Re: 4L80e wiring help
Thank you for the help. After talking to Hannah at wait4me performance, apparently I was missing the vss connector on my harness so she replaced it with what she had laying around. It's the right plug,just has a weird lock shell, however, that set of wires only needed to be about five inches long. The transmission I bought has those connectors still on it but the vss sensor one only has about 1/4 inch of wire sticking out so I had to take it apart and I'm now searching ford my solder iron join wires together to connector. I will be shortening the harness a bit as well.
Thanks for all the help gentlemen..........oh and you too aknovaman. ![]()
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303 My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw |
