Old 12-26-2015, 06:20 PM   #1
rsmarr1982
rsmarr1982's Avatar
manual trans crossmember issues
im installing a straight 6 in a frame that had a factory v8. once i got the engine bolted up to the bellhousing i noticed the engine is too far forward. is there different locations for the manual crossmember between 6 and 8 cylinders? is the crossmember itself different?
1969 chevy c10 lwb stepside 250 6 3 ott
1971 chevy c10 lwb 250 6 with power steering 3 ott
1972 chevy k20 4x4 350/TH350 automatic
1978 chevy Malibu 4dr 305 2bbl (all original)
1979 chevy k10 Scottsdale 350/th350 full-time 4wd(daily driver)
rsmarr1982 is offline   Reply With Quote
Old 12-26-2015, 07:19 PM   #2
Mr Handy
Mr Handy's Avatar
Re: manual trans crossmember issues
Your motor stands need to move back. 2wd v8 uses forward motor stand location, straight 6 and 4wd v8 use rearward motor stand location.
check your frame there should be holes for the motor stands to be able to be moved back... at least that is what I understand.
Mr Handy is offline   Reply With Quote
Old 12-26-2015, 07:29 PM   #3
Lattimer
Lattimer's Avatar
Motor stands move back a few inches for the 6 cylinder. If its a 250 the stands are straight across, if its a 292 they are offset.
Crossmember is different and it is also moved back.
Holes should already be in the frame. Keep in mind you will also need L-6 clutch rods and z-bar mount, they are a little different.
A lot of people put the V-8 in the 6 cylinder position to help with weight bias. I left my engine in that spot when I replaced it since the PO already had it there.
You can put a V-8 in the 6 cylinder mounting position, but you can't put a 6 cylinder in the v-8 position.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 12-26-2015, 07:29 PM   #4
rsmarr1982
rsmarr1982's Avatar
Not a matter of the engine stands, bellhousing to far forward.
Old 12-26-2015, 07:37 PM   #5
frankslagoon
I think that's what the guys are tryin to say. if ya move the engine back the bellhousing will move back.
frankslagoon is offline   Reply With Quote
Old 12-26-2015, 08:33 PM   #6
hamjet
hamjet's Avatar
I think there is a difference between 6 and 8 cyl. manual bellhousing xmembers..http://67-72chevytrucks.com/vboard/s...d.php?t=595376
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 12-26-2015, 09:07 PM   #7
Possmguts
Possmguts's Avatar
The motor stands need moved for the 6...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 12-26-2015, 09:08 PM   #8
Possmguts
Possmguts's Avatar
You move the motor the bellhousing and trans moves with it lol
Old 12-26-2015, 11:03 PM   #9
rsmarr1982
rsmarr1982's Avatar
A manual transmission uses a crossmember that that attachs to the bellhousing not the trans . If I unbolt the bellhousing to move it back it no longer can be bolted to the crossmember.
Old 12-26-2015, 11:31 PM   #10
frankslagoon
Man, the more we see from the 67 72 guys it looks like there are two different bellhousing crossmembers. I always had v8s in the 67 72 trks so I never noticed. I've switched a half dozen 60 66 trks and the crossmembers were always the same. Looks like ya need to find a crossmember for a inline I guess. that's kind of a hassle.
Old 12-27-2015, 12:08 PM   #11
Lattimer
Lattimer's Avatar
Thats why you need the 6 cylinder crossmember, which mounts several inches to the rear of where the v-8 crossmember mounts.
Shawn
