12-02-2014, 04:09 PM | #2 |
I'm just glad to be here!
Re: 1987 Fuel Sender Conversion for LSx Swap
First step in the conversion is to modify the tubes on the top of the sender for the -6 AN adapter fittings. The small bulge on the end of the 3/8" line and the 5/16" line need to be removed.
Cut them off as close to the bulge as possible, but the OD of the line must not be enlarged or the fitting's ferrule will not fit correctly. Deburr both the inside and outside of the lines once they are cut off. Here is the Jeg's Fitting (for the 3/8" line) taken apart. Slide the red part of the fitting over the end of the 3/8" line followed by the brass ferrule. Screw the blue part of the fitting into the red part and tighten per mfg's directions to crushe the ferrule and make the seal on the tube. Here is the assembled fitting on the sender: Now, repeat for the 5/16" line. The Earl's fitting is a little different shape on the tube end, I needed to bend the support tab on the top of the sender down off the tube before putting on the fitting. Once the fitting was on and tight, I bent the support back up and around the tube. Here is the completed fittings on the top of the sender: Leave the center tube (1/4" diameter) alone. Use a regular hose and hose clamp to route a vent tube up and out of the way on this tube of the sender.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
Tags |
fuel pump, fuel system, lsx, swap |
