Closed Thread
Old 06-20-2015, 08:47 PM   #1176
dougf
dougf's Avatar
Re: What did you do to your truck today part III
Typed a lot but was lost.mwiod turkey 101 got me a little loopy. Wild turkey is good stuff! Getting my bed ready
dougf is offline
Old 06-22-2015, 03:31 PM   #1177
mjh1965
mjh1965's Avatar
Well I got home this afternoon,to find that my paint had arrived . So I guess I will be starting on the chassis this weekend
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline
Old 06-22-2015, 03:36 PM   #1178
Lugnutz65
Lugnutz65's Avatar
Originally Posted by mjh1965 View Post
Well I got home this afternoon,to find that my paint had arrived . So I guess I will be starting on the chassis this weekend.
Try this tip. It makes working with POR-15 less messy.
http://lugnutz65chevystepside.weebly...less-mess.html
I also recommend applying a rattle can top coat after the POR-15 has dried enough to not leave any fingerprint.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 06-22-2015, 04:49 PM   #1179
mjh1965
mjh1965's Avatar
Great tip thanks I am using the grey on the chassis . The black is for the suspension parts so that tip will come in very handy . Does anybody know how much I will probably use on a long bed chassis . I have got 2 quarts
Lug nuts you recommend putting a top coat over the top did you use clear or colour ?
MY BUILD THREAD:
mjh1965 is offline
Old 06-22-2015, 04:53 PM   #1180
Lugnutz65
Lugnutz65's Avatar
Spray any colour you want. The POR-15 is gonna fade if exposed to UV light. The top coat will protect it. I think 1 quart is enough to do the entire chassis with 2 thin coats. Two thin coats is better than a thicker coat.
Old 06-22-2015, 06:55 PM   #1181
OldChevy61
OldChevy61's Avatar
Didn't touch it, but spent a bunch of money on it today. Front end rebuild kit, cam and lifters, and a set of headers. About to order epoxy primer. Been over 100 degrees here for more than a week. Hard to get motivated to run that sandblaster after a days work.
OldChevy61 is offline
Old 06-22-2015, 07:02 PM   #1182
blown240
blown240's Avatar
I got the carpet installed in the back of my Panel. First 1/2 inch padding, when thin low pile carpet. Really happy with how it turned out!
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline
Old 06-22-2015, 07:16 PM   #1183
LDO
LDO's Avatar
Great job on the carpet!
LDO is offline
Old 06-22-2015, 07:32 PM   #1184
blown240
blown240's Avatar
Thanks LDO!
blown240 is offline
Old 06-22-2015, 10:31 PM   #1185
Very nice job!
Palf70Step is offline
Old 06-23-2015, 12:53 AM   #1186
DLW
Looks great. Makes me want a burb now..
DLW is offline
Old 06-23-2015, 12:41 PM   #1187
blown240
blown240's Avatar
Thanks guys!
blown240 is offline
Old 06-23-2015, 01:27 PM   #1188
rudy62
rudy62's Avatar
Put bed on truck with new (used) metal floor
rudy62 is offline
Old 06-23-2015, 02:52 PM   #1189
siggyfreud
siggyfreud's Avatar
One quart of black covered my long-bed frame with two coats and I still had some left over. The stuff is really really thin and goes on very nice with a brush.
I then used their black topcoat, which went on much thicker, and did, in some cases, leave brush strokes. Put down plastic over anything you don't want black spots on, and wear gloves/long sleeves. This is tough stuff, but hoping it'll make my frame pretty much rust-proof.
Your frame and suspension won't be exposed to UV very much, but I still recommend the top coat.
Here is a shot of what the finished frame with POR 15 and their top coat looks like:
siggyfreud is offline
Old 06-23-2015, 04:02 PM   #1190
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Originally Posted by Jonnyspringfield View Post
Those are purdy 😍. Where did you order them from?
I am not the poster of the pics but I know those are made by Speedhut.com They custom build your gauges when you order them. You can specify all types of items, like font, lighting color, bezel style, etc. I have used them for a couple projects and love them.
www.speedhut.com
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline
Old 06-23-2015, 04:40 PM   #1191
siggyfreud
siggyfreud's Avatar
Hey sorry I missed this post. The poster above is right, they are from Speedhut. They were running a 10% off sale in May so I built them using their configurator.
They will glow blue at night, but only the numbers and lines, so they'll look more like modern gauges rather than my old set of autometer that lit the entire gauge.
You can get them in a bunch of different styles, colors, fonts, lighting colors, etc. A lot of customization is possible. I got a GPS-driven Speedo, so no worrying about transmission gearing or hookups which will be nice.
Old 06-23-2015, 07:25 PM   #1192
scottco
scottco's Avatar
I got the windshield and back glass in... Was a big pain in the butt !!!
1964 C10 SWB original
1970 SS El Camino
1964 Impala SS
http://67-72chevytrucks.com/vboard/s...d.php?t=649951
scottco is offline
Old 06-25-2015, 08:38 AM   #1193
pimpston65
pimpston65's Avatar
been working the last few weeks everyday to get it together, so its back on the frame and bolted up. needs fine tuning and the final body color, its been off the frame since 98' and has many many hrs of work into it!!!
pimpston65 is offline
Old 06-25-2015, 08:47 AM   #1194
mjh1965
mjh1965's Avatar
Thanks for the tip I will definitely put down a sheet of plastic and the long sleeves it might get a bit hot in the carport but I suppose it's better than having to rub your skin of with a scrubbing brush when you have finished
mjh1965 is offline
Old 06-25-2015, 08:52 AM   #1195
1963c-10
1963c-10's Avatar
1964 Short bed trailer
1963c-10 is offline
Old 06-25-2015, 08:57 AM   #1196
Pappyx3!
Pappyx3!'s Avatar
Congrats! Looks like it's coming along well.
Pappyx4!
1962 Chevy C-10 Stepside 383 Stroker, Turbo 400
1966 Chevy C-10 Stepside 250 6Cyl, 3OTT- Daily Driver
John 3:16
Pappyx3! is offline
Old 06-25-2015, 09:00 AM   #1197
Lugnutz65
Lugnutz65's Avatar
Clean drips on your skin with acetone before it dries. Works pretty good. Plan to throw the brush away. I would not roll it. Spread it thin.
Old 06-25-2015, 09:27 AM   #1198
cru_zn_29
cru_zn_29's Avatar
Looking good . What color will it be?
Too many guys would have given up a long time ago.
cru_zn_29 is offline
Old 06-25-2015, 09:42 AM   #1199
Chevy Fleetside
Chevy Fleetside's Avatar
Feels good huh.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 06-25-2015, 12:10 PM   #1200
pimpston65
pimpston65's Avatar
Unhappy Re: What did you do to your truck today part III
i bought the single stage satin black, with shiny black tu tone top. its the only thing other then the burban thats paid for!!!
Closed Thread
