Old 02-14-2016, 04:04 AM   #1
bc gman
71 bb longhorn
Pertronix elec ignition
I have been been thinking of installing an electronic ignition but then someone had told me about putting in a pertronix elec ignition that fits into the stock distrbutor, would this be a better option and does it perfrom well on a stock engine.
71 2500 Gmc longhorn with a 402 turbo 400.
09 F150 Supercrew 4x4
05 Mazda 6 sport
accept that somedays you are the statue
and somedays you are the pigeon.
bc gman is offline   Reply With Quote
Old 02-14-2016, 07:44 AM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Pertronix elec ignition
I have a Pertronix Distributor with their coil and new 7 mm stock looking wires ready to install in my truck. I did lots of research before I purchased the parts and everything I found out was positive including talking with friends who had installed them in various vehicles. I actually called their Tech Line and told them what I wanted to purchase and what type of engine I had and they agreed that what I bought, for my use ,is what I need. Use the search tab to see threads on Pertronix.
http://www.pertronix.com/prod/ig/ignitor2/default.aspx
http://www.summitracing.com/int/part...0700/overview/
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-14-2016, 08:08 AM   #3
custom10nut
custom10nut's Avatar
I installed one 18years ago. You won't be disappointed. I just got tired of adjusting the points and the floating at the higher RPMs. I also had the desire of keeping the original distributor. It would be easiest to install the module with the distributor out on the bench, but it can be done while it's in the engine
custom10nut is offline   Reply With Quote
Old 02-14-2016, 10:41 AM   #4
nds1968
nds1968's Avatar
Yeah I wanted to keep the original distributor was my main reason, I pulled the distributor to make the install easier.
Nate
1967 short fleet Project Blue Goose
'If it don't bounce back... heeheehee you go hungry!" Blues Brothers
nds1968 is offline   Reply With Quote
Old 02-14-2016, 12:25 PM   #5
Wrenchbender Ret
The factory HEI unit is the best way to go but if clearance problems or originality is desired the Pertronix is good. I've done them both ways.
Wrenchbender Ret is offline   Reply With Quote
Old 02-14-2016, 01:48 PM   #6
57larry
I have it in my 2 other vehicles, no problems
57larry is offline   Reply With Quote
Old 02-14-2016, 01:55 PM   #7
70cst
70cst's Avatar
I installed a Pertronix Distributor about ten years ago with zero issues.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 02-14-2016, 02:31 PM   #8
davepl
davepl's Avatar
I've been running one since shortly after buying my truck, as it came with the incorrect big-cap HEI unit (which runs fine, but looks out of place if you care about that).
I went with their stock-bodied Delco-looking distributor too, as I didn't have a decent core, but I'd just as happily have put the module in my own distributor if I'd had one.
I've heard people having tach compatibility issues with the Ignitor III, which is what I have, but I think my tach is fine, though one I had read wrong (I just tried a different one and it worked). Apparently the Ignitor II, if you can still get it, tends to be more compatible with a broader range of tachs.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-14-2016, 04:16 PM   #9
Ironhorse
Ironhorse's Avatar
I have the Pertronix Ignitor II in my '71 4x4. Engine sits back further towards the firewall with the 4wd and very little room for a large cap HEI distributor. Used my original Delco/Remy distributor for the correct "look" and also for the fit. Also used a Pertronix coil, very satisfied so far. Been in there almost two years now. Hooked to my original GM factory tach I installed after finding it in a salvage yard and it works fine.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 02-16-2016, 12:31 AM   #10
bc gman
71 bb longhorn
Thanks for the feedback i think that is the route I am going to take.
05 Mazda 6 sport
Old 02-16-2016, 11:49 AM   #11
D.PASSMORE
One of the First
D.PASSMORE's Avatar
http://performancedistributors.com/p...nition-system/
I run these, Made in USA!
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 02-16-2016, 12:27 PM   #12
FlameOut
With that above mentioned distributor from Summit, is there anything else needed, or can I just pull my large cap HEI distributor and drop this one in?
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 02-16-2016, 12:33 PM   #13
jocko
jocko's Avatar
Note that the DUI small dia distrib has an externally mounted module. So if space is the concern, these would be great. I original look is the concern, I'd personally go with the internal pertronix setup. For clarification David - since you have these - is the module externally mountable anywhere" (like, inside the firewall) it does it have to be hangin on the cap as depicted? If anywhere, then disregard my comments and this WOUKD be a nice alternative. I'm no familiar and the image on their page threw me off a bit. Thx for sharing this)
Old 02-16-2016, 01:22 PM   #14
FlameOut
Space is the main concern for me. I have a 72 K10 w/350 and my current HEI cap only has about a 1/4" clearance from the firewall. It works, but looks like crap. I just wanted a stock looking, smaller dia cap dist.
Not meaning to hi-jack this thread, but maybe this info might help other too
1967 Chevelle SS
Old 02-16-2016, 02:08 PM   #15
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I've run these (DUI) on my stock 4x4's for the last 6-7 years and no issues with clearences or peformance. I've never liked the pertronix because you had to play with the springs to get the right curve. Never could get the right feel, DUI will set the curve to your desire or recommend one. Really easy to comminicate with, quality made products and they back there warranty, good ole boys from Tenneessee.
BTW, The module mounts in the back (towards the fire wall). I remove the harness and solder the connectors to the pigtail, put some heat shrink around it - plug it back together. I can take a picture and post if anyone is intrested.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 02-16-2016, 02:30 PM   #16
steelhorse
steelhorse's Avatar
I put them in all my customers car/trucks that want to keep a stock looking engine but want better drivability. I have never had a problem with any of them and every engine I have put them in has run better.
steelhorse is offline   Reply With Quote
Old 02-16-2016, 03:26 PM   #17
Stoli
Stoli's Avatar
Put one in last year. No problems
Stoli is offline   Reply With Quote
Old 02-16-2016, 05:12 PM   #18
lovemy71s
lovemy71s's Avatar
I ran one for around 5 years with no issues at all. Took it out cuz my tbi set came with a new distributer
71 GMC 1-2 ton 4x4
71 Chevy Cheyenne 2wd
lovemy71s is offline   Reply With Quote
Old 02-16-2016, 05:31 PM   #19
jmader
jmader's Avatar
Is the original igniter unit the only one that can be run with stock plug wires?
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 02-16-2016, 08:52 PM   #20
'68OrangeSunshine
'68OrangeSunshine's Avatar
I had a Pertronix Ignitor II and FlmeThrower II coil on an Accel blueprinted Delco-Remy distributor, on my 292 L6 in a '68 C/10 Stepside. For about 7 years it ran real good, then it started cutting out at freeway speeds. I'd be going about 65 MPH, 3200 RPM, and the engine would just quit --in gear and rotating w/o spark at high RPM. I'd hafta kick in the clutch, turn the key OFF then ON, slow down to 55 MPH, and pop start in 4th. Usually some frustrated commuter was right up my tailpipe and leaning on his horn.
I talked [via email] with one of their tech reps and at his suggestion, sent the whole unit back to San Dimas, Calif. for evaluation, and never heard from them again.
I built up a Delco-Remy points distributor from the best components I had -- new breaker plate, points, condenser, rotor and cap; and changed out coils. After re-gapping plugs to .035 and tune-up with a dwell meter, it ran fine, and my 292 passed emissions.
I have a new-in-the-box HEI L6 distributor standing by on a shelf, but I'm having fun running with points.
Old 02-16-2016, 09:03 PM   #21
jocko
jocko's Avatar
I'd like a pic David - appreciate the extra info, sounds like a good system.
Old 05-31-2016, 12:46 PM   #22
quick60
quick60's Avatar
Not trying to hijack this post but it is related.
IN reference to installing the pertronix distributor, the tech guy said I need to have 12 volts at the coil wire and eliminate any resistors in the circuit. The only resistors I know of are the ceramic style firewall mounted which I do not see. How do you test the voltage at the coil to verify another type of resistor and remove it? Im running a 67 GMS 3/4 ton with a 250 L6.
quick60 is offline   Reply With Quote
Old 05-31-2016, 12:47 PM   #23
davepl
davepl's Avatar
On GM cars there's not usually a ceramic on the firewall, it's built into the white coil wire. You can remove and replace that wire or bypass it.
Old 05-31-2016, 12:49 PM   #24
quick60
quick60's Avatar
Any particular style replacement wire or just one of equal gauge?
Thanks for the help
Old 05-31-2016, 01:24 PM   #25
davepl
davepl's Avatar
Thanks for the help
Depends on what the ignition module is rated to consume, really, but equivalent gauge with no resistance (beyond copper) should be fine. Go one gauge thicker if in doubt I suppose. I'd at least match what's coming out of the module if you can.
