Old 04-22-2015, 01:02 AM   #1
bilfman
bilfman's Avatar
Re: 79 6x6
Pm'd you on tires.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 04-22-2015, 01:28 AM   #2
Dcheat
Re: 79 6x6
Originally Posted by Dcheat View Post
Even with 40" tall tires, thats like running a 5.0:1 gear on stock street tires. With the overdrive of the 4L80E, im looking at 2600 rpm at 75 mph. Liveable.
Sorry, just noticed a typo. Should have been 46" tall tires. Not 40"
Dcheat is offline   Reply With Quote
Old 04-22-2015, 10:21 AM   #3
wilkin250r
wilkin250r's Avatar
Re: 79 6x6
Love the truck. I'm in your neck of the woods, and I truly, honestly would love to see this thing in person.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 04-22-2015, 11:06 AM   #4
Dcheat
Re: 79 6x6
Your up in Tahoe? Well shoot, swing on by! Kick the tires, shoot the $hit, turn a wrench. There's not a heck of a lot to see at the moment. It's back in the garage in bits, engine and trans are out. I need to cut out and replace the firewall. Discovered some spots hidden by undercoating that I can push my fingers through due to rust.... So I have that going for me
Old 06-11-2015, 12:00 AM   #5
Dcheat
Re: 79 6x6
So! How wants an update! I know I do!
Still on track for August to have it running.
Got my propane setup from Nash Fuel as Gotpropane will not just sell you just parts of a kit. He only sells a full kit. Some of which I didnt need.
My vaporizers are Woodword H-420 tweaked to my specs by NVGI, that are rated for 600hp each.
Getting closer, fellas.
Old 06-11-2015, 12:01 AM   #6
Dcheat
Re: 79 6x6
Little secret for gaining a few ponies out of the Impco mixers.
Inside the fuel inlet is a little restrictor plate.
Pull the thing out.
Reports say this is good to allow the mixer to support an additional 40hp of fuel demand.
Got all my wiring, MSD ECU and TCU sitting in boxes. And a new compact in-cab heater as im freeing up some space on the firewall and under the dash.
Also just picked up some procomp air-bumps.
Chugging right along!
Old 06-12-2015, 03:27 PM   #7
rajincajintj
Re: 79 6x6
Pull the thing out.
nice!!!
ill go pull mine out of my CJ's carb right now. good tip
76 c30 3+3 Camper Special - 12V 5.9l 6BT Cummins and 47RE
rajincajintj is offline   Reply With Quote
Old 06-11-2015, 06:29 AM   #8
Flatpat
Flatpat's Avatar
Re: 79 6x6
Looking forward to seeing this beast in action.
I may have a problem.. 1976 K20 Crew, 1978 K30 Crew, 1981 K30 Crew, 1985 C30 Crew, 1987 C30 Dually Crew, 1988 R3500 Crew, 1990 R2500 Crew, 1991 V3500 Crew, 1991 V3500 Dually Crew.
Flatpat is offline   Reply With Quote
Old 06-14-2015, 01:14 PM   #9
Zach079xxx
Zach079xxx's Avatar
Re: 79 6x6
This build is crazy! I am amazed :P
Zach079xxx is offline   Reply With Quote
Old 06-21-2015, 12:55 AM   #10
Dcheat
Re: 79 6x6
Well, Rust f-ing sucks. When slinging the engine in, I decided to clean up some of the globed on undercoating on the firewall. And while doing so, I noticed my fingers pressed into the cab with ease. Finally got around to stripping the dash and wiring to get to the firewall, and I found a nice strip of the stuff that I figured just needed to be cut out and replaced. Well, the deeper you dig. As you can see by the photos, its bad. Seems the gutters were completely full of debris. Spent the better part of an hour cleaning all the crap out of them. This truck must have been parked under a pinetree for quite a while. I fished out dead mummified baby birds, and so much plant material that it had turned into a nice black fertilizer. Should have put the bucket full I cleaned out onto my veggies.
Over the years, this allowed muddy water to pool on the seam between the firewall and the wiper race. Cancer took over. Even behind the brake booster is completely rotted out. So, the entire firewall needs to be cut out and a new one fabricated. Yippy... At this point, its been suggested that I look for a new cab. I'm taking this under consideration.
In all honesty, im just tired of finding new time consuming stuff to do with this rig. Delays, delays.
That and, living in Nevada, Im spoiled as hell. There is no rust here. The only salt that touches your rig is from the fries you dropped. Soooo.. no time like the present.
I hate working on sheet metal. Its not like the big stuff that just needs some good deep welds. Its hours of this tack-tack-tack crap that drives me nuts.
Old 06-21-2015, 11:00 AM   #11
Corts60
Just here to tinker
Corts60's Avatar
Re: 79 6x6
This is one crazy build. Hats off to you. It sounds like you've done your research.
Old 06-22-2015, 10:50 AM   #12
carboncrew
carboncrew's Avatar
Re: 79 6x6
I'm in...
very cool build!
________________
My very own build
My tailgating ambulance
carboncrew is offline   Reply With Quote
Old 08-12-2015, 03:35 AM   #13
Dcheat
Re: 79 6x6
Engine is home as is the hydro-boost brakes
Trans and t-case are tucked nice and deep into the cab for better clearance for suspension bits.
New input on the NP205 and a clocking ring as well. Twin sticked of course.
Well, moving on to the wiring
Old 08-12-2015, 08:41 AM   #14
carboncrew
carboncrew's Avatar
Re: 79 6x6
almost forgot about this thing....still really cool. Thanks for the updating
________________
My very own build
Old 08-12-2015, 09:08 AM   #15
willem445
willem445's Avatar
Re: 79 6x6
Wow this is amazing! Cant wait to see it come together. How did you remove the metal piece of the dash? Ive always wanted to remove that to clean up the mess of wiring under the dash but its incredibly hard to get to with the metal dash still there.
willem445 is offline   Reply With Quote
Old 08-12-2015, 01:32 PM   #16
chevytrucksforme
Re: 79 6x6
That's one crazy awesome build!! Love it!
chevytrucksforme is offline   Reply With Quote
Old 08-12-2015, 07:45 PM   #17
Dcheat
Re: 79 6x6
Thanks for the compliments fellas. She's running WAY behind schedule. But it should be running soon enough.
As for the dash... A sawzall works well. Side grinder. Or if your lucky as hell to own one, a plasma torch.
I tried to peel up the rubber window gasket to get access to the spot welds. And then the windshield cracked. So out came the sawzall and so did the dash. I'll be fabricating a new dash. But fiberglass and aluminum option are out there.
From DIY4X.com
Fiberwerx.com
Old 08-12-2015, 11:33 PM   #18
TrailerTrash
TrailerTrash's Avatar
Re: 79 6x6
coming along very nicely ive been fallowing this since the beginning and loving every update
looks like you have a plasma cutter yourself. they sure are nice
TrailerTrash is offline   Reply With Quote
Old 08-13-2015, 12:11 AM   #19
Reno81K20
Reno81K20's Avatar
Thumbs up Re: 79 6x6
Cant wait to see this out on the streets here in Reno.
Reno81K20 is offline   Reply With Quote
Old 08-13-2015, 08:43 AM   #20
willem445
willem445's Avatar
Re: 79 6x6
From DIY4X.com
Fiberwerx.com
Thanks for the reply. I thought there were some magical screws or something that I didnt see when I had my dash pad off.
Old 08-13-2015, 02:51 PM   #21
wilkin250r
wilkin250r's Avatar
Re: 79 6x6
Isn't this typical? I've NEVER finished a project like this on time...
Old 08-14-2015, 04:40 PM   #22
OutlawDrifter
Re: 79 6x6
glad to see this thing is still progressing
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 09-21-2015, 12:16 AM   #23
Dcheat
Re: 79 6x6
Bumping back from the mothballs.. Sucks being the only person in my group of friends who can fabricate. Always other stuff to do besides work on my own rig.
Yay! Finally had a full, uninterrupted weekend to myself to hammer some stuff out. So, here ya go. Photos of the interior progress so far.
Keeping it clean and functional. Everything within reach and easy to view for myself and the co-driver.
Old 02-22-2016, 01:08 AM   #24
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: 79 6x6
Sweet build! I keep seeing pictures of it on Facebook and someone posted a link.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 02-22-2016, 02:29 AM   #25
Dcheat
Re: 79 6x6
Thanks Hate to say it, but I keep forgetting to update this thread. Sorry about that, fellas. For the most up to date stuff, keep an eye on my Pirate4x4 thread.
http://www.pirate4x4.com/forum/chevy...-big-ugly.html
But, in the mean time, here are some updates!
Engine is all ready to rock!
Cooling it is a 3 core mishimoto radiator and some big plate coolers for the other fluids. Engine oil, trans fluid and power steering:
Wrapped up the crossmembers and skid plates:
