Old 01-10-2015, 09:30 AM   #51
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Re: Intro and Some Photos of my '63 Project
I can't wait to see the motor back in it.
And see the thing make a poncho motivated run...
That truck is a bad boy!
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 01-10-2015, 09:56 PM   #52
vin63
It's Better With Nitro
vin63's Avatar
Thanks! Me neither. In the meantime, in case I forgot to post it, I did finish my deluxe steering wheel modification. It was an unintended diameter reduction, as I was planning on restoring the old original deluxe wheel, but it was too much of a basket case as I got into it. So, I cut out the hub and welded it to a '61 Pontiac steering wheel I had reduced a long time ago for a Ventura project that never materialized.
...size difference after welding the hub to the outer ring...
...lots of epoxy - previous sectioned area on the bottom wheel that I epoxied 10 years ago started to crack:
...about 45 hours of sanding and shaping with another application of epoxy in between:
...painted then assembled:
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-11-2015, 09:59 AM   #53
That wheel looks great!
Palf70Step is online now   Reply With Quote
Old 01-11-2015, 11:28 AM   #54
Jeff La
Great job
Jeff La is offline   Reply With Quote
Old 03-21-2015, 09:20 PM   #55
vin63
vin63's Avatar
And, so it begins...
Old 03-28-2015, 10:16 PM   #56
vin63
vin63's Avatar
A little more progress today on the cab and front fenders...
Old 03-29-2015, 08:05 AM   #57
66-PMD-GMC
66-PMD-GMC's Avatar
That's the main issue isn't it?
Finding -time- to do the project. ...
This is by far in my top 3 favorite builds on this forum.
Looking forward to more photos of progress brutha. .
Projects..
440CID 2X4 Pontiac
Old 04-12-2015, 09:52 AM   #58
vin63
vin63's Avatar
Finally, the body work on the doors and front fenders are done.
Old 04-12-2015, 10:07 AM   #59
66-PMD-GMC
66-PMD-GMC's Avatar
SWEET! Almost spray time...
Projects..
440CID 2X4 Pontiac
Old 04-23-2015, 05:06 PM   #60
vin63
vin63's Avatar
Thanks! Ended up having to completely strip the top of the hood, which set us back a bit. But, a color test was shot on the underside today. Color and hue are good to go…
Old 04-23-2015, 05:48 PM   #61
SCOTI
SCOTI's Avatar
OE dark green or something newer?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-23-2015, 06:01 PM   #62
vin63
vin63's Avatar
Going with a darker tone of the late GM Woodland Green. Kind of a modern homage to the original early Woodland Green.
Old 04-23-2015, 09:14 PM   #63
66-PMD-GMC
66-PMD-GMC's Avatar
While I am not a huge fan of green... I think that looks great...:-)
Old 04-23-2015, 09:57 PM   #64
SCOTI
SCOTI's Avatar
Cool..... Looking forward to your progress.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-30-2015, 12:25 PM   #65
vin63
vin63's Avatar
Thanks, guys! You can tell from the photo in post 56 of the work on the driver side door that underneath the white, the previous owner painted the truck (along with the orange scallops), the truck (code 535) was originally Woodland Green with the Cameo White two tone. I'm going to use a shade of the Hyundai Powder White as the second color to better match the flake in the newer GM Woodland Green.
Old 04-30-2015, 01:10 PM   #66
1963c-10
1963c-10's Avatar
Nice job on the doors, fenders and hood. That color looks great
1964 Short bed trailer
Old 05-18-2015, 09:05 AM   #67
vin63
vin63's Avatar
Primer on the smaller parts and bed.
Old 05-18-2015, 09:09 AM   #68
66-PMD-GMC
66-PMD-GMC's Avatar
Awesome
Projects..
440CID 2X4 Pontiac
Old 05-21-2015, 02:33 PM   #69
greg65
greg65's Avatar
subscribed.
Nice work
1965 c-10 swb
1997 c-1500 extended cab
2004 tahoe
1993 mustang gt
BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653
greg65 is offline   Reply With Quote
Old 06-29-2015, 08:25 AM   #70
vin63
vin63's Avatar
Working on a couple projects at the same time, so I've been a little laxed on posting progress photos. Small parts were shot. The bed is next.
Old 06-29-2015, 09:02 AM   #71
66-PMD-GMC
66-PMD-GMC's Avatar
I know how it is to be spread thin across several projects...
But the quality certainly has suffered because of it..
That's apparent by the photos... really looks great..
I can't wait to see it done..
Projects..
440CID 2X4 Pontiac
Old 07-01-2015, 12:51 PM   #72
64nlo
64nlo's Avatar
What a beautiful truck!! I'm running into a hell of a problem with mounting my '66 389 in my 64 c10 the issue is mostly with the exhaust. I was thinking about hacking up my headers, but the other issue is that I have to bolt the engine mounts to the cross member and mock up seems to be really high and looks to need some of the cab cut out. Please help!
64nlo is offline   Reply With Quote
Old 07-01-2015, 01:55 PM   #73
vin63
vin63's Avatar
Are you using one of the GM conversion motor mounts? Also, what about the headers is the issue?
Old 07-01-2015, 02:03 PM   #74
vin63
vin63's Avatar
Bed shot last night…
Old 07-01-2015, 02:12 PM   #75
66-PMD-GMC
66-PMD-GMC's Avatar
I honestly never thought I would see green paint that I would like. ..
That truck is going to be gorgeous! !!
AND be pontiac powered!
Nice
Projects..
440CID 2X4 Pontiac
