11-10-2014, 10:11 PM | #76 |
Updated Dirty Dianah
Motor/transmission:6.0 LQ4/T-56 Fuel tank: 20 gallon aluminum fuel cell mid frame, under lifted floor Motor mounts: Dirty Dingo/75 Motor Mounts Tranny mount: Custom Oil pan: Stock LQ4 Radiator: 4-core aluminum Shift linkage: Hurst/F-body Exhaust manifolds: BBK Shorty Headers Gears:3:73 Rear End:12 bolt, LSD Tire size: 28" Bagged:Yes Running:Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=563056 Carb or FI:FI Go Fast: Preparing for Twin Turbo
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual Last edited by 502ms; 11-10-2014 at 10:18 PM. |
11-20-2014, 07:06 PM | #77 |
Re: LSX swappers what ya got?!?!
Guys I finally have a solution for people wanting an easy way to mount a truck/SUV drive by wire pedal in a 67-72 truck. Check out my thread:
http://67-72chevytrucks.com/vboard/s...40#post6926040
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-23-2014, 05:52 PM | #78 |
model: 51 3100 swb
motor/trans: 04 5.3 4l60e exhaust: stainless block hugger headers, ebay shifter: lokar floor shift column: ididit gauges: dakota digital VHX motor mounts: cpp trans mount: cpp front suspension: tci rear diff: s10 4x4 3.42 fuel tank: 36 chevy truck fuel pump: tanks ink in tank radiator: champion |
11-28-2014, 02:29 PM | #79 |
Updated for the K10
Model: 84 K10 Motor/transmission/transfer case: 5.3, SM465, NP205. Fuel tank: Stock 81 K5 Blazer tank modified for an 03 Silverado Pump. Motor mounts: Advanced adapter plates, stock mounts. Tranny mount: Stock. Oil pan: Truck. Radiator: Stock with 98 windstar fans Shift linkage: N/A Headers: Schoenfeld 1302LS1 Gears: 3.73 Rear End: 10 bolt front, 14 bolt sf rear. Tire size: 35" Bagged: N/A Running: Like a BOSS!! Build thread: 84 K10 Custom Deluxe 5.3 build Carb or FI: EFI Go Fast: Flat topped 4.8 pistons, 10.4 compression, Schoenfeld 1302LS1 Headers, LS9 Cam. Build Videos Here Project Chevy K10 |
03-22-2015, 09:51 AM | #80 |
Model: 1979 GMC C1500 S/B
Motor: 5.3, 700R4 Fuel tank: stock with external Fuel pump Motor mounts: Hooker adapters/stock BBC engine side (had to relieve pass side due to AC provisions on 5.3 block) Tranny mount: Stock. Oil pan: Stock 5.3 truck Radiator: aluminum direct fit (summit racing) Shift linkage: stock auto- so far no exhaust clearance issues Headers: do not fit-hit pass side firewall due to head offset on 5.3 (and mt location) Gears: 3.73 richmond/eaton posi locker Rear End: 12 bolt Tire size: 255/70R-15 Stock rims Bagged: N/A Running: Not Yet Build thread: need one Carb or FI: Carb; Edel-7118 LS kit; 600 CFM carb Still hooking everything up |
03-23-2015, 12:10 PM | #81 | |
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
04-10-2015, 08:32 PM | #82 |
Model: 86 SWB step side
Motor/transmission: 2004 LQ9/2005 4L80 w/ Yank Pro Truck 3600 stall Fuel tank: Stock 87 Motor mounts: DD Sliders w/ original SBC mounts Tranny mount: Summit universal 3" offset Oil pan: CTS-V Radiator: Stock 87 454 Shift linkage: Lokar Rod shifter Exhaust manifolds: Schoenfeld 1302LS1 LS1/LS7 Engine Swap Long Tube Header Gears: 3.42 (for now) Rear End: 10 bolt Tire size: 255/40/20-275/45/20 Bagged: No Running: YES Build thread: Not yet Carb or FI: FI Go Fast: Comp 231/235 .630/.610 cam, 799 heads (10.9:1 comp)
'83 Silverado Step Side '85 GMC short bed. '86 Chevy Step Side Custom Deluxe LQ9/4L80 swap (SOLD) Last edited by Tilt; 10-22-2015 at 07:58 PM. |
04-23-2015, 08:48 PM | #83 |
Model: 1969 4wd Suburban
Motor/transmission: 2005 LM7 5.3 / 4L80e stage 3 1500 stall Fuel tank: stock Motor mounts: ECB Tranny mount: factory 1969 Oil pan: stock Radiator: Aluminum 4 core / dual fans Shift linkage: Shift Link Exhaust manifolds: LS3 camaro Gears: 3:73 Rear End: 12 Bolt posi Tire size: 295-65/15 Bagged: no Running: Yes Build thread: Carb or FI: FI multitech Go Fast:Just going first the transfer case is a np205 with 32 spline upgrade, 2 1/2 pipe from front to rear with Borlas mufflers complete dualed.
Ralph L. Jasper 69 4x4 Suburban PTO winch(NAVY) 13 GMC Ext cab 12 Ford Fusion SE(wife) MAI Interior shop Last edited by engairuph; 05-27-2015 at 08:44 PM. |
04-23-2015, 09:08 PM | #84 |
05-27-2015, 05:10 PM | #85 |
Model: 1968 C10 SWB
Motor/transmission: 2013 LC9/ 2014 Camaro SS TR6060 Fuel tank: No Limit EFi setup mounted under bed Motor mounts: CPP sliders Tranny mount: CPP w/ poly Oil pan: CTS-V Radiator: OEM replacement w/ dual 16" SPAL Fan Shift linkage: Core/Hurst shifter Exhaust manifolds: Doug's Tri-Y Gears: 4:11 Rear End: Mark Williams rebuilt 12 bolt (C-clip elim, eaton posi) Tire size: 255/45R20 Front 295/45R20 Rear Bagged: NO Running: YESSS! Build thread: None Carb or FI: MSD Atomic EFi Go Fast: NLE sways, panhard, shock relocation, & power R & P. CPP big brake w/ hydroboost, Ridetech HQ shocks all four corners. Last edited by Bowtiguy; 12-02-2015 at 05:03 PM. |
08-06-2015, 01:59 PM | #86 |
Model: 1970 SWB C10
Motor: 2001 Silverado 5.3 with 221/228 600/605 112+2 cam Transmission: 1997 c3500 4L80e, hd2 shift kit and circle D 3000 stall Oil pan: 2001 Silverado, hangs an inch below the factory crossmember Motor mounts: ECE Tranny mount: ECE Tranny Tunnel: Low hump Radiator: Champion for Big Block w/ 2002 camaro fans Fuel tank: Jeep Cherokee tank with 87 Chevy TBI sending unit and ep241 pump... don't think it's enough pump Shift linkage: 72 c30 floor shift column... nothing on the column. 2001 silverado shift cable, 1967 C10 E-brake used as shifter. Exhaust manifolds: 1998 camaro Gears: 3.73 Tire size: 29 Carb or EFI: EFI Bagged: no, 5.5/8 static Running: yes, drove the second half of the 2015 Power Tour in it. Go Fast: just a cam and tune
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped 1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant |
09-10-2015, 11:23 AM | #87 |
Model: 1972 Cheyenne SWB Motor/transmission: 5.3l / 4L60e from a 2005 Avalanche Fuel tank: Boyd Welding Motor mounts: Stock SBC stands & mounts with eBay plates Tranny mount: Stock Oil pan: Cadillac CTS-V Radiator: Champion LS Swap 3 Row Shift linkage: Modified stock Exhaust manifolds: BBK Camaro Headers Gears: Stock 3.08 Rear End: Stock 10 bolt Tire size: 275/60R15 Bagged: Yes – Porterbuilt Stage 1 front, Stage 2 rear Running: YES Build thread: http://67-72chevytrucks.com/vboard/s...22887&posted=1 Carb or FI: FI Go Fast: Brian Tooley Racing Stage 3 Cam 218/224/.553/.553 113+3
Matt Criswell - Lyman, SC 1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE |
09-10-2015, 12:21 PM | #88 |
Nice ride!
I like the coil covers.
09-11-2015, 06:54 AM | #89 |
1979 GMC S/B
2003 5.3/4L60E dirty dingo mts Hedman Husler headers( i will update Picture) CPP tranny Cross member Stock Driveshaft 3.73 posi Dakota Digital VHX Vintage air (on order) |
09-11-2015, 02:07 PM | #90 | |
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" 1980 C20 Long to short & static drop "Square One" |
09-11-2015, 02:45 PM | #91 |
Ill add mine.
Model: 1965 C10 Motor/transmission: 2005 4.8/4L60E Fuel tank: Boyds Non-EFI Motor mounts: POL Tranny mount: CPP Oil pan: Stock Truck Radiator: Champion 2 Row Shift linkage: Locar Exhaust manifolds: Sanderson CSLS1 Shorties Gears: 3.73 Rear End: 12 Bolt Tire size: 29 Bagged: Rear only Running: Oh yes! Build thread: None Carb or FI: FI Go Fast: Nothing, pure stock.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-10-2015, 11:16 PM | #92 |
Model: 1969 C10, original paint NC truck
Motor/transmission: 2008 6.0L LS2 from a TBSS w/ 4L70e with e38 ECM Fuel tank: Tanks Inc. Motor mounts: CPP Tranny mount: CPP Oil pan: CTS-V Radiator: Griffin Aluminum Shift linkage: Custom Fab Exhaust manifolds: Headers Gears: 4.10 Rear End: 12 Bolt Tire size: 31 Bagged: Accuair eLevel with dual viar compressors and 5 gal tank Running: Yes, but working out some tuning issues Build thread: None Carb or FI: FI Go Fast: Nothing, pure stock LS2 Other goodies: Dakota Digital VHX Gages 4 wheel disc brakes: CPP 2 1/2" drop spindle: CPP Porterbuilt C-Notch Porterbuilt Stage 2 rear kit Push button start: Painless Vintage Air A/C Detroit Steel Wheels (20x8 and 20x9) Auburn Locker Retrosound Stereo with Bluetooth Tilt steering wheel: CPP Cruise control: Custom
'69 C10 | LS2 | 4L70e | 4 Wheel Disc Brakes | Accuair eLevel | 20" steel wheels | Porterbuilt goodies | Push Button Start | Tilt | Cruise '79 Burbo | 2wd | 8100 Vortec/Allison swap | A/C | soon to be bagged. |
11-20-2015, 12:58 AM | #93 |
Model: 1981 1/2 ton Motor/transmission: 2005 LS2/4L65e from GTO Fuel tank: Stock saddle with walbro 255 intank Motor mounts: Home made Tranny mount: Also home made Oil pan: F body Radiator: Stock 05 GTO radiator and fans Shift linkage: Stock modified Exhaust manifolds: Trail Blazer SS Pacesetter headers Gears: 3.40 Rear End: 1974 12 bolt Tire size: 245 40 20 305 35 20 Bagged: Static 6/8 drop Running: Damn skippy Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=656792 Carb or FI: FI Go Fast: My fat foot...for now. |
12-02-2015, 11:41 AM | #94 |
Hello everyone I see a lot of ppl using tbss manifolds did you have to cut frame or modify anything ? Thanks
12-03-2015, 02:46 PM | #95 |
Model: 1970 C10 LWB
Motor/transmission: 2010 L96/2004 4L80E Fuel tank: Byod Fuel Cell Motor mounts: Dirty Dingo Oil pan: Stock (currently) Radiator: Entropy LSX Radiator w/ dual elec fans Shift linkage: Lokar Adjustable Column shift linkage Exhaust manifolds: Doug's Tri-Y Gears: 3:07 Rear End: '70 12 bolt Tire size: In Process Bagged: NO Running: YES! Build thread: None Carb or FI: FI Go Fast: Stock for now, Cam in future? |
12-09-2015, 02:00 PM | #96 |
Model: 1969 c/10 stepside
engine: 2001 lq4 6.0, stroked to 408 trans: 4l80e diff: Stock 12bolt with 3.73 posi frame: Boxed & "x" braced suspension: 4-wheel coilovers with new front crossmenber & 4-link fatbar all from "no limit" steering: Power rack & pinion fuel tank: Boyd's 19 gallon relocated to rear of frame , used corvette fuel pressure regulator/filter to delete the return line from engine just fired engine for first time this past weekend, still have several body mods, driveshaft, interior, gages, wheels/tires, bed, climate control, paint and numerous other tidbits....gee and i thought i was making headway |
12-09-2015, 10:34 PM | #97 |
Model: 94 S10
Motor/transmission: 5.3 NV3500 5speed Fuel tank: stock Motor mounts: current performance poly urethane Tranny mount: stock Oil pan: GM muscle car pan Radiator: S10 V6 HD w dodge Intrepid dual elec fans Exhaust manifolds: Sanderson shorty headers Rear End: changing out to 8.8 w 373:1 Build thread: http://67-72chevytrucks.com/vboard/s....php?p=7400447 Carb or FI: fuel inj w truck intake |
12-14-2015, 11:39 AM | #98 |
Model: 1972 C10 Stepside
Motor: 2014 6.2 (Camaro) Transmission: 2014 6L80E Oil pan: 2008 Cadilac CTS-V Motor mounts: ECE Tranny mount: Porterbuilt Inner Frame Stiffner Tranny Tunnel: High hump Radiator: Entropy dual pass with electric fans Fuel tank: Boyd's Welding stainless in tank pump Shift linkage: TBD Exhaust manifolds: Doug Thorley 324Ys Gears: TBD Tire size: TBD Carb or EFI: EFI Bagged: no Running: not yet... Go Fast: TBD Build thread: http://67-72chevytrucks.com/vboard/s....php?p=5532411
Ryan... 1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain http://67-72chevytrucks.com/vboard/s...11#post5532411 |
02-07-2016, 06:47 AM | #99 |
Model: 1969 C10
Body mods: 67 GMC front clip, bed cut 23 inches, unibodied, mild chop Motor: 2005 6.0 LQ4 bored .020, flat tops, 224R cam on 112 centers Transmission: 2005 4L60E Oil pan: silverado Radiator: 2001 TA with stock dual fans Fuel tank: TANKS inc poly for 48 Ford Exhaust manifolds: Doug Thorley long tube Gears: 3,73 Tire size: 285/35r20 rear, 255/40r20 front Carb or EFI: EFI Bagged: no Running: not yet...
56 GMC BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=368649 69 long bed Chevy turned 67 gmc jimmy roadster: https://67-72chevytrucks.com/vboard/...d.php?t=851167 |
10-07-2016, 11:04 AM | #100 |
Model: 87 R10
Motor/transmission: LS1/T56 Fuel tank: Stock w/Racetronix 340 pump Motor mounts: Dirty Dingo Tranny mount: Energy Suspension Oil pan: GM Radiator: Afco Shift linkage: Exhaust manifolds: Hedman Headers 1-7/8" Gears: 4:10 Rear End: Stock 10 bolt Tire size: 295/50-15 Bagged: Nope Running: Yes Build thread: http://ls1tech.com/forums/conversion...t56-build.html Carb or FI: Holley HP Go Fast:
My LS/T56 C10 build...http://ls1tech.com/forums/conversion...t56-build.html |
