Fuel line recommendations
72 LWB LS swap tank behind axle and I Need recommendations how people have done the fuel lines? Braided stainless or solid line with short braided stainless at ends?
![]() Join Date: Nov 2007
Re: Fuel line recommendations
Ill be installing all braided stainless on mine in a couple of weeks
meowMEOWmeowMEOW
As much hard line as you can run, then braided hose for the final connections to moving parts.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Hard line steel,stainless or aluminum? 3/8? LWB or swb? How much?
Depending on where you live you might want to get PTFE lined hose for your braded stuff. Some of the additives in gas will eat through normal braded line.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
![]() Join Date: Sep 2005
I used the ptfe braided line for mine
The Older Generation
I used the newer NICOPP tubing (nickel+Copper+Iron) on one of my projects. Really easy to bend and it will not rust. I bought mine from this guy: http://www.ebay.com/itm/CNC625-3-8-C...3D141563486115 Best price I could find at the time. It bends really easy and flares easy with a regular double flaring tool. There are coated flare nuts available for it too. Some of the auto parts stores carry it but it is more $. I don't know how it would do with the AN6 tool. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 02-10-2015 at 11:24 PM. |
#8 | |
meowMEOWmeowMEOW
3/8 feed, 5/16 return if you need it. I can't tell you how much, that depends how you route it. Protip: buying a 20ft roll of 3/8 steel line is the dirt cheapest way to get it, and its very handy to keep around the extra, as you WILL mess up somewhere. Technically any of the hardlines will work, however if you plan on using the hardline-braided line AN tube adapters, you need to be careful with the softer options like the aluminum, or the very hard like stainless. Soft lines can get over-bitten by the fittings, and can chafe or puncture from repeated bending (which happens if you don't have properly designed braided/hose sections to absorb the movement). Stainless lines are harder than the ferrule in the fittings, and sometimes it means the fittings don't get a proper bit and seal on the line. This can cause a little leaking from the base of the fitting.
Boosted Member
I agree with brew in regards to the hard-line.
I ran braided from the sump to the pump and to the frame-rail. Then hardline up to the engine where I split it off in braided again to the back of the fuel rails. ![]() ![]()
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Wasted income ^^^ that is NICE ^^^
one set closer
Hey wasted income where did you get dose clap that holding the fuel line to the frame?
#12 | |
Boosted Member
I got the clamps from summit. http://www.summitracing.com/parts/sum-g1882/overview/
meowMEOWmeowMEOW
Whats the Y in the supply for? Nitrous enrichment?
Boosted Member
Reduced from single -10 to dual -8s to feed the fuel rails.
![]() I also did the return line in hard aluminum, up to the flex fuel sensor, then went braided back to the tank. ![]()
#15 |
meowMEOWmeowMEOW
Is there a flow advantage to doing it that way? I've looked at a few aftermarket rails setups for if I switch my intake off, but I usually see it fed from PS and then to a crossover, with the other rear port being a return.
Where does your return exit the rail?
#16 |
one set closer
Wow didn't pay attention to that thanks for the web site and hope you got that taking of LOL hehehehe
#17 | |
Boosted Member
This is also how Aeromotive officially states that a dual fuel rail, return style fuel system should be plumbed. This is how it used to run. ![]() This is how it runs now. Hard line out of the rails to the regulator, then down to the frame rail. ![]()
#18 |
Hey wasted, I tried to pm you but you're at your max limit on messages
#19 |
The Waco Kid
You can check out what I did here: http://67-72chevytrucks.com/vboard/s...=585899&page=5
Posts 107-118, 145, & 154 |
#20 |
Boosted Member
Cleaned it out.
#21 |
Truck and auto performance nut
hows that new Holley hi-ram (that what they cal it?) intake working out for you? I've been eying that one for some time now.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#22 |
meowMEOWmeowMEOW
Not speaking for him, but I know a few people with it who LOVE the thing...IF you got hood clearance for it. Its one of the highest flowing intakes without going to a single plane and all that jazz.
#23 |
Boosted Member
Yea, it's working pretty good for me, and looks outstanding. I had planned on running the sandwiched A2W core from my bud Blake, but it wouldn't clear the doghouse on the firewall of these trucks. At least mine wouldn't.
#24 |
Anybody use this stuff yet http://www.speedwaymotors.com/Black-...6-AN,8976.html
I'm sure some of you have seen the parker push lok that sloppy mechanics uses but this actually says fuel line. I wonder if it is any good. Speedway says you can run alcohol and diesel through it too.
#25 |
