02-23-2015, 11:20 AM | #1 |
Re: Transmission temperature Gauge
NO, don't just tap into it, that would just ground the low reference circuit to the PCM. Take the M wire out and run a dedicated single wire between there and pin 41. The pins in the trans connector and the PCM are the same, so if you have two extra ones, they will work in either connector.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-23-2015, 11:34 AM | #2 |
Old member
Well that maybe harder than I thought. I don't have the wires to do that. What do I do with the wire coming out of the trans connector now if I take it out of the connection?
M- is a ground so what difference would it make if I just tap off of it?
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-23-2015, 12:00 PM | #3 |
Sounds like you found your transposition!
02-23-2015, 12:04 PM | #4 |
Old member
So what do I need to do to get it right? Change it to 41 are tap off 53 over to 41... what?
02-23-2015, 12:15 PM | #5 |
If you are positive #53 = goes to the Black "M" on the trans plug remove 53 black from the ECU connector and place it in the #41, test with VOM from pin side of trans plug "M" to #41 Is #53 location on the ECU even in use, pressure in tank, do you even need that?
02-23-2015, 12:25 PM | #6 | |
Old member
I ran continuity checks on both wires. 51 which is yellow TFT senor wire. Checked good. I checked "M" as well to blue connection at 53. It was good. Next question how do I get the connector apart from ECU 53?
02-23-2015, 01:15 PM | #7 |
Old member
ls1nova71,solidaxel
Thank you both. I got it working. I hooked it back up and nothing. Had to reprogram the Scan Gauge. I had programed it last for the Allison transmission just to see if it would work. Per tech support at S/G, all is good! I have a reading. I'll take it for a drive later and see how it does. I have to put the glove box back in now. I'm so happy!
02-23-2015, 01:57 PM | #8 |
............... You did all the work !!
02-23-2015, 02:30 PM | #9 |
Old member
Yea but you both directed it!
02-23-2015, 03:08 PM | #10 |
What about me, it was my suggestion...............JK...glad you got it working.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-23-2015, 03:56 PM | #11 | |
Old member
That why I love this board it the people are willing o help each other.
01-29-2016, 11:50 PM | #12 |
But Found Her 25yrs Later!
I did a google search about using a water temperature gauge for the transmission fluid temperature gauge, and many say it'll work.
01-30-2016, 09:09 AM | #13 | |
Old member
I fixed this problem with my wiring harness. I bought a scan gauge 2 scan tool which hooks straight into the ECU and you can use it as gauges. Mine wasn't picking up the trans temp, and after several month's over a years worth I got to the problem which was a ground issue in my wiring harness. All is good now. Yes a water and trans gauge work on the same idea so they should work for either system.
05-08-2016, 08:01 PM | #14 |
I am going to attempt to revive this post, I am having the same problem. Except I am using a blue tooth obdii adapter and the app called torque.
I verified that the pins on the transmission plug go to the correct plug at the computer with continuity. When i open the torque app everything is good except the trans fluid temp? |
05-08-2016, 08:17 PM | #15 | |
In Torque, Go to Settings > Manage extra PID's/Sensors > GM and then find the transmission Fluid Temp options. There are two. I can't remember which one I used, but you may have to try them both. Good luck!
Matt Criswell - Lyman, SC 1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE |
05-08-2016, 11:45 PM | #16 |
meowMEOWmeowMEOW
If you do a little creative google-fu, you can find the complete list of GM PID's. Its not a single published document, but between the available stuff from AllData, AeroForce, and GM's own tech, they are all out there for your consumption.
*fwiw, there are also a ton of PID's you'll never use, which can be used for fun things if your willing to experiment.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
05-09-2016, 12:00 AM | #17 |
meowMEOWmeowMEOW
Ok I dug around in my PDF collection and found some stuff I downloaded a while ago.
Most companies (whether "GM" or not) used something called SAE J1850, which is just a title for an industry-accepted standard for hex-based language protocol for controlling ECM, TCM and BCM functions. Basically, when everyone "agreed" on OBDII being the standard, they also "agreed" on a basic language to be used for programming and error coding. (DTC codes for Errors, PID's for sensor function channels). Its a hex based language, so numbers 10 numbers (0-9, with 0 being considered a number), and A-F, being used in combinations. Those combinations (called strings) are usually affixed or prefixed with a 1 or a 0 to denote On/Off or Open/Closed. Manufacturers can use strings that aren't reserved called Enhanced or Extended PID to control brand-specific or special equipment goodies. This is what most manufacturers used, or used as a base up until CANBUS/GMLAN/CANII overtook it by the late 2000's. Here's the list of GM specific PID's for the pre-canbus era. They have the others as well if you navigate the page. http://www.scangauge.com/support/x-gauge/gm-specific/
05-11-2016, 08:42 AM | #18 |
Old member
Driving mine I have noticed the Trans temp will read higher than the water temp. Not hot but a few *'s higher sometimes even though they are both below 185*.
My water temp most of the time is 179* with no fans. Some times the trans temp will read 182-183. Just something I have noticed. I have both coolers hooked up. Anybody else noticed this?
05-11-2016, 11:49 AM | #19 | |
05-11-2016, 07:02 PM | #20 |
Old member
Per most people it's plumbed before the radiator so in the winter it heats up a little before going into the transmission.
These are readings straight off the ECU through the scan gauge 2 monitor not mechanical gauges. I have the trans cooler in between the condenser and radiator. I've never seen it more than 200 and that was last spring on a trip to the mountains. It always cooled right back down after pulling a long grade. Normally it's in the 165-185 temp range. Depending on how hot it is outside.
