04-05-2011, 03:00 PM | #1 |
Life, Be In It.....
Accuair Height Sensor Locations?
Does anyone have some pics showing the best mount location of the accuair height sensors?
I have the stock suspensions bits and trailing arms
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
04-05-2011, 06:05 PM | #2 | |
Junior Member
Re: Accuair Hieght Sensor Locations?
http://www.accuairsuspension.com/vehicles-tech.html Click the tools symbol once you are looking at a given vehicle to see the tech/ installation photos when they are available. If that doesn't help we can email some pictures of other builds to get you on the right track. |
04-05-2011, 07:14 PM | #3 | |
Life, Be In It.....
YOUR EMPLOYEES ARE SUPER GREAT AT ANSWERING QUESTIONS THROUGHLY AND IN A MANNER THAT A NOVICE WITH THE TECHNOLOGY CAN UNDERSTAND. I have another question, does the height sensor have to be vertical with ground or can it be off centered like the picture below.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 04-05-2011 at 10:49 PM. |
04-05-2011, 07:54 PM | #4 | |
Junior Member
04-06-2011, 07:18 PM | #5 |
Life, Be In It.....
I have worked on this for about 8 hours now and I can't figure it out. I have followed the instructions and even had my wife come out to make sure I'm following the instructions properly. I just can't seem to get the sensor travel distance lower the 3.50. I have moved both the A and B position to numerous different locations along the upward arch of the rear frame. I have also just moved the B position closer to the pivot point and still get a travel distrance anywhere from 4.50 to 3.50. I lost and a little P/O.
Does anyone have some pictures of the height sensor locations on a truck with stock suspension and trailing arm? PLEASE. Unfortunetly the truck Accurair used on the site has a four link rear end which doesn't help with picking a mounting location. Anyone what to buy and unfinished project???????????????????
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 04-06-2011 at 07:21 PM. |
04-06-2011, 08:25 PM | #6 | |
Junior Member
http://67-72chevytrucks.com/vboard/s...d.php?t=389328 |
04-06-2011, 10:51 PM | #7 | |
Life, Be In It.....
Anyone have any thought please feel free to chime in. Thanks.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 04-06-2011 at 10:52 PM. |
04-07-2011, 12:40 AM | #8 | |
Junior Member
04-07-2011, 08:39 PM | #9 |
Life, Be In It.....
After spending some more time looking at it that's what I decided to try. I think I will make a bracket to box in the frame at the location I want to put the sensor. I will try to work on it this weekend and keep everyone updated.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 Last edited by jugernot; 04-07-2011 at 08:49 PM. |
04-10-2011, 10:48 AM | #10 |
Re: Accuair Height Sensor Locations?
Here's what I did to mine:
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 04-10-2011 at 10:58 AM. |
04-11-2011, 09:05 AM | #11 |
I mounted my sensors on the inside of the frame like Accuair did in the link http://67-72chevytrucks.com/vboard/s...d.php?t=389328
I used a peice of a 2x4 as a spacer between the frame and the sensor, similar to the aluminum block Accuair made. I used large c-clamps to hold the sensor in place while i cycled the suspension. When the sensor was in the correct location, i drilled through the block and started drilling the frame. Once i got both hole marked, i took down the sensor and block and finished drilling. I then used two peice of pipe to replace the wooden block and long bolts to mount the sensors. click the link below and go to post #11 to see a pic of my rear sensor mounting. One of the nice things about the Accuair system is the sensors dont have to perfect. during the calibration step, the computer will figure out your setup and learn from there. http://67-72chevytrucks.com/vboard/s...d.php?t=429466 I know the sensors dont look stable in the pic, but they are solid as a rock. Last edited by dznucks; 04-11-2011 at 09:09 AM. |
04-11-2011, 09:01 PM | #12 |
Life, Be In It.....
Thanks for the posts, pics, and links and thanks to Accurair for the tech support, but I give up. After 4 days of moving things, making brakets, moving the suspension up and down, up and down numerous times, measuring, measuring and more measuring, and no progress, I'm going to find a shop to do the install. If I don't have I shop do it, I probably push the truck onto the street and put a "Free" sign on it.
01-31-2016, 08:17 PM | #13 | |
1961 Biscayne http://67-72chevytrucks.com/vboard/s...90#post6978790 SOLD 1971 C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=656258SOLD 1966 Suburban http://67-72chevytrucks.com/vboard/s...85#post7323885 |
