Old 09-07-2015, 07:17 PM   #1
McCoyAZ
McCoyAZ's Avatar
Another mechanic screws me over.....
I really don't have a sign on my shirt that says "Screw Me", but considering all these so called mechanics I have had work on my truck, you would sure think I did.
I had a guy move the gas tank from behind the seat and install a 53 Chevy sedan tank up under the bed. It didn't take all that long to have it done and this guy came highly recommended from several others who had work done.
After I drove the truck around a few days and decided to top off the tank I pulled up to the pump and started to fill the tank. The nozzle kept popping off and the smell of raw gas was pretty evident.
After about 5 minutes and only getting around 3 gallons of fuel in the tank I decided something wasn't right, and upon further investigation I found out what the problem was.
Take a look for yourself.
McCoyAZ is offline   Reply With Quote
Old 09-07-2015, 07:20 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Another mechanic screws me over.....
wow what a mess. One of the reasons I like doing it myself. I only have me to blame.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-07-2015, 07:31 PM   #3
OldChevy61
OldChevy61's Avatar
I want allow anybody else working on my truck. Me and he would be having a serious talk and he wouldn't like the ending.
OldChevy61 is offline   Reply With Quote
Old 09-07-2015, 07:32 PM   #4
65 GMC
Wow that is a mess. The tank is unlevel from side to side and a smashed filler neck.
65 GMC is offline   Reply With Quote
Old 09-07-2015, 07:37 PM   #5
cv65
cv65's Avatar
Gee maybe He could light a match at the filler neck and blow that dent out! Im bad I would be having strong words with him.
cv65 is offline   Reply With Quote
Old 09-07-2015, 08:46 PM   #6
Chevy Fleetside
Forgot to mention.. I doubt he is a mechanic. Maybe a Hackanic.
Old 09-07-2015, 08:51 PM   #7
strat10
sorry that happened to you. That kind of stuff seems to run thick in my gene pool as well. I understand now why my grandpa always stresses doing it yourself no matter how long it takes.
strat10 is offline   Reply With Quote
Old 09-07-2015, 09:12 PM   #8
MisterC
MisterC's Avatar
Sorry about your misfortune. There's a pretty strong 60-66 following in AZ. I suggest you post up on the AZ or southwest forum and ask one of these good folks near you to help you out. If you buy the proper equipment, I'm sure someone will come to your aid and help you install it.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 09-07-2015, 10:05 PM   #9
TJ's Chevy
TJ's Chevy's Avatar
Bet you he was an "Engineer" before he became a "mechanic".....probably one of those guys who though it would be cool to start Stuffing engine compartments full of needless crap. I'd go back and have some words with him. This type of work is a no no. If anything you can get a new tank from Classic Parts for $300.
Old 09-07-2015, 10:16 PM   #10
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Yep
That's why I'm keeping my truck simple.
So I can work on it myself.
I'll figure it out and do it myself.
I've had my share of bull crap mechanics.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 09-07-2015, 11:07 PM   #11
LT1 Burb
LT1 Burb's Avatar
Not only that but that is probably a 20 gallon tank at 8# per gallon equals 160# flexing on a 3/8 bolt on the 18 gauge steel,Fail. What a moron that guy was, that tank eventually would have been on the road.
LT1 Burb is offline   Reply With Quote
Old 09-07-2015, 11:51 PM   #12
kerber63
kerber63's Avatar
I'm sorry that you got the severely short end of the deal. It's frustrating to see a "professional" treat a customer like that. I'm sure if it was his rig, he would've come up with something quite a bit better, and not settled for that lame attempt. His answer to problems is clearly "get a bigger hammer."
1963 C10 short-wide
Turbocharged 454, T56, 4.11 posi
http://67-72chevytrucks.com/vboard/s...d.php?t=605408
1963 C10 suburban
Unknown, unknown, 3.73 open
http://67-72chevytrucks.com/vboard/s...d.php?t=622037
kerber63 is offline   Reply With Quote
Old 09-08-2015, 03:25 AM   #13
luvbowties
luvbowties's Avatar
Smile Re: Another mechanic screws me over.....
If we just stop and assess the overall situation, you are really a long way towards a done project. Trying to be positive, it appears the tank is easily accessible to work on right now. And its dimensions appear quite workable. Using some 1" tall by 2" wide channel(or close: experiment with short pieces of this given size and close-but-different sizes to determine optimal) can do wonders in leveling, raising and securely mounting this tank.
Really, leaving cosmetics aside, you aren't very far from a very workable solution. **I'd check the inside condition of the tank and also check it for leaks before spending anything further on it.
Depending on where you plan to mount your fill-pipe, get an experienced welder to remove and weld closed the present fill-pipe and its opening; and have him cut a new opening and weld in a fill-pipe in your needed position.
Good luck with your outcome.
Sam
luvbowties is offline   Reply With Quote
Old 09-08-2015, 11:45 AM   #14
McCoyAZ
McCoyAZ's Avatar
I talked to the guy about this and he just blew me off. He isn't willing to do anything to fix the problem.
He isn't the 1st and probably not the last A Hole I have dealt with around here, and small town news travels fast. Karma is a ***** they say.
SO
A quick question...
How far above the top of the frame rail could a tank be? I have a tank I bought from the parts section here, it's just really deep and would hang pretty low unless I can raise it up some.
Anyone know off hand how much room there is between the top of the frame rail and the bottom of the cross sills that I could use to raise this other tank?
Thanks for the comments and suggestions.
Old 09-08-2015, 12:27 PM   #15
Lugnutz65
Lugnutz65's Avatar
SO
A quick question...
Too bad that guy won't own up to his bad work.
Basically, for a short bed, the 2 rear most cross sills sit directly on the top flange of the frame.
I just installed my 1965 short stepside bed. The 2 front cross sills sit on perches. The very rear cross sill is bolted to the bed sides just beneath the tailgate and has mounts that sit directly on the very end of the frame. There is a cross sill in front of that "under the tailgate cross sill" and it sits directly on the frame too. I had 2 thinner cross sills that had no frame contact at all.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 09-08-2015, 12:36 PM   #16
McCoyAZ
McCoyAZ's Avatar
Dang.....well guess plan B will have to work.
Thanks for the pictures.
Old 09-08-2015, 01:14 PM   #17
padresag
perhaps he wasn't a professional but just another back/yarder.
ron
padresag is offline   Reply With Quote
Old 09-08-2015, 01:49 PM   #18
Clyde65
Clyde65's Avatar
There is supposed to be some 1/4" rubber pads between the cross sill mount and the frame. You "could" make your adjustment with thinner isolators.
http://www.classicparts.com/1954-87-.../#.Ve8gd_lVhBc
maybe use these?
http://www.classicparts.com/1949-72-.../#.Ve8gjPlVhBc
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-08-2015, 02:29 PM   #19
62step
Is that one on the left even on the frame? Doesn't look like it from the pics...
62step is offline   Reply With Quote
Old 09-08-2015, 04:50 PM   #20
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I think you can still use that tank:
cut the filler tube just before the smashed section. go to the parts store and get some fuel hose-its expensive, maybe 10-20$ a foot- use the hose to route your filler pipe around the frame- I don't see why you couldn't notch the frame a tiny bit there as well.
the tank needs to be mounted right. buy some steel 3/16 to a 1/4 by 2"X 30" (maybe 33"-measure it first), 2 pieces should go across the frame rails, bolt them on. then get some gastank straps and trap the tank between the steel and the straps. you could bolt the straps to the existing crossmember behind the rear, and then maybe install another piece of strap steel- angle iron might work good on this part - to bolt the other end of the straps to.
here is what I did on my 'burb:
http://67-72chevytrucks.com/vboard/s...=448681&page=5
post # 112
my '60 build:
http://67-72chevytrucks.com/vboard/s...=280904&page=4
post # 97 picture 5- at the front of the tank you can see the strap I bought from the hardware store to use as gas tank straps
also on my '60 build, how I re-routed the filler neck:
http://67-72chevytrucks.com/vboard/s...280904&page=12
post # 281
Old 09-09-2015, 11:48 AM   #21
72step
72step's Avatar
Damn! I'd blast him on your local facebook!
In the past I only had experienced negative issues with local paint and body guys. Shoddy work and they took months or years if you let them. When it came time to work on my 65 C10 I bought me a mig welder and many other paint and body tools and accessories fired up youtube and I ended up with a very satisfactory finished product. I've paid for much worse work!
With that said if you want a job done right; do it yourself.
72step is offline   Reply With Quote
Old 09-09-2015, 12:18 PM   #22
cv65
cv65's Avatar
I agree with others do it yourself if at all possible,I dont know what he charged you but sometimes you have to bite the bullet and get the job done right , one time, clean and you can cross it off and move on to the next problem,our trucks need work all the time ,the more you do your own work the more you learn the eaiser it gets,and when your an old fart like me you might know half of what you need to belive me Ive paid plenty for jobs I had to do over.but I can stand back now and say I can fix that! trouble now is Im too old and crippled up to do some things Ha Ha ! smile shake your head and get on with it!
Old 09-09-2015, 12:49 PM   #23
russellrox
buy a boyds welding tank, the 67-72 tank fits our trucks, just got mine, very impressed with the quality and it's polished, the non fuel injection tanks are not a bad price, under 400 usd.
russellrox is offline   Reply With Quote
Old 09-09-2015, 03:00 PM   #24
72step
72step's Avatar
Oh and when you diy you end up with a high level of self accomplishment and satisfaction!
Old 09-09-2015, 03:16 PM   #25
65chevysub
65chevysub's Avatar
I did a similar swap into my 65 Suburban several years ago. I put a 31 gal tank from a mid 70's Blazer into it. I modified the straps so they were longer and it sat level. If I was closer I'd swing by and see if we could get yours straightened out. PM me if you have any questions ob how I did my swap
Good Luck
65chevysub is offline   Reply With Quote
