Old 07-06-2015, 12:43 AM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Recommend brake lines and shocks for 71 Chevy?
71 Chevy Deluxe, short/fleet, 1/2 ton, 2WD. Rear drums, front disc. ...Trying to stick to original as much as possible. What/where do you recommend for:
1. Brake lines and junctions. I'll restore what I've got, but a few items need to be replaced.
2. Emergency brake linkage. I'll restore what I've got, but a few items need to be replaced.
3. Shocks (so far no plans to lower).
Thank you for any suggestions.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-06-2015, 07:37 AM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Recommend brake lines and shocks for 71 Chevy?
I would go with Monroe Sensa-Trac Shocks. They are a good quality shock and not that expensive. I put a set on my last truck and was quite satisfied with the ride and handling. Another suggestion is if there isn't one on your truck add a front sway bar.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-06-2015, 02:13 PM   #3
71CHEVYSHORTBED402
Thank you. It does have a sway bar. Apparently that's post-production?
Tony
