Old 06-15-2015, 09:26 PM   #1
2wd73blazer
Is there a difference in 2004 and 2005 lq9 engines?
I bought a lq9 and I was told it was out of a 2005 Escalade. It has a fan on the water pump. My 2005 Denali has electric fan setup. That makes me believe it is actually 2004 or older. The reason I ask is while buying parts i discovered there are different part numbers for head gasket kits for 2004 and 2005 and don't want to buy the wrong thing. If anyone knows of any differences I would love to know what they are.
2wd73blazer is offline   Reply With Quote
Old 06-15-2015, 09:49 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Is there a difference in 2004 and 2005 lq9 engines?
My 02 lq9 had electric fans...not sure about the other years..I'm told there should be a casting date on the heads..or a wta sticker on the back drivers side head,, those numbers can be run by a gm tech to tell you all about the engine but I've not looked at mine.also told the only changes made were longer head bolts.
Old 06-15-2015, 10:05 PM   #3
mongocanfly
Wta sticker..
Old 06-15-2015, 10:58 PM   #4
boostedc10
boostedc10's Avatar
Not sure what you are looking at for head gasket differences between 04 and 05 for the LQ9. If you're sure it's a LQ9 there shouldn't be any differences in those years. Only thing that may be different is the head stud kit if it's a super early 2004. Bottom end on the lq9 was pretty much the same all the way through the years. Floating pins and beefier rods. What is your concern?
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 06-16-2015, 11:35 AM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
AFAIK even with the stud/vs bolt situation, the gasket is the same. The defacto replacement is the GM LS2 gasket. Its whats sold by GMPP, TSP, and every other high-performance abbreviation lol. Don't spend the money for an aftermarket gasket, as the stock gasket is already MLS.
As long as the heads and deck are stock, this gasket @ .51 is what you need.
GM Part# 12589227
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-16-2015, 11:36 AM   #6
2wd73blazer
I want to make sure i get the right gasket set. I looked up felpro and they list a hs26192pt2 as the set I need. One site said I needed hs26192pt. I am going with felpros info.
Old 06-16-2015, 12:42 PM   #7
boostedc10
boostedc10's Avatar
I use factory LS9 gaskets on all my builds.
Brandon
Instagram: DRVFSTR
