Old 01-08-2015, 09:48 PM   #1
DLTruck1973
1971 K20 parts F/S
Jan 6 at 5:10 PM
First thanks for looking. DLTruck1973 is a combined effort between myself "tll74" and "TBONE1964" both certainly no strangers to this site. I (Tom) have bought out my family of our family owned business D & L Truck Parts very recently. We will be offering parts from all of our Chevy/GMC trucks. I personally have a stock pile of 67-72 trucks that we will be listing as they get parted out plus many loose parts from many past trucks. Thomas aka "TBONE1964" will be handling the listing and selling of the parts. I have been selling parts for years here on the site but have been struggling finding time and keeping up with request from members. This combined effort hopefully will resolve that problem. It's our hope and wish that we can provide excellent service and parts to you fellow truck enthusiasts.
To avoid possible confusion, we ask that you try to respond in the thread(s) for parts listed with in the thread.
Shipping via UPS, USPS, and freight truck.
Payment via Paypal, MO, and cards over phone.
This thread shares common parts for K20 Pickups and Suburbans. Note: these parts were removed from a Suburban. There will be a separate thread posted with Suburban parts only very soon. Some parts may not be in the photos but available.
Photo 1
Hood latch...15.00
Hood latch striker...10.00
Grill support center...10.00
Grill support left...10.00
Fender/Radiator support "triangles"...7.50
Park light lenses...12.50 each
Washer hoses with firewall pass through grommet...12.50
Upper radiator hose pipe (best one I've had or seen)...85.00 SOLD
Emergency brake cables (front cable, interm.cable, frame brackets, support rods, and couplers)...75.00 SOLD
Front cross member...25.00
Left and right brake calipers...25.00 each
Fan spacer...7.50 SOLD
Front bumper brackets 71-72 4x4 only...22.50 each SOLD
Steering shaft (intermediate)...25.00
Wiper transmissions...12.50 each
Brake line set (front 4x4 only)...40.00
Inspection cover...15.00
Tin flywheel cover typical split at top starter hole...10.00
Bell crank with pivot stud on block, frame bracket, rod to fork...30.00
Gas peddle assembly 71-72...28.00 SOLD
Master cylinder with proportioning valve...30.00 SOLD
Flywheel...25.00
Front stabilizer shock with mounting hardware (aftermarket) shock probably wore out....12.50
Engine cross member been tanked and acid dipped nice...75.00 SOLD
Transmission cross member...65.00
Body mount brackets / all...
Front spring hangers/core support mounts...40.00 each $75.00 for a pair
Front axle bump stops bumpers with brackets...10.00 each
Front spring shackles...12.50 each
Photo 2
Front axle shaft LH 71-early 72(small u-joint) needs u-joint, some wear on pocket bearing surface... 60.00
Front axle shaft RH 71-early 72 (small u-joint) nice...75.00
Engine mounts...5.00 each SOLD
Transmission/transfer case mounts (mounts on cross member) original and complete...45.00
Front spring rear hangers for shackles...20.00 each
Front leaf springs pair...125.00
Door hinges, front doors and rear door...
Front upper shock brackets...5.00 each
Rear drive shaft some play in splines...75.00
Rear axle bump stops with brackets...12.50 each
Rear spring hangers (front)...30.00 each
Photo 3
Windshield rubber and trim ding in trim RH lower corner nice otherwise...65.00
Rear HO72 differential housing tanked still original factory markings...125.00
Rear differential housing cover...22.00 SOLD
Floor hump 4sp/t-case...30.00 SOLD
Park brake assembly...22.50
TH350 4x4 shift linkage complete... 50.00
Door relay RH...10.00
Speedometer cable 4x4 ...25.00
Blower motor...15.00
Alternator bracket set...40.00
Washer bottle bracket...5.00
Upper trim for door panels...10.00 each
Inside mirror hazy glass otherwise very nice...20.00
Outside (2) RH door handles average DQ, one pitted other kinda dull...20.00 each
Window cranks...7.50 each
Door release handles...7.50 each
Lower side vents with handles and knobs...22.50 each SOLD PASS SIDE
Wiper motor very nice paint...25.00
Under dash wiring harness 4sp/gauges very nice...65.00
Front light harness 71-72 one wire spliced...40.00
Front RH park light housing...10.00
Engine harness (for manual trans) bad ends on starter and temp... 20.00
Brake/Clutch pedal bracket assy...40.00
Steering Column...65.00 (SOLD)
Defrost vents...10.00 each SOLD
DLTruck1973 is offline   Reply With Quote
Old 01-08-2015, 09:53 PM   #2
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: 1971 K20 parts F/S
condition of steering column and shipping cost to 21801 business. Also verify it is a floor shift column.
Richard
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is online now   Reply With Quote
Old 01-08-2015, 09:57 PM   #3
teeitup
Just like to part out trucks!!
teeitup's Avatar
CONGRATS Tom and Tom!!!!!!!!!!!!!! You guys will do awesome together!!!!!!!
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 01-08-2015, 10:15 PM   #4
undertaker72
undertaker72's Avatar
depending on postage or freight, and a pic of
4 speed transhper trans cover 30.00
id like that the front crosmember ,75.00-- does it have upper and lower pieces
and the mt mounts 5.00 each
my zip 84648
undertaker72 is offline   Reply With Quote
Old 01-08-2015, 10:21 PM   #5
DLTruck1973
Richard
Richard,
the column is for a floor shift and it is real nice for a driver. I can get you a price shipped tomorrow.
Thank you,
Thomas
Old 01-08-2015, 10:23 PM   #6
DLTruck1973
Thank you Randy,
That means a lot coming from you. The master is teaching me well
Take care,
Thomas
Old 01-08-2015, 10:30 PM   #7
DLTruck1973
my zip 84648
I can get you a shipping quote tomorrow. When you say "front crossmember" you are asking for the engine crossmember correct? Yes it will come complete.
Thank you,
Thomas
Old 01-08-2015, 10:50 PM   #8
undertaker72
Thank you,
Thomas
correct
Old 01-09-2015, 01:28 AM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Condition/shipped cost to 59901 of the master cylinder, prop valve, and MC to prop valve lines - mostly need the lines but will consider whole package. Thanks,
Old 01-09-2015, 06:54 AM   #10
1972 Jimmy
1972 Jimmy's Avatar
I'll take the front 4x4 bumper brackets and upper radiator tube for a 1972!
Thanks,
Eric
1972 Jimmy is offline   Reply With Quote
Old 01-09-2015, 07:51 AM   #11
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Does the HO72 cover come with good drain plug? Ill take it pending info...
And the fan spacer, can you measure, Ill take it pending info...
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 01-09-2015, 09:44 AM   #12
Minnz
Minnz's Avatar
I'll take the passenger side Lower side vent with handle and knob. My zip is 55443.
Thanks!
Lee
72 Ochre Blazer
69 Camaro Z28 Garnet Red
48 Willys (rolled)
Minnz is offline   Reply With Quote
Old 01-09-2015, 10:03 AM   #13
DaHos
DaHos's Avatar
What is there for hubs/lockouts?
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 01-09-2015, 10:26 AM   #14
CUSTOM/10
CUSTOM/10's Avatar
I've had nothing but great experience dealing with Tom ( tll74 ) Good parts at good prices !!!!!
You guys partnered together should be awesome !!!!
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 01-09-2015, 01:17 PM   #15
undertaker72
in photo 4 im interested in oil fill tube extension , need price ,add to my stack
Old 01-09-2015, 01:26 PM   #16
DLTruck1973
The drain plug on this cover is in excellent condition, no rounded corners. The fan spacer is 1 1/2 thick and 1 1/2 inch bolt center.
Let me know,
Thank you,
Thomas
Old 01-09-2015, 02:56 PM   #17
DLTruck1973
Richard,
Thank you,
Thomas
Richard,
With shipping, the column will be $93.00.
Let me know,
Thank you,
Thomas
Old 01-09-2015, 03:01 PM   #18
DLTruck1973
The fill tube extension is $25.00. It has a very nice valve cover grommet. $20.00 without the grommet. The fill tube is in excellent condition.
With your other parts above, the total for everything on your list with shipping is $182.00.
Let me know and I will get everything ready to ship.
Thank you,
Thomas
Old 01-09-2015, 03:04 PM   #19
DLTruck1973
Hi Pete,
I can sell you the proportioning valve with the two short lines. I would rather not split the lines from the valve. The master has no real value so the price is still $30.00. I can ship without the master for $10.00 for a total of $40.00.
Let me know and I can get them ready to ship
Thank you,
Thomas
Old 01-09-2015, 03:06 PM   #20
DLTruck1973
Thanks!
Lee
I can get this to you in a flat rate envelope, padded well for $27.75 shipped.
Let me know,
Thank you,
Thomas
Old 01-09-2015, 03:24 PM   #21
Minnz
Minnz's Avatar
Thomas,
Sounds good for the lower side vent. Please PM me your PayPal contact.
Thanks!
72 Ochre Blazer
48 Willys (rolled)
Old 01-09-2015, 03:27 PM   #22
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Hi Pete,
Thank you,
Thomas
Thanks Tom - I'll take the prop valve and lines if all looks to be good. Will send you a PM now re: payment. Pete
Old 01-09-2015, 03:52 PM   #23
undertaker72
I will need your payment info , is this price with tube and grommet,
thanks kevin
Old 01-09-2015, 04:02 PM   #24
DLTruck1973
thanks kevin
Kevin,
Price of the fill tube is $25.00 if you want the valve cover grommet with it or $20.00 without the grommet.
I will PM you paypal information.
Thank you,
Thomas
Old 01-09-2015, 04:05 PM   #25
Minnz
Minnz's Avatar
Payment Sent for Passenger side vent & Handle.
Thanks!
Lee
Let me know,
Thank you,
Thomas
72 Ochre Blazer
48 Willys (rolled)
