Old 02-11-2004, 12:28 PM   #1
Beefcake
what's you best MPG??
Give me some #s....
Looking to increase my MPG in my 1/2 ton would like to stay with a carb... but if you want to brag with your fi, feel free!!
What engine/trans and setup?
thanks!!
72 GMC Camper Special 2500.
currently has 350/350/14 bolt. 383 and 400 tranny is in the works.
Beefcake is offline   Reply With Quote
Old 02-11-2004, 12:51 PM   #2
_Q_
I'm running a 402 BBC, holley intake, and a 625cfm road demon. I've also got a 700r4. I get about 16-18 freeway, 10-12 in town.. depending on how far my foot goes.
_Q_ is offline   Reply With Quote
Old 02-11-2004, 01:20 PM   #3
JimKshortstep4x4
Talking
71 longbed, 307/TH350/307 gears, 2wd, 16 mpg highway, 14 city.
Engine has a 4 bbl. Q jet.
Does not seem to vary if loaded or not.
Jim
Old 02-11-2004, 01:31 PM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
33" tires 4.10 gears 4speed, about 7 mph. When I fix the vacuum advance then back to about 11 mph. Q-jet. stock 350.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-11-2004, 01:53 PM   #5
lukecp
Formerly yellow72custom
lukecp's Avatar
13.2 is my best, usually around 12-13, mostly highway driving. 300hp 350/TH350/3.07 gears in a 3980lb truck
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 02-11-2004, 02:02 PM   #6
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
327/350/3.07. 2wd and a 2bbl and points! 11-13 town, 11-13 highway (running 70-80mph). If I would slow it down (never) to 50's then it comes up to the upper teens but I've got better things to do than turn 2300rpms... (3g's at ~82mph)
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 02-11-2004, 02:41 PM   #7
mrein3
mrein3's Avatar
3.73 rear. 4wd. Just over 13 is my best ever.
Usually around 9.5 while towing my boat.
3-5 in the winter which consists of warm it up 20 minutes, drive 1/4 mile across the lake, shut it off.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 02-11-2004, 03:20 PM   #8
Grim Reaper
I think a few of those are a little off. Odometer is off from tires size I bet.
Best I have manage with a 88 FI 454, TH400, 3.73 and 235/85/16 E-rated hwy tires was 11.5 in a Suburban. Steady 70mph with 2800 ish on the tach.
That's as recorded by GPS for the miles and confirming my odometer is only off by 3/4 of mile over 300 miles on the current tires. It was a start engine drive 300 miles on the hwy deal. Normal driving to and from work including 38 miles of hwy a day against traffic it gets 9.5 with winter grade and long warm ups (She cold natured). I'm a set the cruise type also and run under 70.
With OD I can buy 14-15. Tall gears I can buy 12-14.
Best I did on my 75 Jimmy was 12.5 empty on 32's with a 3.08 gear. I towed a car back that same trip and was down to 8-9 area. The Odometer seemd fairly acurate but I never checked against a GPS when it had that combo. It seems to get about 9.75 on 35's with a 4.10 gear now with summer fuel and no top.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 02-11-2004, 04:39 PM   #9
darcane
Just over 15mpg with a 400sb at ~75mph.
That's with 3.73 gears, a 5-spd (from a 1990 1/2 ton), and a lame EFI system (Holley Pro-jection 4). I don't have any good numbers with the 700R4 yet.
Mike Lackey
'68 C10
darcane is offline   Reply With Quote
Old 02-11-2004, 04:39 PM   #10
68 Suburban
68 Suburban's Avatar
17+ Adjusted for the tire size
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 02-11-2004, 04:45 PM   #11
Bowtie67
Bowtie67's Avatar
Cool
15mpg around town 21mpg on highway, 350/ roller setup and Holley MPFI, 700R4 with 2200 Stall & 3.73 gears. Custom Crower Roller Cam 208/218 452/477 112LC, Performer RPM Heads, 10.2cr
But I should also add this is gonna change
new setup this summer includes, Loosing over 300lbs in truck,
New IFS, Four Link Rear, 414SBC 10.4cr, Fuller Roller Setup, 4.11 gears and New Holley StealthRam Setup.. Hoping to smoke a few Mustang Cobras..
Bowtie67 is offline   Reply With Quote
Old 02-11-2004, 05:57 PM   #12
72c10step
WHYBYNU when old will do?
72c10step's Avatar
That's pretty sweet! Have you ever taken it to the dragway? It'd be cool to check that out someday!
-72 Chevy C10 Stepside
-2002 Chevy Silverado 2500HD 4x4
-1984 Jeep CJ7
-1995 Polaris XCR600 Custom
-2003 Honda 300ex
72c10step is offline   Reply With Quote
Old 02-11-2004, 06:35 PM   #13
Bowtie67
Bowtie67's Avatar
Post
The crower cam really smoothed things up and there was quite a bit of torque but the cam was more docile, I went from a Compcams 286HR to this, HUGE Difference, the 286HR WOuld smokem through 3 gears and really sounded awsum, but would load up in heavy city driving and out on the highway it really didn't really feel like it was there, more of a lets get it on type of cam, The new motor I'm hoping is gonna get a little more of both worlds, CompCams XE276 Marine Cam. Im putting in a 2 peice timing cover if it's not...
Old 02-11-2004, 06:43 PM   #14
ts71281
In my 70 SWB 1/2T 2WD and a 468 with a 3spd saginaw and 3.73 gears I can yank about 15 MPG on the interstate at 65MPH and 12 MPG in town if I keep my foot out of it.
Joe Hirdler
ts71281 is offline   Reply With Quote
Old 02-11-2004, 07:18 PM   #15
cdowns
cdowns's Avatar
4:10 gears 2004R tranny longbed with 350 about 300hp on the highway 75-80mph i get just under 17
Old 02-11-2004, 10:01 PM   #16
cochran63
cochran63's Avatar
Over the summer i had a 14:1 chevy 302 on alcohol that got 1/3 of a mpg, but when i have my 327 in i get around 14-15 mpg
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 02-11-2004, 10:06 PM   #17
bad 71 chevy
bad 71 chevy's Avatar
12.0 is my best
71 Chevy C/10 lwb 350
5 speed nv3500
3.73 rear end
2.5" Front Drop and 4" in the back
Edelbrock perfomer rpm manifold
Edelbrock 600 cfm carb
Headmen headers
bad 71 chevy is offline   Reply With Quote
Old 02-11-2004, 10:10 PM   #18
67dragtruck
67dragtruck's Avatar
cams
I feel your pain on the cam deal. I have the 300HR one in mine and with some huge rockers at that and I definitely know what you mean. Very tough to adjust with the EFI, hits a nasty lick, actually runs well, but tough to tune. Thinking of putting a smaller stick in mine too.
Tom
67dragtruck is offline   Reply With Quote
Old 02-11-2004, 10:15 PM   #19
jku72
My 68 burb gets 16 around town, 19 on the highway. I run a 350, 4 speed, and 3.07 rear.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 02-12-2004, 10:57 AM   #20
Bowtie67
Bowtie67's Avatar
Post
Dragtruck, I ran that 286HR with a set of duel quads and had same issue with city driving as far as FI goes the eaiest I am able to figure is that you need at least a 112LC for best compatibility, What motor and setup are you running in that truck, just curious..
Old 02-12-2004, 12:07 PM   #21
rn2fine
rn2fine's Avatar
72 Burb, 2WD, 350, Vortec Heads, Headers, TH700R, 3.07 Rear, Edelbrock Performer Intake, Edelbrock 600 cfm, Average 15 mpg
72 C10 Burb 350 700R4
70 C20 LWB 350 Crate TH400
68 Chevelle
rn2fine is offline   Reply With Quote
Old 02-12-2004, 02:55 PM   #22
68 Suburban
That combinations seems like it should be getting a lot better. What cam do you have?
Old 02-12-2004, 02:59 PM   #23
rodnok1
rodnok1's Avatar
18 in the tow vehicle when the stock distrib broke, otherwise 12-13 max usually 8 around town, less if I whoop on it.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 02-12-2004, 06:49 PM   #24
71402BB
now thats a true COON DOG
In my 71 swb step
it has a mild 402 BB 10.5:1 268 comp cams cam balanced, 4-speed 3.73's and 26" tall tires I got 5mpg this summer with it! I hope to put 2.73's in this spring and hopefully I will double my mpg!
current project
67 402BB stout th350 3.08's with a locker. Plan on tubs 18.5's out back! (thanks Burnsman!)
71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) was my first truck!... oh well...
72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!)
68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!)
67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!)
71402BB is offline   Reply With Quote
Old 02-12-2004, 07:00 PM   #25
68 Suburban
Originally posted by 71402BB
In my 71 swb step
5mpg!!!! Ouch!!! Be carefull with your gearing. You want to make sure you are cruising in a good range for the cam in your engine
