1961 crewcab
Re: '60-'62 Power Brake Booster Adapter Bracket
which one will I need for a 60-62 firewall that was set up for hydraulic clutch, but is now a standard (63-66 style) clutch?
getting ahead of myself here , but I am not sure if I will have to change out the pedal support from 61 to 63-66 with the clutch change as well....not sure if that will make a difference with the bracket or not? also not sure if I am going with hydro boost , or regular power brakes, with your bracket(s) do either of them still need the rod from the pedal to the booster shortened/lengthened? thanks.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
