Wheel studs
I'm running the Boss 338 wheels on my c10 and the stock wheel suds are too short so I need longer ones.
I think my suspension is off a 72'. Size is 1/2-20. Anyone know what diameter of a stock wheel stud is for front and rear? Last edited by Vova; 02-06-2015 at 09:36 PM. |
Re: Wheel studs
Top
Re: Wheel studs
Hint: Remove one stud and measure it the press in end is the critical measurement here
![]() Join Date: Mar 2004
Re: Wheel studs
I have had guys mention to drill and upgrade to 7/16 if you are going to take the time to re-stud...
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
Re: Wheel studs
Old member
You can buy longer studs at NAPA are any other parts store. I have longer studs on the rear end because of the disc brakes I installed. 1/2 20 is the correct size though. I found this on google. It shows all the studs and wheel spec's.
![]() http://www.wheelsupport.com/chevrolet-gmc-bolt-pattern/
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Wheel studs
How much more threads do you need? Unless it's excessive you can use the long reach lug nuts that give an extra 5/16" of thread engagement, that's about 6 more threads. A lot easier then changing studs.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
Re: Wheel studs
7/16 isn't an upgrade from 1/2"
Re: Wheel studs
I had the same problem so I used wheel studs from a chevy Avalanche. They need to be slightly shaved right on top of the knurl but it worked. I had maybe 1/8 thread left to screw on the lug nuts. Now theres like half an inch
#10 | |
Re: Wheel studs
Currently the studs are about 1/2 way through lug nut. Having a hard time finding a 1/2-20 acorn deep reach. |
Re: Wheel studs
You need to have at least 1 thread past the nut. I buy the long reach at the local swap meet, Gorrilla lug nuts sells them on line but they are much higher priced then what I can get them for at the swap meet.
Re: Wheel studs
Page 6, 4 different styles to choose from in 1/2, they reach down .300"
http://www.gorilla-auto.com/lug-nuts-page-11
#13 | |
Re: Wheel studs
Re: Wheel studs
I pay about $.50 at the swap meet.
#15 |
Re: Wheel studs
#16 |
Re: Wheel studs
#17 |
Old member
Any good wheel store should have these lug nuts. Well at least around here they do. I have several places to buy them from. Custom wheels will require a long reach most of the time.
#18 |
Re: Wheel studs
guilty...I was backwards. oops
#19 |
Re: Wheel studs
I should have some at work, I can check when I go there. Just pay the USPS shipping, I think a small flat rate box is $5.25
Is the extra .300" (6 threads) going to give you what you need?
#20 |
Re: Wheel studs
#21 |
Re: Wheel studs
I have quite a few so PM me and just pay the USPS
