Old 09-24-2015, 12:52 PM   #1
jcblue
jcblue's Avatar
High oil pressure
What would cause high oil pressure and is it a bad thing? My stock gauge is pegged out.. Have an aftermarket gauge ordered to see what it's reading.. I do think the pressure is making it leak a little oil..
jcblue is offline   Reply With Quote
Old 09-24-2015, 12:56 PM   #2
pwdcougar
pwdcougar's Avatar
Re: High oil pressure
It isn't over filled is it? A blown head gasket could also be the problem.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 09-24-2015, 01:09 PM   #3
cleszkie
cleszkie's Avatar
Is it an issue that just started, increased gradually, or has it always been high? Have you done any work to the engine recently? Are you running a standard oil pump or a high pressure unit? Have you changed grades/viscosities of oil recently? Is the gauge always pegged, or does it actually move. If it is always pegged (hot, cold, idle, high RPM) then I would suspect a faulty gauge or sending unit.
I have a newly built small block in my Blazer that will peg out the stock gauge when cold or running high RPM. My mechanical oil pressure gauge will be reading above 40psi when the stock gauge is pegged.
cleszkie is offline   Reply With Quote
Old 09-24-2015, 01:13 PM   #4
jcblue
jcblue's Avatar
It's not over full.. Motor is recently rebuilt . Stock with a small cam. Probably still has the break in oil in it.. I haven't changed it yet
Old 09-24-2015, 01:21 PM   #5
cleszkie
cleszkie's Avatar
Break in oil is typically thinner than the recomended daily use oil in my experience. Don't think that is the source of the pressure. If the engine is a new build, ask the builder if they installed a high pressure oil pump.
Old 09-24-2015, 01:33 PM   #6
Dave
DND Trucks
Fwiw, I've rebuilt a few SB engines that I installed the high pressure oil pump spring , like the corvettes used back in the day. This would cause the stock mechanical 60 lb gauge to stay at 60 thru the warm up cycle into the normal operating temperature. It wasn't until about 5k miles later that it started to come down a bit. In addition, all of your crank, rod and cam bearing tolerances are the tightest they'll ever be given this a new engine.
Dave is offline   Reply With Quote
Old 09-24-2015, 03:51 PM   #7
jcblue
jcblue's Avatar
Does it really matter that it's high? Is it something I should worry about?
Old 09-24-2015, 05:12 PM   #8
Robznob11
Robznob11's Avatar
If you did not wash the engine real good before assembly and if you had any machine work done you may hav a restricted oil gally. Not good I smoked a sbc crank and mains in 600 mi because of this. In short high oil pressure is not good like some think. You want high volume. Most race engines restrict oil to mostly the bottom of the engine tho. I would pull the pain and check a main before I drove any more. In my case the front was just a little marked and got worse going back last one was trashed. Had to turn the crank
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 09-24-2015, 05:26 PM   #9
leftybass209
leftybass209's Avatar
Interesting suggestions. It seems though, you should first ensure your 45+ year old mechanical oil pressure gauge is in proper working condition, before you go chasing an issue that may not exist.
Connect a gauge that can read above the 60lb limit of the original, so your scale is more accurate.
It's similar to chasing electrical faults when the whole time your battery was never properly charged.
leftybass209 is offline   Reply With Quote
Old 09-25-2015, 07:10 PM   #10
jcblue
jcblue's Avatar
I hooked up an aftermarket gauge.. Truck idles at 60 psi and goes up as Rpm go up.. Is that pretty normal?
Old 09-25-2015, 08:59 PM   #11
hamjet
hamjet's Avatar
Is that hot engine or cold. you say it goes up, how high?
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 09-25-2015, 09:17 PM   #12
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Sounds like someone installed a high volume/high pressure oil pump during the rebuild.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 09-26-2015, 12:21 AM   #13
toolboxchev
Thats a HOT trick, now where to find the part.
toolboxchev is offline   Reply With Quote
Old 09-26-2015, 04:12 AM   #14
Jrainman
Jrainman's Avatar
on fresh engine 60 lbs is normal on cold start up as engine warms up you should see the pressure come down , at full warm up you would like to see 35 lbs min this is all at idle rpm .
As you increase engine speed you increase oil psi . I would address your concerns with your engine builder ,like previous poster said about the oil not retuning back to sump ,this can happen ,but you would have other signs of failure . also as poster said about oil pump it self could be new high volume oil pump installed or also spring change .
there are other things such as is your engine properly breathing rite , your best bet is to go back to the engine rebuilder. if you did not get in in writing on what was done only he knows and will be able to quickly evaluate your concerns,
Jrainman is offline   Reply With Quote
Old 09-26-2015, 08:38 AM   #15
Robznob11
Robznob11's Avatar
Wink Re: High oil pressure
In my case I was young, had a rebuild done. The pressure was high and the builder said he used a hi press spring. It ran and drove fine. I pulled up to a gas station left it running and filled up. Went in to pay and walked out to hear a knock . Went to the shop to find my surprise. My main gally was mostly plugged so the first main was not to bad but each next one was worse and last one looked like you ran 40 grit sand paper around it. Trashed.
LED TAILS
Old 09-26-2015, 08:38 AM   #16
Davidf
My 283 in "seen better days" condition pegs the gauge cold and shows 1/4 on hot engine at idle, 1/2 while cruising.
Davidf is offline   Reply With Quote
Old 09-26-2015, 09:49 AM   #17
Skinny Kid
The 383 in my Chevelle was built by a friend of mine, who is a very well known engine builder used a Melling pump that is spec'd for the 69 Z28 302. I can't remember the part number right now, but it is a factory high volume/std pressure pump and the pressures are right where he said they would be. Cold - 60psi idle, hot - 25psi idle and 60psi cruise. Excessive oil pressure isn't necessary on a street car and just puts extra wear on parts and hurts economy.
Now on the other hand, the 422 he built for my Nova, which is a dedicated race car and not on the street ever is a different story. That one makes about 70psi idle and I see about 100psi on a run. But, that is a big solid roller, 14:1 engine that turns 8,500 rpm. Works for the race engine, but totally overkill for a street engine.
1971 Chevy Custom Camper/20, Hugger Orange with White Top
31,000 original miles (when purchased), 402, TH400, PS, PB, AC
As of May 2017 it now has a turbo LS in it! (Still looks stock though)
Skinny Kid is offline   Reply With Quote
Old 09-26-2015, 09:53 AM   #18
Skinny Kid
I once heard someone use the analogy, "If your engine was a human, the doctor would diagnose hypertension."
Old 09-26-2015, 11:02 AM   #19
leddzepp
Moderator
leddzepp's Avatar
I wouldn't worry about it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 09-26-2015, 06:48 PM   #20
toolboxchev
Based on the wide variety of responses I would definitely be looking into that one.
Its not worth losing an engine IMHO. Keep us posted and let us know what you find.
On my top end rebuild we keep everything in the bottom. Including the High Volume pump we found.
On a hot day when engine is fully up to temp I am at a hair over 1/4 on the stock gauge. At normal cruise, a hair over 1/2.
Under WOT it is almost fully pegged and drops when I let off the throttle.
I hope this helps, pretty much a stock motor with HEI and an edelbrock carb.
Old 09-26-2015, 07:20 PM   #21
jcblue
jcblue's Avatar
Ok I went for a drive today and this is what the readings are.. 60 at startup cold.. Warm idle at 35-40. Crusing is anywhere in between those depending on how much I'm in the throttle. Thanks for all the responses
Old 09-26-2015, 07:32 PM   #22
Robznob11
Robznob11's Avatar
I dont think that's bad, I thought it was 60+ all the time
LED TAILS
Old 09-26-2015, 08:33 PM   #23
Jrainman
Jrainman's Avatar
Sounds like good numbers to me for a fresh rebuild ,with mild cam , I would recommend you add zinc additive for the next few oil changes ,for extra lubrication during the break in..........
Old 09-26-2015, 09:53 PM   #24
jcblue
jcblue's Avatar
Noted on the zinc.. Thanks guys
Old 09-26-2015, 11:04 PM   #25
mike16
might want to use a 2 quart oil filter with that much pressure otherwise it will bypass your filter and who knows what that can do to a rebuilt engine.
mike16 is offline   Reply With Quote
