Old 03-30-2015, 06:31 AM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
NP205 shifter linkage
I have a couple different NP205s, the earlier ones used a bent flat bar between the shifter and the shift rail coupler (connection made with bolts). On the later ones they have a nice little bent piece of stock that has a retaining bushing on the shift rail end and a washer/cotter pin at the other end (shifter). I am trying to locate the little retaining bushing. Any ideas? Thanks,
Jim
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-30-2015, 10:35 AM   #2
jeffahart
jeffahart's Avatar
Re: NP205 shifter linkage
any parts bushing wise I've gotten for shift linkage is from just locating a proper size bushing. I just fixed my 205 shift lever where it mounts. I could not find a proper pivot bolt. I ended up using a bolt wrapped with a shock mount sleeve then put brass bushing around the shock sleeve. It is solid and works great. But I would like to locate a proper pivot bolt. I would like to see the bushing you are talking about, and how it is assembled. My linkage uses cotter/clevis pins for assembly. You can hear jingle bells at the right RPM from washers singing.... annoying!
White K20
jeffahart is offline   Reply With Quote
