![]() Join Date: Aug 2003
292 parts from 71 GMC
Engine will turn over but haven't got started. It is auto truck. Power steering $325,linkage $50. Shipping extra. I will add other parts/priced when check more on engine. Please respond to post. First take it gets it. Pics to come shortly.
Re: 292 parts from 71 GMC
Pic 1
#2
#3
#4
#5
"Trucks with Class"
![]() Join Date: Jul 2000
That is the best examples of a "correct" 69-72 292 PS I have seen in a long time. There have been several others that may or may not have worked...but, this one is right!
Get all of the pulleys to make sure. |
Frank, are all the lower pulleys attached to balancer? Haven't got that far yet. Or is outer bolted on 71 truck? Thx.
"Trucks with Class"
The balancer will have either 2 or 3 grooves (both work). PS will be either cast or stamped (same offset). WP & alt will both be 2-groove (but, it will work with one alt belt/groove)...and away you go.
Interested in ps setup. Is Pikmup in line for them?
Thanks Ed |
No. Just clarifying applications.
I'm interested in the hard line fuel pump to carb if good. Thanks.
I want/will buy the passenger side crossmember engine mount bracket, if it will work on a 4x4 crossmember. not the brackets that bolt to the engine but the ones that bolt to the crossmember and depending on price.
Sorry for spelling ti out exactly but some people have offered me some parts but that will not work. I do not know if 2 wheel drive and 4 wheel drive are the same. here is a picture of what I have engine wise and my crossmember is the correct factory 67 angled one. sorry no picture of that right now Plus, good to see 292 parts going for what they are! Pm me I tend to forget things. Thanks, Steve |
Can you give me a break down of what is included for the $325 price.
Thanks Ed |
#15 |
#16 |
Dirt's72 will check,qksilver I will sell complete mounts for $100,Chevyguy71that includes pump,brkts,lines. Pulleys are extra. Pump pulley is included.
#17 |
Active Member
![]() Join Date: Dec 2003
#18 |
I'm interested in:
Carb (if it's complete and rebuildable) Throttle cable Gas pedal assembly (if it's for sale) Coil bracket Engine lift hooks (if they're still there) |
#19 |
Dirts72 gas line is copper,72swbcamaro75 plus ship,rickoner do you want brkt for auto kickdown too? If not 65 plus ship. No lift brkts. Sorry taking me so long to respond.
#20 |
No, I won't need the kickdown bracket. Is that $65 for everything else besides the lift brackets though?
#21 |
Rickoner that's correct.
#22 |
Pm'd you.
#23 |
Hi, is the w/p pulley one pulley with two grooves or two single groove pulleys bolted together? By the way I'm still interested in p/s setup. How much shipped to 92701
Thanks Ed |
#24 |
Don't have pulley off yet but looks to be single.
#25 |
and they will work on a 67 4x4 crossmember? Just want to make sure, what does the complete mount mean (bolts also?)and does it include shipping ?
Thanks, Steve |
