Old 09-06-2015, 02:29 PM   #1
iceman777
iceman777's Avatar
radiator upgrade
hi i am running a stock radiator in my 64 c10 and it runs a bit hot so i am wondering what is the best up grade? is there anything that will go straight in with not to much hassle
iceman777 is offline   Reply With Quote
Old 09-06-2015, 05:18 PM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: radiator upgrade
A good aluminum 2 core will cool better. Champion has alot of nice ones available.
Old 09-06-2015, 06:23 PM   #3
ranger danger
ranger danger's Avatar
I would want to know why its overheating! Timing, carb adjustment, clogged radiator fins, bad water pump, thermostat etc??? If it is the radiator then is it leaking, clogged fins???
1969 C20 Suburban "Rez Dog"
Rebuild America one testicle at a time.
US Army 1977-1979 12B Combat Engineer
US Navy 1979-1983 Gunners Mate Guns (GMG)
NRA Life Member
Unrestrained Children in back seats cause Accidents.
Unrestrained Accidents in back seats cause Children.
ranger danger is offline   Reply With Quote
Old 09-06-2015, 11:29 PM   #4
Captainfab
60-66 Nut
What engine is in your truck? Does it have the small I6 radiator or the larger V8/292 radiator? Do you have a fan shroud?
Old 09-07-2015, 01:07 AM   #5
iceman777
iceman777's Avatar
it has a 383 stroker in it,and it has an electric fan that cuts in at around 190 f
Old 09-07-2015, 10:09 AM   #6
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Check out my radiator swap. Im running a 160* stat and it never moves from that temp not matter what im hauling or how fast im going.
http://67-72chevytrucks.com/vboard/s...=508507&page=4
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-07-2015, 10:46 AM   #7
Grizz1963
Grizz1963's Avatar
Depending on your needs, views and who you want to support, or not
Steve Lang of Langeys Hotrod Shop (on FB) mobile 07836 244483 may be able to source what you need once you identify what you need. He brings stuff into the UK at Dollar for Pound including the VAT.
Hope that helps.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 09-07-2015, 11:05 AM   #8
rcnutt
rcnutt's Avatar
+1 on the champion
rcnutt is offline   Reply With Quote
Old 09-07-2015, 11:48 AM   #9
hubcaplarry
Thumbs up Re: radiator upgrade
I just took my original radiator to a reputable repair shop and it was close to 400 bucks for the core/rebuild w/ powerglide. After research looks like Champion is the top dog. Good luck!
HCL
hubcaplarry is offline   Reply With Quote
Old 09-07-2015, 12:27 PM   #10
rcnutt
rcnutt's Avatar
I got my 3 row auto trans champion for 209.00 to my door...ebay
Old 09-07-2015, 01:06 PM   #11
iceman777
iceman777's Avatar
just read yor thread mate looks really good
Old 09-07-2015, 01:34 PM   #12
iceman777
iceman777's Avatar
Hope that helps.
cheers grizz
Old 10-01-2015, 07:26 PM   #13
Jimal
Jimal's Avatar
I just installed a Champion 3-core in my '65 K10. It dropped right in with no drama.
The shroud was fabricated by the PO, and while it doesn't cover everything, I wasn't having overheating problems before (I sprung a small leak, and since this isn't a restoration, a chose a new rad over having the old one fixed. Look for the old in the Classified soon)
Jimal is offline   Reply With Quote
Old 10-02-2015, 04:42 AM   #14
dragon65
read my thread I posted Monday......this radiator perfect fit quick free shipping...under $150 and looks great installed.....with warranty.
http://67-72chevytrucks.com/vboard/s...d.php?t=683738
dragon65 is offline   Reply With Quote
Old 10-02-2015, 06:19 AM   #15
dragon65
Iceman....I just noticed your in England...I am assuming there will be a shipping charge to your location.
I was born in Barry Island Wales...seems we have a bit in common
Old 10-02-2015, 01:13 PM   #16
iceman777
iceman777's Avatar
hey man im in England, i have been in touch champion radiators and they have said a 2 row is what i will need so think im gonna go for that
Old 10-02-2015, 01:35 PM   #17
dragon65
Gotcha...good luck
The one i showed you was a 2 row as well......as long as it works all good!!
Old 10-02-2015, 02:49 PM   #18
jason999
I have been looking at radiators for a week or two. As I understand it, the Champion 2 rows have smaller tubing (5/8"), but there are some 2 row radiators with 1" tubing. I believe that the one I bought was made in the same factory as Champion.
I looked at several, including Champion 3 and 4 row. I ended up buying this
http://www.ebay.com/itm/1963-64-65-6...item2a4ac06a83
It's just $10 more than the 2 row Champion with smaller tubing and some say it's as good or better than the 3 rows with smaller tubing.
I haven't received it yet, but I liked the sellers return policy so I went with it.
It's just something else to consider. If anyone knows more about the 2 row radiators with 1" tubing, please comment.
jason999 is offline   Reply With Quote
Old 10-02-2015, 03:35 PM   #19
DLW
A 2 core radiator with 1 or 1.25" tubes will cool as good or better than a 3 or 4 core with 0.5" tubes, for example. It makes since mathematically.
Champion 2 core uses .75" tubes and their 3 and 4 core's use .63" tubes. Champion also sells American Eagle radiators (the one you bought from ebay), which their 2 and 3 row/core radiators use 1" tubes.
Griffin uses big 1.25" tubes in many of their radiators and so does my Entropy. This is why sometimes a 2 row radiator can be better than a 3 or 4 row with smaller tubes.
IMO, the 2 row radiator you bought with 1" tubes is a better choice than the Champion 2 row with .75" tubes.
DLW is offline   Reply With Quote
Old 10-02-2015, 04:32 PM   #20
jason999
Your numbers sound familiar on the .75" tubes for Champions 2 core. I confused my numbers because I was comparing the Patriot 2 row to Champions 3 row. Thats where I got 1" vs 5/8".
How do you think the Patriot 2 row would compare to the Champion 3 row? I was under the impression that they would be very close.
Old 10-02-2015, 04:50 PM   #21
DLW
Do you have a link to the Patriot radiator? I never heard of them. Google just comes up with radiators for the patriot jeep.
If it has 1" tubes and has quality core and tanks, then it should be comparable to the Champion 3 row.
Old 10-02-2015, 05:14 PM   #22
jason999
I'm the worlds worst about researching things to death. I spoke with the guy that had the ebay listing and saw his return policy and feedback and decided to order from him, but not before I spent hours reading about radiators.....
Its an AE284 - AE stands for American Eagle
Champion's standard 2 row for our trucks is an EC284 - EC for Economy
Here is my radiator at Jeggs. Click on Overview. Notice they call it a Champion
http://www.jegs.com/i/Champion-Cooli...AE284/10002/-1
Here is the Champion 2 row at Jeggs. Again, click Overview
http://www.jegs.com/i/Champion-Cooli...EC284/10002/-1
I didn't see a lot of info but here is the site you wanted http://www.americaneagleradiator.com/
Here is some math comparing the 3 core Champion to the 2 core Patriot, from another forum. I didn't check it but here it is.
3 rows wide x .63� tubes x 2 (cuz rad tubes have 2 sides�top and bottom) x 42 rows tall x 23� wide core = 3651.5 square inches of cooling surface area.
2 rows x 1� tubes x 2 x 42 rows x 23� core = 3864 square inches of cooling surface area.
Old 10-03-2015, 12:05 PM   #23
DLW
I agree with your math you found there.
I did see that you bought AE from ebay before, but the patriot name you put out above through me off.
Also, you can see the AE radiators on the champion website for some details too. I think you went the better route with the AE radiator for sure. Always good to research to death.
Old 10-03-2015, 01:13 PM   #24
iceman777
iceman777's Avatar
are you saying that a 2 row A/E is better than the the 2 row champion radiator
Old 10-03-2015, 06:27 PM   #25
DLW
Providing the core dimensions are the same, the AE should cool better with the 1" tubes.
