Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 09-29-2015, 07:49 PM   #51
stick72
Re: Hemi's 70 Blazer build
Looks great, I'm envious of your progress!
stick72 is offline   Reply With Quote
Old 10-02-2015, 02:16 PM   #52
hemi43
hemi43's Avatar
A few more updated pictures.
hemi43 is offline   Reply With Quote
Old 10-05-2015, 08:55 AM   #53
jaros44sr
jaros44sr's Avatar
Very nice
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-11-2015, 09:28 PM   #54
hemi43
hemi43's Avatar
Been a busy week. Got the chassis done, so I'm back to getting the body done. I fabricated the roll bar and mounted it permanently. I figured it would be easier to paint it in location than to risk getting the paint scratched afterwards. I incorporated the seat belt mounts into it also. I'm putting in 3 point harnesses because I just don't feel safe with just a lap belt. We have some nice weather coming up, so I rolled the body outside for the fun task of sandblasting it. So far I've used 52 50lb bags.
Old 10-15-2015, 09:39 AM   #55
hemi43
hemi43's Avatar
Was able to get the underside and floor epoxied and painted. Today I will be seam sealing all the joints. Someone asked for pictures of the transfer case to frame mount, so I've added those too.
Dan
Old 10-15-2015, 09:40 AM   #56
hemi43
hemi43's Avatar
One last lic of the mount. sorry about the crappy quality.
Old 10-15-2015, 01:37 PM   #57
tjsblazer
tjsblazer's Avatar
Thanks Dan. That was me asking the question about the mount. Between yours and another post I get how it goes together now. The bushings are different thicknesses, which did you put on the bottom the thick or thin? I'm getting conflicting answers on that.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 10-15-2015, 05:32 PM   #58
hemi43
hemi43's Avatar
I think the thick one, but I will double check.
Old 10-15-2015, 08:50 PM   #59
jjzepplin
jjzepplin's Avatar
You certainly have some talent and some very nice tools. Great job on your Blazer. Looks factory straight. Better than new.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-16-2015, 05:17 PM   #60
tjsblazer
tjsblazer's Avatar
Dan definitely I think it was the thick bushing. I just installed my transfer case this afternoon and after I got it bolted to the tranny and sitting at the correct height I measured. Thin would have been way too low in my case.
Right now my output yoke is sitting offset between the frame rails a bit. That side mount basically dictates where it sits left to right between the frame. When I take a measurement I'm 1" closer to the Lh rail than the Rh rail so 1/2" off center.
How close is yours to center between your frame rails ??
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 10-17-2015, 02:50 PM   #61
hemi43
hemi43's Avatar
I just checked mine, and the thick bushing is on the bottom. I also checked the side to side location of the transfer case yoke and it's 1/2" offset also same as yours.
Was able to get the passenger 1/4 straightened and epoxy primed today. Nice to see panels in one color.
Old 10-23-2015, 06:52 AM   #62
grillzy
great progress
grillzy is offline   Reply With Quote
Old 10-23-2015, 08:46 AM   #63
hemi43
hemi43's Avatar
Originally Posted by grillzy View Post
great progress
Thanks! If you're ever near Newcastle, be sure to drop in.
Old 10-23-2015, 12:26 PM   #64
GMC-YA68
GMC-YA68's Avatar
Are your exhaust tips out the back or are they angled out behind the tires?
Did you put a H-pipe anywhere or are they straight from the manifold back?
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 10-23-2015, 01:11 PM   #65
hemi43
hemi43's Avatar
They come out the back. Hopefully this wont cause issues by causing exhaust fumes to go into the truck from the low pressure because I will only be using a soft top.
I had plans on an H-pipe, but once I had the exhaust fabbed up, there was no place for me to install one. Since I'm using a 5.3, the laws here in Canada dictate that I use all the emission controls from the donor engine and this includes the cats. If they weren't there I would have had room.The small gain in HP is minimal anyway, but I will miss the sound of an H-pipe though. Oh well !!
Old 10-23-2015, 04:46 PM   #66
grillzy
You can be sure of it!
Old 11-04-2015, 11:24 AM   #67
hemi43
hemi43's Avatar
Getting lots done, but mostly boring body work. Everything is now in epoxy primer (gray colour), and giving it 72 hours before I sand it and spray on the polyester primer (Featherfill). Parts like the underside of the hood and rad support were epoxy coated then painted wet on wet with satin black urethane.Parts like the inside of the doors that wont get blocked with Featherfill were sprayed with high build urethane primer (tan colour).
Old 11-04-2015, 11:58 AM   #68
tjsblazer
tjsblazer's Avatar
Looks good. At this rate you'll have it on the road before the snow flies.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 11-04-2015, 12:27 PM   #69
IronCanine
I'm trying....
IronCanine's Avatar
Fantastic Dan. Hood looks great. I love it when everything is the right color. Keep rocking it out.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 11-04-2015, 01:26 PM   #70
hemi43
hemi43's Avatar
Thanks Guys!!!
I guess you wont like my final choice for the exterior then because it's not a factory colour.
When I first bought my Blazer, I was going with Hugger Orange. It looks great and really suits this style of truck, the problem is that everyone else thinks so too and in IMHO it's been done too many times. What made me change my mind was the Syracuse show this year. There was an amazing looking Blazer there (1 of 2) and it was from Ontario, and you guessed it, it was orange.
I don't like wrong year paint either, and some newer colours with high metallics and pearls really don't suit older vehicles. I think my choice will look good, and will be somewhat different.
I'm not one to follow trends.
Old 11-04-2015, 01:46 PM   #71
IronCanine
I'm trying....
IronCanine's Avatar
Thanks Guys!!!
Hey...my truck wasn't a factory correct color (or colour ). You couldn't get silver on these trucks. We cheated on the reproduced SPID and coded the paint out as a special order code so it synced up. I just like the black under hood, correct dash color, detail stuff like that...
BTW...have I missed it in the thread...or misread your post? What colour are you painting it?
Old 11-04-2015, 03:08 PM   #72
tjsblazer
tjsblazer's Avatar
I'm going through the colour deciding process now. I think my paint guy is getting tired of doing test panels for me. Can't decide beyond I want to be period correct. Also curious what you're going with.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 11-04-2015, 03:47 PM   #73
hemi43
hemi43's Avatar
I'm a real military buff and would have loved to paint it flat drab olive, but then everything on the truck would have to blacked out and needless to say any flat colours (color for my American friends) are extremely difficult to maintain. I knew I wanted a solid colour, and driving home one day I spotted a 2015 Jeep which from far away looked black. It was actually a real dark olive green, and although it was shiny, it still had that military look to it.
It's called "Tank" green, and although the paint formula says there's metal flake in it, it's in such a low amount that you can't even see it.
I had a buddy photoshop a Blazer with it and it looked good especially with the black soft top.
I'm a couple of weeks away from having to buy the paint, and so far I can't seem to be able to talk myself out of it.
It would be different, but not so different that it would make it stand out.
Old 11-04-2015, 04:44 PM   #74
IronCanine
I'm trying....
IronCanine's Avatar
That sounds cool...next question...interior colour(my spell check really doesn't like that word): green, saddle or black?
Old 11-04-2015, 05:56 PM   #75
hemi43
hemi43's Avatar
The interior is originally black, so it will stay that way. The original seat are the utility buckets, and although I would prefer the smaller buckets, I'll keep them. I'll upholster a small pleat design into them so they don't look so...well...utility looking !
Even though I've upgrade the drivetrain and a few other things, I still want this truck to look to be as close to original right down to the AM radio. The stereo will be in the console, and I have a WW2 era anti tank mine box that will be a permanent storage box behind the rear seat. I also have a WW2 metal gas can that will become the housing for the subwoofer and this will be clamped to the rear part of the roll bar by the tailgate.
