01-29-2015, 12:28 AM | #1 |
Left over parts
Here is some left over half way trough my build and parts I've accumulated over the years and hope somebody has a use for them. First I'll take it posted gets dibs. Note prices don't included shipping. Can get shipping quotes within a few days. Pm for PayPal and ?'s Thanks Curt
-Driver vent wing window good tinted glass and really nice chrome (rubber is cracked) $50 -Oil gauge $10 (SOLD) -Amp gauge $10 (SOLD) -Temp gauge $10 (SOLD) -Sun tach $10 (SOLD) -Windshield washer pump plastic cover $Free + shipping (2) gauge parts (backing plates for lower gauges) $free + shipping (SOLD) -Chrome glove box w/ Cheyenne stainless wood grain insert and 72' Cheyenne super emblem $40 (SOLD) -Delco remy voltage regulator w/ 4 prong wire connector clip (not broken) $10 (SOLD) -(2) Cargo lights $10 each one has switch (1- (SOLD) -New turn signal switch non-tilt with hazard button $30 -71' Intake manifold w/ gasket set $30gm 346250 -T-stat housing $10 (SOLD) -Valve covers w/ (8)long hold downs $20 (SOLD) -(8) short valve cover hold down washers $5 (SOLD) -Set spark plug heat shields $10 (SOLD) -Distributor hold down $free+ shipping (SOLD) -Quadra jet complete (will need cleaned and tuned) $50(SOLD) -(2) Chokes (heat rise) $5 each (SOLd) -Oil filler tube w/ cap $10 (SOLD) -(6) Exhaust manifold tensioners w/bolts $5 (SOLD) -Transmission kick down carb (q-jet) and manifold bracket $20(SOLD) -Kick down manifold bracket $5 -Small block chrome oil dip stick and tube (new) $10 -Turbo automatic transmission crossmember $35 -Spare tire crossmember $20 (SOLD) -Small block engine towers w/ hardware $25 (SOLD) -Rear shock mounts upper and lowers (great shape) $30 -Grill center support 71'-72' $10 (SOLD) -71' Tow loops? $10 -Condenser w/ dryer and lines $40 (SOLD) -Compressor (clutch is good) $ 40 priced to help on shipping (SOLD) -Compressor to evaporator lines $25 (SOLD) -Drier to evap line $5 (SOLD) -Vacuum accumulator cowl shut off valve $10 (SOLD) -Vacuum tank $5 (SOLD) -Small block compressor brackets (all brackets but 90 degree bracket on -manifold, some hardware but not all)$75 (SOLD) Trim Upper 69'-72 -Short bed right and left really nice $50 for pair (SOLD) -Doors left and right $25 for pair (SOLD) -Cab left and right $10 for pair (SOLD) -Fenders (2) sets one pair really nice $40 (SOLD) -one pair driver quality with holes at back of fenders $10 Lowers w/ wood grain 71'-72' -Short box set really nice driver needs wood grain $70 (SOLD) -(2) driver rear fender $5 each -(1) passenger front fender cup $5 -Cab rear left and right $10 for pair -Rear big window set (bottom is beat but top left and right are save able, have corners but no center joint) $15 -New saddle dash pad $45 (never installed) (SOLD) -Blue visors pair (driver quality) $20 Last edited by Curtb1971; 03-08-2015 at 02:16 PM. Reason: Sold stuff |
01-29-2015, 12:38 AM | #2 |
Re: Left over parts
I'll take voltage regulator. Also oil gauge with backing plate and one cargo light if all are original. Pics of cargo light and shipping to Nashvile please 37027
01-29-2015, 12:39 AM | #3 |
Re: Left over parts
ill take that Cheyenne glove box door
01-29-2015, 12:39 AM | #4 |
Re: Left over parts
Also is the dash pad a cover or a actual foam dash?
01-29-2015, 12:44 AM | #5 |
Re: Left over parts
I'll take the spark plug heat shields and the chokes. Shipping quote to 84043.
Thanks, Paul |
01-29-2015, 12:45 AM | #6 |
Re: Left over parts
01-29-2015, 12:46 AM | #7 |
Re: Left over parts
in line for dash pad
01-29-2015, 12:46 AM | #8 |
Re: Left over parts
I'll take the dash pad assembly
01-29-2015, 12:54 AM | #9 |
Re: Left over parts
i will take the door vent wing assy let me know what shipping cost is
01-29-2015, 12:58 AM | #10 |
Re: Left over parts
i will pass on the door vent wing it looked like a 1967 style sorry
01-29-2015, 01:03 AM | #11 |
Re: Left over parts
I'll take the dash pad in addition to the items listed in y first post. Don't need pic of cargo light. I'm good with the ones in your posting
01-29-2015, 01:16 AM | #12 |
Re: Left over parts
I'll take the upper short bed trim pair and I'll take the lower short bed trim set with wood grain
01-29-2015, 01:16 AM | #13 |
Re: Left over parts
I'll take all the A/C stuff.
01-29-2015, 01:22 AM | #14 |
Re: Left over parts
AND I'll take the grill center support
Thanks |
01-29-2015, 01:27 AM | #15 |
Re: Left over parts
I will take the spare tire holder. Just need size and weight and I can send fedex label for shipping.
01-29-2015, 02:02 AM | #16 |
Re: Left over parts
I'll go second on the spare tire crossmemeber
01-29-2015, 02:15 AM | #17 |
Re: Left over parts
How are all of the exhaust manifold tensioners? Are any of them broken or really rusty?
My dad always says that HEI distributers are pointless... •1972 Custom/10 Deluxe. My first truck and I've had it since I was 7. Tilt, tach, AM/FM, 350, deep dish rally's, original paint and an increasing amount of NOS jewelry. It's always taking my money.. •1967 c10 with tach, dropped 3/5 on deep dish rally's •1972 Cheyenne Super. Sold |
01-29-2015, 02:22 AM | #18 |
Re: Left over parts
01-29-2015, 02:26 AM | #19 |
Re: Left over parts
Cool thank you.
01-29-2015, 02:42 AM | #20 | |
Re: Left over parts
Just pulled them out and none are broken. Not an expert on these but the (4) at the top are one size and the (2) on the bottom are more u shaped the bottom right one is bent but not broken. There is defiantly surface rust but these should clean up nice with a light media blast and far as the bolts go some metal prep would clean them right up. Sorry the pics are bad (iPad) |
01-29-2015, 02:51 AM | #21 |
Re: Left over parts
Would you sell just the tensioners without the bolts? If so how much shipped to 97013?
01-29-2015, 09:42 AM | #22 |
Roadtrip!
Re: Left over parts
In line for the glovebox door.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
01-29-2015, 10:41 AM | #23 |
Re: Left over parts
I'll take the tow hooks pending the shipping quote to 14225
Thanks. |
01-29-2015, 10:53 AM | #24 |
Re: Left over parts
Ill take the sun tach and distributor hold down pending shipping to 37303
01-29-2015, 11:11 AM | #25 |
Re: Left over parts
I'll get inline for tach, and r the copper exhaust gaskets up for grabs?
thanks Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
