04-18-2015, 10:16 AM | #1 |
Doors will not lock
I will be installing my new interior this week and would like to get this fixed so I feel safe when it's parked in parking lots. knobs will push down inside but when you close the door and you can just open it right back up like they never locked. does the same way thing when you lock it with the key from outside. Turn the key and the knob goes down but door opens up without unlocking.
1970 Long bed- Stress release "There are only two kinds of people that understand Marines: Marines and those who have met them in battle. Everyone else has a second-hand opinion." Unknown |
04-18-2015, 10:47 AM | #2 | |
Re: Doors will not lock
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
04-18-2015, 04:31 PM | #3 |
Over the years my doors wouldn't lock with the key. The tumbler just would not turn. My truck is parked in the back yard, so my concern was low. Eventually, the problem got bad enough they couldn't be locked from the inside either.
I pulled them out and gave them a nice ultrasonic bath with a hot water/Simple Green solution. I studied how they work, and oiled all moving parts. Now they work like I imagine they did new! What I found is they are designed to prevent owners from locking their keys in. There is no way around this, even if you ground off some of the functions of the mechanism, you'd prevent something else from working. Regards, Mike P.S. If the door opens when locked, it might not be completely locked. The mechanism is probably gunked up with dirt, like mine were.
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback. The C10 and the Super Beetle run, the Fastback is just not there yet! Please visit my Super Beetle and Fastback profile on TheSamba. |
04-18-2015, 07:20 PM | #4 |
The Older Generation
The key is not turning far enough to actuate the lock mechanism so the lock knob is not going down far enough. Try pushing in on the door while you turn the key to lock it.... You should also lubricate the door latch and the locking mechanism. LockDoc
04-18-2015, 08:06 PM | #5 |
Thanks everyone. I will give this a try in the morning and let you know how it works.
04-18-2015, 08:29 PM | #6 | |
LockDoc
04-19-2015, 01:41 AM | #7 |
stupid question but, what oil should we use for the locks an such?
thanks, jason
70 Chevelle | 71 Camaro RS/SS | 71 K20 | 98 TransAm | 10 Ducati 848 |
04-19-2015, 07:16 AM | #8 |
04-19-2015, 07:57 AM | #9 |
blood type; Retumbo
someone years ago had a thread on how to disable the auto-unlock by grinding a tab on the latch. But then you better have a spare key hidden somewhere
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
04-19-2015, 09:32 AM | #10 | |
All I ever use on lock parts and lock cylinders is spray lubricant with teflon. The only problem with the Graphite that 7tee mentions is that people get really carried away with it. It tends to hold moisture and turns into a gummy mess inside the lock cylinders. LockDoc
04-19-2015, 10:54 AM | #11 |
Thanks all. Little lube and gentle pressure and both doors lock now. Once again I have to say this is the best message board I have ever used.
04-19-2015, 12:34 PM | #12 | |
I do forget what the other action was. Regards, Mike
