Old 02-27-2015, 01:50 AM   #1
Rod Run
Rod Run's Avatar
Exclamation 1971 rear e-brake parts help PLEASE!!
I've been lucky on this forum with getting lots of great info, but I don't know about this one.
I just bought new rear e-brake cables and went to put them in. I've been searching the forum (not to mention Google too) for the last two days trying to find good detail pics, only to realize that my project truck is missing all the e-brake parts inside the drums.
After searching much more, it looks like I need the parking brake lever (that the cable connects to), the pin and clip that hold that part in, the spreader bar (or strut) and the spring that goes on one end of that.
I can't find any links or information about where to buy this stuff. It seems like it's all dead-ends, when trying to get these types of parts?
I'm located in Massachusetts, so parts trucks aren't really available in junkyards around here, so that's not an option for me. Even if we did have them in the area, we're still buried under about 4 feet of snow here, so it still wouldn't work
I'm really hoping someone on here knows of a source where to buy these parts? They make everything else for our trucks, so they must make these parts too..................... right?
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 02-27-2015, 01:56 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: 1971 rear e-brake parts help PLEASE!!
Your best bet would be to become a subscribing member and post a want to buy ad. Many guys here part out trucks and will most likely have what you need. Some of the parts you need are not available over the counter. You can get the parts from a junkyard from any truck up until 87 I believe, not just limited to 67-72 parts trucks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-27-2015, 02:26 AM   #3
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Exactly. Members and Forum Vendors first.
I'm not a big proponent of buying LMC parts. But, to make myself feel better because
I use their book (along with my other references), I buy a little from them.
Here's a page from their catalog that's easily available with a few clicks- or less.
But, I ALWAYS go with Forum Members or Vendors first, ECE because I know them and they are local
(and national and international) supporters of our sport.
But that's just me.
Anyway, here's the drawing...if it helps...
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 02-27-2015, 11:22 AM   #4
Rod Run
Rod Run's Avatar
But that's just me.
Thanks for the pic, but that's what I was using for reference anyway. they do sell the "spreader bar", but that's it.
I would use a recommended vendor if anyone knew who had the parts.
Old 02-27-2015, 11:24 AM   #5
Rod Run
Rod Run's Avatar
So it's pretty certain that no one makes these parts that I need?
Thanks for the info anyway, I appreciate it
Old 02-27-2015, 03:52 PM   #6
RenoKeene
Florida Edition
RenoKeene's Avatar
Most of the trucks being parted-out on the parts forum will have what you need. All you have to do is ask one of those guys.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 02-27-2015, 04:20 PM   #7
cdowns
cdowns's Avatar
most of those parts are readily available at your local auto parts storew in the help section
Old 02-27-2015, 09:19 PM   #8
El Dorado Jim
http://www.truckandcarshop.com/ I looked in my catalog and they don't carry the parts you need,but check out their site and order a catalog, I buy alot of my parts from them,good quality IMO....http://www.truckandcarshop.com/
El Dorado Jim is offline   Reply With Quote
Old 02-27-2015, 09:54 PM   #9
magwakeenercew2jh
Okay...I pulled all that stuff from the one (pass) side of my rear drum in anticipation of going to a disk/disk e-brake system.
So, I think I have all of the parts from one side that I could dig out.
However, I KNOW that the spring on my lever (#6), pictured in shadow next to #6 in the drawing, was broken. So, if you are
looking at pulling some parts together from different sources, let me know and I'll tell you EXACTLY what I have. If you do it that way,
the ones I have will be yours for the asking.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 02-27-2015, 10:30 PM   #10
Rod Run
Rod Run's Avatar
Thanks for all the advice guys and magwakeenercew2jh, I'm sending you a PM
Old 02-27-2015, 11:29 PM   #11
Wrenchbender Ret
I have a whole set from a 61 or 62. I don't know if they would fit.
Wrenchbender Ret is offline   Reply With Quote
Old 02-28-2015, 11:11 AM   #12
cleanfreak
cleanfreak's Avatar
I have a full set also , but shipping would be lots. Listen to leddzepp , just about any 11" drum brake chevy will have the parts , all the way to the 2000's on 6 bolt chevy vans & 4x4 88-98's , 2wd 6 bolt 2500's 88-98, impala wagons thru 90... there's lots out there.
cleanfreak is offline   Reply With Quote
Old 02-28-2015, 11:23 AM   #13
Rod Run
Rod Run's Avatar
I appreciate all this info. You guys really are helpful
One question though. What is a 6 bolt?
Old 02-28-2015, 12:02 PM   #14
snipescastle2
snipescastle2's Avatar
Talking Re: 1971 rear e-brake parts help PLEASE!!
reffering to the number of lugs 6 bolt wheels/5 bolt wheels,etc.....
Ben
snipescastle2 is offline   Reply With Quote
Old 02-28-2015, 12:28 PM   #15
Rod Run
Rod Run's Avatar
Ben
Ahhh ... thanks
Old 02-28-2015, 03:29 PM   #16
magwakeenercew2jh
I dug through my stash and found this "strut". That's all.
You're welcome to it. But I don't think that would solve the problem.
No question that the best way to get this together is to wait out the weather and pull a couple of drums off a wreck. You have a wide range
of years that the stuff will work...You;'ll have to do the specific research on that...Easy enough to figure that out.
Here's an inexpensive set of springs that would help on the "replacing" of the parts you pull, if you chose to go that way.
http://tinyurl.com/mtlxpnu
Also, here is a pic from one of my service manuals. Pretty much the same general picture as we used before. I can't seem to find the internal
works on the rear drum in my assembly manual...But I can't seem to find *anything* in that when I need it.
As I said...I only have one strut. And, you're welcome to that if you need it. But, when you pull drums off of a wreck, each one will fall right out.
I'll keep looking on line for a kit. I may be wrong, but I think an all-inclusive kit with struts, springs, connectors, and parking brake levers might
not be out there. But there *are* MILLIONS of those parts out there for the picking.
Figure out the year spread, wait out the weather, and you'll have it licked.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 02-28-2015, 04:29 PM   #17
snipescastle2
I did a conversion to rear disc brakes, if I can find my hardware I removed I'd be happy to pay it forward......
Ben
Old 02-28-2015, 08:46 PM   #18
Rod Run
Rod Run's Avatar
Ben
Thanks Ben.
I opened this thread just as a way to try and get some info on how to find these parts, but EVERYONE in here has been more than helpful with everything
magwakeenercew2jh, thanks for the offer, but that is the one part that can still be bought. I appreciate it though
Snipescastle, if you can come through with the parts, I would be forever grateful and I would sure as hell pay it forward also, next time someone on here needs something that I have
Thanks again to everyone!!
Old 03-01-2015, 12:33 AM   #19
winky
I have a 68 I'm going disk on I think it has all of the e brake stuff on it. It's at work so I can check for you Monday ( I'll pull and take pics to make sure it's what you need) your welcome to it if you pay shipping.
winky is offline   Reply With Quote
Old 03-01-2015, 09:32 PM   #20
Rod Run
Rod Run's Avatar
I would love that. Thanks for the offer
Paying shipping would not be a problem for me. Usually I always take care of people with beer, so I would even include some extra dough so you could purchase yourself some of your favorite flavor
With everyone offering and being so kind, I just want to let them know that I have a 6 lug rear and I don't know if that would make a difference on the parts inside the drum? I doubt it would, but I just wanted to mention it
Thanks again!!!
Old 03-01-2015, 09:35 PM   #21
winky
Everything I have is 6 lug as well, can you receive sms messages on your phone? It would be a lot easier for me to just text pics instead of trying to upload etc...
Old 03-01-2015, 10:07 PM   #22
Rod Run
Rod Run's Avatar
oops... I meant to say I have a 5 lug... sorry about that
Right now I have no cell phone. I've been without one since Friday and I'm in a big battle with Sprint right now, so I don't know when I'll have it back
I feel so lost and alone without it. LOL!!
Old 10-30-2015, 09:01 PM   #23
Rod Run
Rod Run's Avatar
I finally located a possible parts donor rear end.
I am going to check it out on Monday, but the only problem is that it's a 6 lug and I have a 5 lug, so I don't know if the parts will fit my rear end
8 months trying to source these parts is crazy. I've never had this hard a time at finding anything I've ever needed for restoring a vehicle
Old 10-30-2015, 09:09 PM   #24
Dustytrix
I went from 6 to 5 lug, and used all the brake parts, fit without issues. 67 to 71 rearend.
Dustytrix is offline   Reply With Quote
Old 10-30-2015, 10:40 PM   #25
Rod Run
Rod Run's Avatar
Best news I've heard in months
That will make me sleep well tonight. Thank you!
