Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 06-25-2015, 08:54 AM   #76
Rich84
Rich84's Avatar
Re: DBW pedal mounting bracket
It's an LQ4 with Fbody oil pan and exhaust manifolds. So I guess it's a Camaro trapped in a box truck.LOL
Rich84 is online now   Reply With Quote
Old 06-25-2015, 09:21 AM   #77
Hart_Rod
Hart_Rod's Avatar
Originally Posted by Rich84 View Post
This is the pedal I have..
Attachment 1419028
Attachment 1419029
Attachment 1419030
Sorry about the picture quality..Little too much wine last night.
Lol, It looks like the flat bracket might work for you. You will probably have to redrill some holes though.
Hart_Rod is offline   Reply With Quote
Old 06-26-2015, 12:22 PM   #78
StingRay
StingRay's Avatar
Do you have any left for the truck style pedal? I'd like one. Can you ship to Canada?
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 06-26-2015, 12:24 PM   #79
Hart_Rod
Hart_Rod's Avatar
Are you talking about the bent bracket for the 03-07 truck pedal?
This one: http://67-72chevytrucks.com/vboard/s...d.php?t=651123
If so, I do have some left. What is required to ship it to Canada?
Old 06-27-2015, 12:36 AM   #80
StingRay
StingRay's Avatar
Yes the bent one. I like my stuff sent USPS. You will likely have to fill out a declaration of value, what the part is and where it was made. Should be about it. I'm happy to pay some extra handling for your trouble.
Canada
Old 06-27-2015, 07:51 AM   #81
Hart_Rod
Hart_Rod's Avatar
PM me your address and I'll talk to the post office.
Old 07-14-2015, 09:05 AM   #82
Hart_Rod
Hart_Rod's Avatar
Thanks for the purchase! Only 10 Left!
Old 07-14-2015, 11:21 AM   #83
StingRay
StingRay's Avatar
Got it yesterday. It looks great. Thanks a bunch
Canada
Old 09-26-2015, 05:40 PM   #84
Blazn C5
Blazn C5's Avatar
Are these still available ? I would like to package one with the hood brackets if you do.
Thanks, Anthony
Blazn C5 is offline   Reply With Quote
Old 09-26-2015, 06:00 PM   #85
Hart_Rod
Hart_Rod's Avatar
Thanks, Anthony
Yes I Do! Text me.
Old 10-23-2015, 12:16 PM   #86
hozeman469
Need one for a 05 truck pedal if you have one available.
hozeman469 is offline   Reply With Quote
Old 10-23-2015, 01:09 PM   #87
Hart_Rod
Hart_Rod's Avatar
Yes sir! PM sent and here's a link to that thread: http://67-72chevytrucks.com/vboard/s...d.php?t=651123
Old 10-23-2015, 04:41 PM   #88
hozeman469
Ok,Thanks
Old 10-29-2015, 12:43 AM   #89
copywritten
CopyWritten
copywritten's Avatar
Intestred in a bracket for my 86. I have a pedal from an 05 Cadillac Escalade EXT.
copywritten is offline   Reply With Quote
Old 10-29-2015, 09:08 AM   #90
Hart_Rod
Hart_Rod's Avatar
I don't make a bracket specifically for the 73-87, but some guys have modified my 67-72 bracket to work on the 73-87. LMK
Old 01-07-2016, 12:02 PM   #91
Hart_Rod
Hart_Rod's Avatar
For all of the guys looking for a pedal bracket to work with the 73-87 trucks, here's a thread that has some great info in it:
http://67-72chevytrucks.com/vboard/s...d.php?t=692222
http://www.hotrodlane.cc/Streetstories/81%20swap.pdf
Apparently a factory OEM gas pedal from a 94-02 CHEVY GMC 6.5L V8 DIESEL (PN 15984422) will bolt right in. You have to repin a few wires, but it's supposed to be pretty straight forward.
The .pdf file has a complete discussion on the entire install, but here is a small snippet:
"This is the installed Pedal Position Sensor AKA Drive by Wire pedal.
I used one from a 1998 6.5 Diesel truck as it bolts right up and is a closer match
than the later Silverado pedal. A couple of the wires do have to be moved as it is
internally wired different. Basically, there are three different sensors in the pedal
and the PCM compares all three of these to determine how much throttle
opening the drivers is requiring. If these three sensors do not agree, a code will
be set and the PCM takes a best guess at what the throttle opening should be.
The gray wire was moved from location A to J, the Brown wire was moved from
location E to A and the Yellow wire was moved from location J to E. I also had to
add a slot in the connector plug so it would plug into the pedal."
PLEASE NOTE I HAVEN'T TRIED THIS ON A TRUCK, I'M JUST PASSING THE INFORMATION. DO YOUR HOMEWORK BEFORE YOU PURCHASE ANY PARTS!!!!
Good luck with your LS Swap!!!
Old 04-05-2016, 10:06 AM   #92
Rust_phoenix
Rust_phoenix's Avatar
Rob, i would like one of your corvette pedal brackets, i have sent a Paypal payment to the email listed on page 1
Paypal: robhartley@aol.com, enter "CPB" in message block.
Thank you!
My build: Project "Lazarus" 8.1 Vortec and Allison in a 72 swb k10
http://67-72chevytrucks.com/vboard/s...d.php?t=555878
Rust_phoenix is offline   Reply With Quote
Old 04-05-2016, 10:22 AM   #93
Hart_Rod
Hart_Rod's Avatar
Thank you!
It should ship today. Thanks!
Old 04-08-2016, 09:13 PM   #94
Rust_phoenix
Rob, I received my bracket today, excellent service, Thank You!
Old 04-09-2016, 01:37 AM   #95
shenk10
shenk10's Avatar
Rob, just sent a Paypal payment for a Gen IV pedal bracket for a 72. Thank you.
Jordan
1972 Chevy K5 Blazer, 6" Lift, 35x13.5R15, 6.0/6L80E/NP205
1982 Chevy C10 SWB, 2006 LS2/4l70e
In progress....
http://67-72chevytrucks.com/vboard/s...d.php?t=439860
shenk10 is offline   Reply With Quote
Old 04-09-2016, 08:01 PM   #96
Hart_Rod
Hart_Rod's Avatar
Glad you like it! Thanks again.
Your bracket shipped today via the USPS. Thanks!
Rob
Old 11-15-2016, 09:12 AM   #97
Hart_Rod
Hart_Rod's Avatar
bump
Old 11-22-2016, 07:09 PM   #98
shenk10
shenk10's Avatar
Just wanted to say that interestingly enough I too had the same problem as "derotoreut" with my holes not lining up and my blazer is a '72 purchased in Texas. It wasn't a problem for me, I just lined up the bottom hole, drilled 2 new holes and welded up the old ones. I wonder if it would be location, mine was made in April of 72 in Flint.
Jordan
In progress....
Old 12-25-2016, 01:54 AM   #99
brian1971
brian1971's Avatar
Hi Rob,
I need one of the Corvette pedal brackets,I'm going to send you the payment in a few minutes.
Thanks Brian
1971 c10 custom deluxe fleetside swb
LS3 w/BTR stage IV cam,4L85E w/3600 stall
67-72chevytrucks.com/vboard/showthread.php?t=558024
brian1971 is offline   Reply With Quote
Old 12-25-2016, 09:10 AM   #100
Hart_Rod
Hart_Rod's Avatar
Originally Posted by brian1971 View Post
Hi Rob,
Thanks Brian
Got it Brian, thanks! It will be in the mail Tuesday. Let me know if you have any questions. Merry Christmas!
