12-25-2015, 01:25 AM | #1 |
Bmi built 66
Well I've been designing this back suspension for a month or so and im finally getting started on the build. Ill Post pictures as I go.
The truck is a 66 big window short box. At this time I'm only doing the back suspension but I think I will end up doing most of the truck. Custom bent Art Morrison rails, my design for a 4 link setup and more. Let me know what you think so far. |
12-25-2015, 01:29 AM | #2 |
Re: Bmi built 66
more pics
12-25-2015, 01:30 AM | #3 |
Re: Bmi built 66
where Im at so far
12-25-2015, 11:11 PM | #4 |
60-66 Nut
Re: Bmi built 66
Lookin good Casey
I see you got those rails notched.
12-26-2015, 10:09 AM | #5 |
Re: Bmi built 66
very nice!!
http://67-72chevytrucks.com/vboard/s...d.php?t=649661 |
12-27-2015, 04:41 AM | #6 |
Re: Bmi built 66
12-27-2015, 04:41 AM | #7 |
Re: Bmi built 66
12-27-2015, 04:57 AM | #8 |
Re: Bmi built 66
started welding the the back half together
12-27-2015, 05:04 AM | #9 |
Re: Bmi built 66
All the welds have been ground smooth to make it look as if it was one piece.
Tonight I drew up a drive shaft loop that Should be cut out in the next day or so, and at that point I will be able to get the 4 link mounts welded in the front. |
12-27-2015, 06:11 PM | #10 |
Re: Bmi built 66
Drive line loop has been cut out. Now just need to get some 2x4 tubing so I can weld this stuff together!
12-27-2015, 06:26 PM | #11 |
Re: Bmi built 66
Great fab work! This build is on another level.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
12-27-2015, 06:37 PM | #12 |
Re: Bmi built 66
12-27-2015, 06:40 PM | #13 |
Re: Bmi built 66
Makes me want to start from scratch! I'll be watching this one.
12-27-2015, 06:45 PM | #14 |
Re: Bmi built 66
12-28-2015, 01:25 AM | #15 |
60-66 Nut
Re: Bmi built 66
OK, Now I need to know who you know with a CNC plasma or laser that works that quick and on weekends
12-28-2015, 01:38 AM | #16 |
Re: Bmi built 66
It's a guy in rathdrum. His business name is red beard fab shop. He has a 4x4 plasma table. The cut on the 1/4 isn't as nice as the laser stuff but it's plenty good for me. Cost for the drive line loop was $60 and $40 in bolts washers and nuts.
12-28-2015, 09:31 PM | #17 |
Re: Bmi built 66
I spent a few hours in the garage today. I got the drive line loop installed which is also the front crosbar for the 4 link mounts. Then I welded the front 4 link mounts on. now I just need to make a few peices to help the front flow a little and it will be time to start cutting the old swb frame up.
12-28-2015, 09:33 PM | #18 |
Re: Bmi built 66
more pics
12-29-2015, 12:25 AM | #19 |
Re: Bmi built 66
Nice work fitting the Morrison part's. This is a cool build.
The Snortin' Bull |
12-29-2015, 02:08 AM | #20 |
Re: Bmi built 66
12-29-2015, 10:58 PM | #21 |
Re: Bmi built 66
Well the garage is a mess,
The back half is pretty much ready to be welded to the old frame. This thread isnt getting much feed back so ill take it as a good thing : ) Also the rear end is not centered in these pics. I just really wanted to set it in there |
12-29-2015, 11:00 PM | #22 |
Re: Bmi built 66
more pics
12-29-2015, 11:01 PM | #23 |
Re: Bmi built 66
last pic for the night
12-29-2015, 11:14 PM | #24 |
Re: Bmi built 66
Don't worry about slow thread response they are all just speechless , In aw of your skill's. It seem's most seem to chime in if it's shiny and painted but not during building not sure why?
The Snortin' Bull |
12-29-2015, 11:27 PM | #25 |
Re: Bmi built 66
Very nice work
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
