Re: My nv4500 swap then doubler ol' black
A few pics ;The job went smooth and no problems.
You can see(sorry blurry) the build up of carbon tracking from the small contacts in the cap as well as the small hold down screws that are easily broke off with even a hint of corrosion present. The 2 connectors on my harness that were changed to fit the big cap was all that was needed for this distributor to work everything fits. Will see how it performs as time passes and keep posted' strangely enough it seems to idle better from the get go? later...
100:1 low gear! |
