Old 01-29-2004, 01:58 PM   #1
cheyenne10
cheyenne10's Avatar
Blazer Carpet Kits
I would like to install a carpet kit in blazer that is easily removeable. Has anyone done this? I don't want to use snaps like older bed covers. Carpet when wet promotes rust and mildew. During summer months should be no problem, in winter remove and clean often or just leave out. Thinking about installing POR15 and bedliner combo to floors and then hiding with carpet in summer and running without carpet in winter.
Any thoughts? Often someone else has down what I'm thinking about, hate to recreate the wheel.
Bob
cheyenne10 is offline   Reply With Quote
Old 01-29-2004, 04:29 PM   #2
Leinie
I have thought along the same lines as you. My thought was to cut the carpet myself to fit, then take it and have the edges hemmed. I would then use velcro , or some other unthought of method to hold down the edges but still be removable.
You need something other than gravity to hold it down with the top off. Everything on my floor flies up at about 45mph and topless.
Leinie is offline   Reply With Quote
Old 01-29-2004, 05:04 PM   #3
cheyenne10
cheyenne10's Avatar
velcro
Velcro might be enough. I think I saw a bulk roll of 2" wide stuff at Costco last week.
Bob
Old 01-29-2004, 06:20 PM   #4
pound41
If your blazer was orginially fitted with carpet. Under the carpet would have been a heavy molded black rubber set of mats that had fins on them to fit into the contour of the bed style floor and make it level. They are pretty thick might try and find a set
pound41 is offline   Reply With Quote
Old 02-02-2004, 03:57 AM   #5
sdredneck
The Crazy Kracka
Why not just use a sill plates to hold them down. They would only be held down with some screws. Easy enough to pull out. Or do like I do and carry way to much stuff. That hold it down pretty well.
My goal in life is to be as good of a person as my dog already thinks I am.
68 GMC LWB 396 BBC Camper Special
72 Chevy Blazer 4x4 with 406 SBC
73 Dodge Dart Sport with 340
sdredneck is offline   Reply With Quote
