Old 07-14-2015, 01:41 PM   #1
summitflier
summitflier's Avatar
Just another 68 side stepper
Mine wasn't in real bad shape to begin with. Here are a few pics before I started.
Yes, I know it looks like a 69-70, but it really is a 68. Someone changed the fenders, hood and grille before I got it.
68 C10 SSB 383
12 Charger 6.4L
12 Accord 3.5L (Wife's ride)
05 Ram 1500 5.7L
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545
summitflier is offline   Reply With Quote
Old 07-14-2015, 01:43 PM   #2
summitflier
Re: Just another 68 side stepper
Finally got around to tearing things apart last week.
68 C10 SSB 383
12 Charger 6.4L
05 Ram 1500 5.7L
Old 07-14-2015, 01:50 PM   #3
summitflier
Found a little rust on the rocker panel. Got the front suspension removed.
68 C10 SSB 383
12 Charger 6.4L
05 Ram 1500 5.7L
Old 07-14-2015, 01:55 PM   #4
summitflier
The tired old 350 was a good motor, but it was starting to smoke some.
(Has a LOTTTTTT of miles).
Going with a 383 stroker. My radiator was full of rust, so I'm going with a new aluminum, with dual elec fans.
68 C10 SSB 383
12 Charger 6.4L
05 Ram 1500 5.7L
Old 07-14-2015, 01:59 PM   #5
summitflier
The old Lexar wire wheels had to go. The pro comp wheels will be a nice touch I think. 18x8 front, 18x9.5 rear. 255's fronts, 275's rear.
68 C10 SSB 383
12 Charger 6.4L
05 Ram 1500 5.7L
Old 07-14-2015, 02:03 PM   #6
nuke1
nuke1's Avatar
good start so far!!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 07-14-2015, 02:06 PM   #7
summitflier
Got a Scott's IFS to replace my front suspension. Yes, I know I already had an IFS. But it needed new springs, new ball joints. Also I am switching to disc brakes. Also, I am adding power steering. Also I am changing from a 6 bolt pattern to a 5 on 5 bolt pattern. Yes I could do all of this with the stock suspension, but by the time I did all of that, the cost wasn't really that different. Also I lose almost 80 pounds in weight.
68 C10 SSB 383
12 Charger 6.4L
05 Ram 1500 5.7L
Old 07-14-2015, 02:50 PM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
Who could do such a thing to a 68? I mean, swap a 68 nose onto a 69-72, but the reverse? BLASPHEMY!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-14-2015, 03:03 PM   #9
chopnchaneled
chopnchaneled's Avatar
You are going to change it back to a 68 RIGHT!
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 07-14-2015, 10:28 PM   #10
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
oh wow! YOu're really doing it up right. You should put a '67 hood on it, they're the coolest, then again I'm partial. Good luck with it. I have a friend in Bonney Lake, I'll have to check out your lake sometime, bet it's nice out there right now.
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline   Reply With Quote
Old 07-14-2015, 11:29 PM   #11
summitflier
Thanks... I guess I just consider this a medium build.
We all just do the best we can. On one hand I envy those guys with custom frames and 25k LS motors and the wheels that are $800 a piece. On the other hand, I envy those guys who have a knack for doing it all the old fashioned way or making do with whatever they have laying around so it doesn't take a lot of $$ but it does take some talent.
When I bought the truck, I thought it was a 69 or 70. It was only when I looked at the VIN and title I realized it was a 68. I'm not against going back to the 67/68 look, but I would have to change both the front fenders, the hood and the grille, (possibly even the radiator tower, but I don't think so). It starts to add up in a hurry.
This week, the plan is to get almost everything sand blasted (even the frame). Then start getting primer on everything. I have mixed feeling about powder coating the frame. I'm not sure I can justify the cost vs the advantage. I may end up just going with Krylon or Rustoleum in a rattle can for the frame and trailing arms.
After that, the plan is to put the 5x5 axles I bought into the 12 bolt axle housing. I'm also replacing the drums with disc's on the rear axle and putting a Moser posi (spool type) unit in.
If everything goes as planned, should have a rolling chassis in less than 2 weeks.
68 C10 SSB 383
12 Charger 6.4L
05 Ram 1500 5.7L
Old 07-14-2015, 11:32 PM   #12
summitflier
I live right at Bonney Lake, but the truck and garage are at a friends in Moses Lake, that's where I'm doing all this. (Contracting in the area). I used to live in Hillsboro not to far from you.
68 C10 SSB 383
12 Charger 6.4L
05 Ram 1500 5.7L
Old 07-15-2015, 12:46 PM   #13
Xeen
Xeen's Avatar
That is a very nice engine and I really like the upgraded front suspension.
Do you plan to add a sway bar to the rear to further improve handling?
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 07-15-2015, 12:53 PM   #14
summitflier
Yes, eventually. The bed came without any of the floor rails.
I'll have to buy some, but I'm not even sure how to mount them.
Anyone have a picture for step side wood bed?
Only the bed front and tailgate were actually bolted to the frame,
the side of the bed (and fenders) were just "floating" above the frame.
68 C10 SSB 383
12 Charger 6.4L
05 Ram 1500 5.7L
Old 07-15-2015, 06:13 PM   #15
Dustmaker65
Dustmaker65's Avatar
Gotta ask....How much that front end set up costs???
That is bad azz!
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 07-17-2015, 01:33 PM   #16
Justin@EntropyRad
Justin@EntropyRad's Avatar
Cool project! Dig the IFS
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 07-17-2015, 06:21 PM   #17
BlackHaze
BlackHaze's Avatar
great looking truck and wow i want that engine lol shinny
1971 Chevy Wrecker 350 4 Speed With Holmes 440 Bed. ps,pb but no air
BlackHaze is offline   Reply With Quote
Old 07-27-2015, 12:16 PM   #18
summitflier
Finally got the cab off. Removed the rear trailing arms.
Bring a 1 1/8 socket with a long cheater bar, and bring your lunch.
I don't think they've ever been removed in the last 47 years.
The cab wasn't as heavy as I thought. It's a load, but 3 people can move it short distances in a pinch.
68 C10 SSB 383
12 Charger 6.4L
05 Ram 1500 5.7L
Old 07-27-2015, 08:46 PM   #19
Xeen
Xeen's Avatar
LOL! I broke two Craftsman 1/2" drive wrenches before I switched to a 3/4" drive socket and a breaker bar and a 2 ft. cheater bar.
Old 07-28-2015, 12:28 PM   #20
summitflier
Got the rear trailing arms and axle apart.
A word to the wise... (I'm amazed I've never heard about this on any of the other build threads I've read through).
When you are taking out the coil spring retainer bolts, be careful. The idea was to gradually loosen the bolt until the pressure was off the retainer.
However, the bolt broke after about a quarter turn. The coil spring jumped out and gave me a little bruise on the ribs.
68 C10 SSB 383
12 Charger 6.4L
05 Ram 1500 5.7L
Old 07-28-2015, 12:29 PM   #21
summitflier
Sure... now you tell me.
68 C10 SSB 383
12 Charger 6.4L
05 Ram 1500 5.7L
Old 07-28-2015, 03:19 PM   #22
Hammerforhire
Looking good, I'll keep watching your progress. Yeah those trailing arm bolts kick my butt too.
Hammerforhire is offline   Reply With Quote
Old 07-28-2015, 04:10 PM   #23
srvhemi
srvhemi's Avatar
That motor is sooo sweet. no doubt, that will smoke the tires off.
IF PLAN "A" DIDNT WORK, THE ALPHABET HAS 25 MORE COOL LETTERS.
1999 Dodge Ram Sport 1500 4x4 (my baby)
2013 Dodge Durango R/T (wifes ride)
2015 Dodge Challenger HELLCAT (my next car)
MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...=1#post7250442
srvhemi is offline   Reply With Quote
Old 07-28-2015, 04:41 PM   #24
Advanced Design
Advanced Design's Avatar
Cool build! Tagging along.
I like the IFS. What are the rear suspension plans?
Advanced Design is offline   Reply With Quote
Old 07-28-2015, 09:16 PM   #25
swamp rat
swamp rat's Avatar
Watching this one!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
