Old 12-25-2015, 01:25 AM   #1
casey g
casey g's Avatar
Bmi built 66
Well I've been designing this back suspension for a month or so and im finally getting started on the build. Ill Post pictures as I go.
The truck is a 66 big window short box. At this time I'm only doing the back suspension but I think I will end up doing most of the truck.
Custom bent Art Morrison rails, my design for a 4 link setup and more.
Let me know what you think so far.
casey g is offline   Reply With Quote
Old 12-25-2015, 01:29 AM   #2
casey g
casey g's Avatar
Re: Bmi built 66
more pics
Old 12-25-2015, 01:30 AM   #3
casey g
casey g's Avatar
Re: Bmi built 66
where Im at so far
Old 12-25-2015, 11:11 PM   #4
Captainfab
60-66 Nut
Re: Bmi built 66
Lookin good Casey
I see you got those rails notched.
Old 12-26-2015, 10:09 AM   #5
Sickfast1964
Re: Bmi built 66
very nice!!
Sickfast1964 is offline   Reply With Quote
Old 12-27-2015, 04:41 AM   #6
casey g
casey g's Avatar
Re: Bmi built 66
Originally Posted by Captainfab View Post
Lookin good Casey
I Drilled the corners and just used a cut off wheel. There pretty close! Thanks for the advise.
Old 12-27-2015, 04:41 AM   #7
casey g
casey g's Avatar
Re: Bmi built 66
Originally Posted by Sickfast1964 View Post
very nice!!
Thanks man!
Old 12-27-2015, 04:57 AM   #8
casey g
casey g's Avatar
Re: Bmi built 66
started welding the the back half together
Old 12-27-2015, 05:04 AM   #9
casey g
casey g's Avatar
Re: Bmi built 66
All the welds have been ground smooth to make it look as if it was one piece.
Tonight I drew up a drive shaft loop that Should be cut out in the next day or so, and at that point I will be able to get the 4 link mounts welded in the front.
Old 12-27-2015, 06:11 PM   #10
casey g
casey g's Avatar
Re: Bmi built 66
Drive line loop has been cut out. Now just need to get some 2x4 tubing so I can weld this stuff together!
Old 12-27-2015, 06:26 PM   #11
shrunken66stroker
shrunken66stroker's Avatar
Re: Bmi built 66
Great fab work! This build is on another level.
shrunken66stroker is offline   Reply With Quote
Old 12-27-2015, 06:37 PM   #12
casey g
casey g's Avatar
Re: Bmi built 66
Thanks man! Wish it was mine to keep! Just building it how I would want it.
Old 12-27-2015, 06:40 PM   #13
shrunken66stroker
Re: Bmi built 66
Makes me want to start from scratch! I'll be watching this one.
Old 12-27-2015, 06:45 PM   #14
casey g
casey g's Avatar
Re: Bmi built 66
your project is badass! your amost there : )
Old 12-28-2015, 01:25 AM   #15
Captainfab
60-66 Nut
Re: Bmi built 66
OK, Now I need to know who you know with a CNC plasma or laser that works that quick and on weekends
Old 12-28-2015, 01:38 AM   #16
casey g
casey g's Avatar
Re: Bmi built 66
It's a guy in rathdrum. His business name is red beard fab shop. He has a 4x4 plasma table. The cut on the 1/4 isn't as nice as the laser stuff but it's plenty good for me. Cost for the drive line loop was $60 and $40 in bolts washers and nuts.
Old 12-28-2015, 09:31 PM   #17
casey g
casey g's Avatar
Re: Bmi built 66
I spent a few hours in the garage today. I got the drive line loop installed which is also the front crosbar for the 4 link mounts. Then I welded the front 4 link mounts on. now I just need to make a few peices to help the front flow a little and it will be time to start cutting the old swb frame up.
Old 12-28-2015, 09:33 PM   #18
casey g
casey g's Avatar
Re: Bmi built 66
more pics
Old 12-29-2015, 12:25 AM   #19
namloc
namloc's Avatar
Re: Bmi built 66
more pics
Nice work fitting the Morrison part's. This is a cool build.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 12-29-2015, 02:08 AM   #20
casey g
casey g's Avatar
Re: Bmi built 66
thanks man! its pretty cool to be able to draw it on the computer and have it start to take shape in real life.
Old 12-29-2015, 10:58 PM   #21
casey g
casey g's Avatar
Re: Bmi built 66
Well the garage is a mess,
The back half is pretty much ready to be welded to the old frame.
This thread isnt getting much feed back so ill take it as a good thing : )
Also the rear end is not centered in these pics. I just really wanted to set it in there
Old 12-29-2015, 11:00 PM   #22
casey g
casey g's Avatar
Re: Bmi built 66
more pics
Old 12-29-2015, 11:01 PM   #23
casey g
casey g's Avatar
Re: Bmi built 66
last pic for the night
Old 12-29-2015, 11:14 PM   #24
namloc
namloc's Avatar
Re: Bmi built 66
Don't worry about slow thread response they are all just speechless , In aw of your skill's. It seem's most seem to chime in if it's shiny and painted but not during building not sure why?
The Snortin' Bull
Old 12-29-2015, 11:27 PM   #25
62stepside longbox
62stepside longbox's Avatar
Re: Bmi built 66
Very nice work
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
