05-17-2015, 08:44 PM | #1 |
Danforth Cross Member Install
After weighing all my options, I have a Danforth Cross Member on the way. IMO it is the most cost efficient way to do a IFS in a AD truck while using the stock frame. Cost of the Cross Member is $500.00 plus freight.
There are some build threads on the interweb, but nothing yet I have seen from start to finish, and it took a lot of reading to find them. I am planning on this install late fall, but have already started looking for donor parts. The pictures below are some that I have saved from build threads and off Facebook. The Cross Member is based on GM metric geometry, which is the 1978-1987 GM G-bodies, parts of the F bodies, and the S/T bodies which includes the S-10 and S-15. |
05-17-2015, 08:45 PM | #2 |
Re: Danforth Cross Member Install
05-18-2015, 08:48 AM | #3 |
Looks sweet. I will be looking for pictures of your upper A-arms installed.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
05-18-2015, 10:19 AM | #4 | |
05-18-2015, 07:21 PM | #5 |
Danforth Crossmember? Okay, I'll say it: Never heard of them.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
05-18-2015, 09:32 PM | #6 |
This kit was designed by Scott Danforth to use GM metric suspension on the 47-54 frames. He is an active member on Stove Bolt and The Hamb. He now builds them for others to use for a low dollar alternative to ifs / S10 swaps.
1949 Five Window, 1973 Step Side, 2000 Z71 |
05-18-2015, 10:54 PM | #7 |
I'm sure you know it, but you can use the 2WD 98 and up Blazer steering knuckle/sealed bearing spindle/ and duel piston brakes on the G Body setup. These are really cheap in the salvage yards (just bought a complete set to upgrade the brakes on an S10. If you really want to go all out, you can use the 2WD blazer steering knuckle and sealed bearing, buy an $85 bracket, and bolt 5th generation Corvette brakes and rotors on the front. Love your build, looking forward to your upgrades.
Ricky
Rick's 55 TF/Fleetside/LSx build 1958 Corvette LS1/T56 Build 1966 GTO LQ9/T56 Restomod |
05-19-2015, 07:54 AM | #8 |
You have to kinda dig to find info. He does not advertise at all.
05-19-2015, 09:43 AM | #9 | |
05-19-2015, 09:45 AM | #10 |
05-25-2015, 08:49 PM | #11 |
A320 Pilot/USAF Retired
That cross member looks nice, looking forward to seeing it installed!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
05-26-2015, 08:49 AM | #12 |
Thanks, I am super excited to install it.
I found a donor truck, I just need to find the time to strip the front suspension off it. To get to my preferred ride height, Scott is suggesting drop spindles, so I need to order those as well. |
05-26-2015, 05:28 PM | #13 |
Could you notch the bottom of the frame to raise the cross member and eliminate the need to notch for a arm clearance?
http://67-72chevytrucks.com/vboard/s...d.php?t=414646 |
05-26-2015, 05:30 PM | #14 |
raising/ notching the cross member into the frame lowers the truck even more, it's discussed in the thread on stove bolt. Seem like the hard way when you can buy dropped springs and spindles or easily use air bags, but Mr. Danforth notched a frame to accomplish it.
05-26-2015, 05:44 PM | #15 |
I guess it would have been better to say "I should have done this" instead of giving up on that unit in my truck.
05-26-2015, 05:46 PM | #16 |
So you have a Danforth member and decided not to use it?
05-26-2015, 10:54 PM | #17 |
Had one, installed it, got cheesed off because the steering wasn't completely developed and traded the chassis away to do a dakota swap.
05-26-2015, 11:15 PM | #18 |
Right on. I am in the process of ordering one, if you had one to get rid of I was ready to drive north! LOL!
I will post photos of mine going together. |
05-27-2015, 02:09 PM | #19 | |
The top notch is still avoidable with a tubular upper A arm, which are pretty affordable. http://www.ubmachine.com/uppermetric.html |
05-31-2015, 07:27 AM | #20 |
Random Notes:
Donors- Any 1982-2004 S-10, S-15, T-10, T-15, S-10 Blaser, Sonoma, Hombre, Bravada, Jimmy, Cyclone, Typhon, etc. Technically GMT-325 and GMT-330 chassis These are the same stampings as any A/G body which is any 1978-1987 Malibu, Regal, Monte Carlo, Cutlass, El Camino, Gran National, etc. |
05-31-2015, 07:30 AM | #21 |
Rack and Pinion:
"the 1993-1997 Camaro or Firebird. in 1998, they changed the angle of the pinion and it hits the frame. simply cut off 4-1/8" off the inner tie rod ends and rethread. however if you desire, a ford exploder or dodge durango/dakota rack and pinion can be used as well." "The 87 Tbird rack I used goes stop to stop on stock S10 spindles. I haven't driven it yet but i'm expecting a turn radius about the same as a long bed S10" |
06-01-2015, 09:41 PM | #22 |
Hollister Road Co.
The 87 Tbird I used came up a bit short on turning once we have this on the ground and actually driving it was about 3/4" from the stop ,not bad Its just not where I want it. I have a 97/98 Mark Viii rack on the way that turns 6.88" lock to lock and should take care of that issue. The Tbird rack was 5.33" lock to lock. I believe it has the same mountings. I'll post what I find out when I get it
06-02-2015, 09:21 AM | #23 | |
I am pulling parts from a 1995 Thunderbird (same as 1995 Mark Series) and have access to that rack. |
06-02-2015, 03:39 PM | #24 |
I am going to use a Sweet power servo rack in mine from stock car racing.
06-02-2015, 03:48 PM | #25 |
How much do those run?
