Old 02-25-2004, 08:09 PM   #1
Piper71c10
Unending Project
Piper71c10's Avatar
Brake Light Broke...
So, when my lights are on, the taillights work fine. But, on the drivers side, when I step on the brakes, the taillight goes out.
I checked the voltage to the socket. everything seems fine. New bulb too..
Any advice?
Piper
Piper71c10 is offline   Reply With Quote
Old 02-25-2004, 08:21 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Does your drivers side turn signal work?
Double check your bulb, and make sure you have the 1157 bulb, and not the 1156.
Old 02-25-2004, 08:34 PM   #3
Piper71c10
Unending Project
Piper71c10's Avatar
Yeah, turnsignal works great. Bulb is 1157. I'm stumped. maybe a ground problem?
Old 02-25-2004, 08:43 PM   #4
useRc10
useRc10's Avatar
try switching the bulbs and see if it follows bulb or stays on drivers side
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires
-'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree
-'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials
-dads '70 burb (red, 5-7 drop, 350...)
www.geocities.com/userc10/truckhome.html
AIM: Auntjoedadda
useRc10 is offline   Reply With Quote
Old 02-25-2004, 08:44 PM   #5
Longhorn Man
nope, not a ground problem.
If the turn signal works fine, (and we are talking about the turn signal with the parking light off) then the only thig it could be is a bad turn signal switch.
