little bit when help gets here and Ill post some more pics of the tear down.
More pics of the tear down showing some things that need attention...
Still looking good all in all... I have no idea what that big chunk of the frame was torched out for? You can get a good look at how NOT to lower a truck by the way the coils are collapsed. SMH.... do NOT heat coil springs!
THAT was quick..lol. You defiantly got a nice project.
#15 |
This is gonna look so nice... and its only gonna cost me a kidney and a testicle...
#16 |
![]() Join Date: Nov 2010
Subscribed. I'm not far from you. Seems as though we are going to be going through a bit of a resto. You got a little head start. I'm almost afraid to even begin. I'll be watchin ya.
#17 |
Im in for the rest of your build .
#18 |
Just remembered I did this video as my "before" video... Im regretting not doing a massive burnout video now though...
https://www.youtube.com/watch?v=chPpoyFtQuw
#19 |
Nice. Wish I had a fleetside sometimes.
#20 |
I was off today and couldnt just sit around... so i went out and started stripping.. the old fashioned way.
Got a pretty good start. The fender is only held on with 2 bolts as I wanted to see how it matched up to the door with no filler or a gazillion layers of paint... undecided on trying to save the other fender or replace it. Its a 68 fender with a horrible patch job over the side light hole. Need something smaller to get in the low areas on back of the cab.. With any luck Ill have it down to metal all around the outside next weekend and will only have to blast the inner and under stuff, and door jams and what not and then once I pull all the glass and handles Ill clean those areas up, but for now its a start..
#21 |
Considering where you are from your truck is very solid ,I love seeing your progress .
#22 |
I bought it from Auburn Alabama and had it shipped home this past summer.. Its been a southern truck all its life. Seen it on Ebay one night at around 1am right after it was posted while I was on the road and figure since its easier to ask for forgiveness than to ask permission... I hit the buy now button lol
#23 |
That explains a lot .
#24 |
Damn....got quite a bit done.
#25 |
Well I guess thats what I get for buying stuff when Ive been drinking... I got the gauge carrier this morning and its made from ABS Plastic... not CF at all!
![]() How can someone justify selling a thin plastic part for 140 bucks?? Im not even sure it will hold the weight of the gauges without warping in the heat of summer... ![]()
