Old 07-12-2015, 11:50 PM   #1
billsbowtie
billsbowtie's Avatar
71 high hump cab and 71 blazer patches f/s
couple patches already cut patch that goes around where the high hump was removed with threaded bolt wholes $20.00 plus $15.00 shipping.
other patch is where gas pedel bolts to floor/firewall if someone is useing a 71/72 gas pedel on a 67/70 this patch has the threaded bolt wholes for the 71/72 gas pedel $25.00 shipped.
if you need a patch post a pic. and i will see if it is good on my cab and give you a price on it. 6" by 6" patches $10.00 plus $10.00 shipping 12" by 12" patches $15.00 plus $10.00 shipping .
i have 67/72 chevy truck parts f/s.
billsbowtie is offline   Reply With Quote
Old 07-12-2015, 11:50 PM   #2
billsbowtie
Re: 71 high hump cab and 71 blazer patches f/s
Old 07-12-2015, 11:57 PM   #3
billsbowtie
this cab has been patched on before so the outer floor have been patched before and the cab corners have had work done to them so may not be any good.
Old 07-12-2015, 11:58 PM   #4
billsbowtie
Old 07-12-2015, 11:59 PM   #5
billsbowtie
non a/c dash complete $100.00 plus $25.00 shipping.
Old 07-13-2015, 12:04 AM   #6
billsbowtie
Old 07-13-2015, 12:12 AM   #7
billsbowtie
Old 07-13-2015, 12:12 AM   #8
billsbowtie
Old 07-13-2015, 12:15 AM   #9
billsbowtie
Old 07-13-2015, 12:15 AM   #10
billsbowtie
Old 07-13-2015, 12:18 AM   #11
billsbowtie
Old 07-13-2015, 12:19 AM   #12
billsbowtie
Old 07-13-2015, 12:24 AM   #13
billsbowtie
blazer doors bad windshield frame bad in corners good for patches only.
Old 07-13-2015, 12:24 AM   #14
billsbowtie
Old 07-13-2015, 12:25 AM   #15
billsbowtie
Old 07-13-2015, 01:00 AM   #16
lchall
Interested in the pedal patch and the area highlighted in the picture shipped to 63303.
Thanks - Chad
1967 Chevy SWB
1972 Chevy SWB
1972 Chevy SWB K20 4x4
1991 Ford F-150
2013 Dodge Ram 1500 4x4
lchall is offline   Reply With Quote
Old 07-13-2015, 02:26 AM   #17
billsbowtie
ok chad could you measure how far you need from the hole in firewall where the outer heater box use to be. thanks bill
Old 07-13-2015, 07:18 AM   #18
Grumpy old man
Grumpy old man's Avatar
Hi ,How much for whats left of the Blazer ? Title ?
Old 07-13-2015, 09:52 AM   #19
lchall
I'm going to use on my firewall on my 67. Its stamped a little different in this area and I already shaved the heater holes so its a little hard to measure. My engine is in the rear mounting holes and hits the firewall.
Took a pic of my firewall and outlined what I am looking for. This is probably way more than I need to modify, but want to make sure I have more than enough to work with. The lower line is a little hard to see with the angle, but looking for 2-3 inches past the lower stamping line.
1967 Chevy SWB
1972 Chevy SWB
1991 Ford F-150
Old 07-13-2015, 11:27 AM   #20
Are you selling the bell housing on the Blazer?
Old 07-13-2015, 10:58 PM   #21
billsbowtie
Grumpy old man i sent you a pm on whats left of blazer.
lchall there is a cut mark that runs into the piece you need look at # 11 in this tread.
special-K tim i have priced whats left of blazer if he doesn't take it i will let you no something on bell housing.
Old 07-13-2015, 11:48 PM   #22
lchall
I see it in the lower right side. I think it'll be ok, I'm not expecting to actually need anywhere near that much. Just figure if I'm going to get a piece cut I might as well make it plenty big. Just need to make sure the rest of it is straight/good. Absolute worst case it would only have a few inches of the cut I'd need to weld up.
1967 Chevy SWB
1972 Chevy SWB
1991 Ford F-150
Old 07-14-2015, 12:08 AM   #23
billsbowtie
ok i will see about getting it off now how about $15.00 for patch and $10.00 shipping with the other patch you wanted if i can fit them together i will take a little off shipping total.
Old 07-14-2015, 12:18 AM   #24
lchall
Ok, that sounds good to me.
Thanks - Chad
1967 Chevy SWB
1972 Chevy SWB
1991 Ford F-150
Old 07-14-2015, 09:11 PM   #25
billsbowtie
lchall patch cut pm sent.
anyone else a patch.
