#51 |
Re: Bagged 1968 Suburban
I will post a pitcure soon but the tank is behind the gas tank and i have one 380 via air compressor mounted on the outside of the frame. Were at the truck nationals in PA till sunday
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#52 | |
Brett ![]() 67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594 72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.) 72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614 YouTube: https://www.youtube.com/@6dee7-7dee2 |
#53 | |
Wide n'Low
![]() Join Date: Jan 2007
Sounds de like a great trip
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
#54 |
I forgot to post pictures of the air tank and compressor opps
Look at what the plow suburban brought home for the summer suburban. 2003 LQ4
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 02-11-2016 at 11:42 PM. |
#55 | |
Well I guess to answer your question the 327 left something to be desired as far as tq and power it did ok once it got rolling and got 10mpg towing the airstream Changing from 3:73 to 3:42 didnt help with towing but if you take into account my rear tire size of 27" that makes the 3:42 comparable to a 2000+ truck with 4:10s The big hills even splitting the gears with the gv I would loose about 10 mph on a hill. It was work dropping and splitting gears so the LQ4 should help alot
#56 |
4 broken exhaust studs turned into bolts after welding either a washer then nut or just a nut as needed to remove them. I was really scared how this would work....... went way too well !!! all of them out in under 1/2 hour.
#57 |
![]() Join Date: Mar 2015
Nice Burb!!
I'm in! I'm hoping to get started on mine someday soon and plan to do many of the same mods you've done to yours. Thanks for posting!
56 Chevy step-side 68 Chevy Suburban 69 Corvette Stingray 00 BMW 325 (Daily driver) 09 BMW M3 18 GMC Acadia (Wife's daily driver) |
#58 |
Great Burb. Going to be great with that engine!
![]() 1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
#59 |
![]() Join Date: Jul 2012
The engine swap will be really nice. We love ours.
Nice work with the bolt removal. I was the same way first one I did and it works well. |
#61 |
Well I got the engine stripped down and cleaned up today. Looks like i should repair the knock sensor wire or replace the harness wire looks pinched.
That's all for today I ordered the Holley ac brackets and the flex plate bushing so the torque converter from the T400 will line up. http://www.ebay.com/itm/LS1-Flexplat...-/251723077551 I need to learn how I can take the signal generator from the gearvendors which is 8000 ppm and multiple it to whatever the ls computer needs to see in order to use the drive by wire cruise. . Hopefully I can make time to order the Cadillac cts v oil pan setup tomorrow night. The I will be ready to remove the 327 from the suburban
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 02-19-2016 at 12:20 AM. |
#62 |
My buddie James 68gmcdually was kind enough to let me have a new intake dropped off at his work. This will replace the damaged one that came with the engine.
#63 | |
![]() Join Date: Apr 2005
EDIT: Here's some more options for you: http://www.dakotadigital.com/index.c...cat/cat287.htm
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-19-2016 at 09:28 AM. |
#64 |
I am looking at using the SGI-5E it can take a 8000ppm and convert it to the 128,000 ppm I think that is whats needed for the cruise to work properly ????. I really don't want to have to deal with a electric speedometer.
The company the converts them is called Red Line Gauge Works they charge $450 to convert your stock gauge to a eletrice stepper motor and the od display becomes a digitall display. Its a really neat setup but I would be into $ 900 CDN into one gauge. http://www.dakotadigital.com/index.c...rod/prd126.htm I wanted to attach a pitcure of the crank spacer for anyone else doing this swap onto a older GM transmission
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 02-19-2016 at 09:20 PM. |
#65 | |
Great build btw. You have all the right goodies in there
87 k5 silverado 4x4 350 38k stock 77 k5 Cheyenne 2wd 5.3 4l60e project Last edited by mcnally351; 02-20-2016 at 12:22 AM. |
#66 |
Here is what I order from gm parts depot.ca. Thats the last big hit I hope to take on this swap !
The items you ordered: Qty Product # Price EA 1 Dipstick. Engine Oil Dipstick. 12584737 $21.00 1 Engine Oil Dipstick Tube. Oil tube. Tube. 12584738 $24.64 1 Engine Oil Pan. Oil pan. 12631828 $204.76 1 Engine Oil Pump Pickup Tube. OIL PICK-UP. Suction pipe. 12621299 $84.78 1 Engine Coolant Thermostat Gasket. Engine Coolant Thermostat Housing Gasket. Engine Coolant Thermostat Seal. Engine Coolant Water Inlet Gasket. GASKET. Inlet assy seal. Seal. THERMOSTAT GASKET. Thermostat hsng seal. Thermostat seal. Water inlet seal. 12570307 $3.82 Your order summary: 5 products , 5 items $ 339.00 Shipping To ON, Canada $ 34.95 Tax $ 48.61 Total $ 422.56
#67 |
I will have to remember that website . That oil pan was cheaper than I expected it to be . Nice work . I have a 6.0 burb behind the barn that is waiting to have its driveline plucked. Don't have a donor to put it in yet tho . I'm sure I don't have to tell you it's slim Pickens up in our neck of the woods for anything worth worken on . Keep up the great work I'm following along for sure !
56 gmc 4X4 Cummins 5 spd 60F 70R 2005 Ram 3500 DRW cummins 4X4. 2006 Conolift 9/15. 2011 F 350 winter beater New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new ! My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908 |
#68 |
Well the T400 and Gear Vendors are gone. I am having a 4L80E Built this week I ordered a Dakota Digital EDC-100 for my speedometer until Hart Rods version of gauges are released. I have a week to get this swap nearly complete...
#69 |
C10 Club Tennessee
Why a week to get it done?
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
#70 |
We have a cramping trip booked on the 14 th. The suburban is the perfered tow vehicle
#71 | |
C10 Club Tennessee
#72 |
I would like to come down to TN again. Last time we met up with RUSBUILT and brought a longhorn frame back with this suburban. That trip was one never to forget...No OD 3:73 27" tire no carpet or sound deadingand a junk air ride system.
Truck sure has come a long way If everything work out smoothly with the swap were thinking of going back to the PA Carsile truck nationals.
#73 |
Well I am making some progress. There is no way it will be done by the 14th. I forgot how long running around in town trying to get silly things like a oil filtet can take.
I got the gas pedal modified to fit using original holes. The new pedal angle is a little steeper but I like it. The gas pedal is closer to the same height as the brake pedal. I also got the cruise lever ls71Nova made for me installed. |
#74 |
Here is the gas pedal
#75 |
Got the engine in last night. I need the transmission before I can go any further as the mounts are sliders and I want to try and make the aluminum shaft from the 2003 short box extended cab fit. Its around 3" shorter than the original shaft.
The CTSV oil pan is 1" above the front crossmember. The dirty dingo mounts raise the engine 1/2" over the stock engine height. I have to measure but it looks like the hot rod pan kit would have been flush with the crossmember. 2010 Camaro manifolds and down pipes fit very nice. Just going to tie into existing system for now. |
