01-19-2016, 05:37 PM | #1 |
What Trac Bar for lowered rear end
Good afternoon to you all,
I'm in the process of lowering the rear of my 71 SWB with coils. I've got 4" springs and 1.5" blocks. Question is, do I need a new trac bar? An adjustable one? And if I do need one, do I need just the adjustable bar for stock location or do I need the trac bar that goes from frame to the passenger side trail arm (ECE super trac type)? Your help will be greatly appreciated Thank you |
01-19-2016, 10:59 PM | #2 | |
Re: What Trac Bar for lowered rear end
01-19-2016, 11:44 PM | #3 |
I'm running exactly the same rear suspension as you. Porterbuilt bar is fantastic, I noted a better ride after installation. First class joints and fit like a glove. Scoti pretty much summed it up!
01-20-2016, 01:32 PM | #4 |
i have a porterbuilt trac bar that i cannot use that is already powder coated black it is a straight bar that attaches to trailing arm on passenger side and to frame on driver side it is adjustable it retails for 199.00 plus shipping and then paint or powder coat plus wait time I will sale mine for 199.00 plus shipping let me know thanks Richie
01-21-2016, 02:16 PM | #5 |
Thanks for the reply fellas..and thank you Richie for the offer on the panhard. I'm gonna hold out for a bit on which to go with, on a budget. Again I appreciate the help
01-21-2016, 03:30 PM | #6 |
Budget approach = build your own from factory parts if you can fabricate.
01-21-2016, 08:05 PM | #7 |
I just recently bagged my truck and had to go with a different trac bar. I went with a CPP bent trac bar @ $129 shipped and it worked out great. It's a longer one like the PB & others. I too am on a tight budget so the money I saved over the PB I also bought a new CPP trans mount. I also didn't have to change the frame mount with the CPP one, it uses the factory bracket. PB no doubt makes a nice product, some of us just don't have that type of $$$ to spend.
