Old 02-20-2016, 05:39 PM   #1
Wayne penn
window crank handle will not come off
I recently bought an 86 k10 Silverado. I wanted to remove the door panel to push out a dent. The clip on the crank is gone but the handle will not come off. I have checked for a set screw none there. I looked for epoxy residue and don't see any. Large screw driver as a pry bar does no good. The only thing I can think to do is drill in the center and use a small puller, but I hate to ruin an original handle. Anyone have any ideas?
I also was going to clean and lube the regulator while I was in there.
Wayne
Wayne penn is offline   Reply With Quote
Old 02-20-2016, 06:20 PM   #2
tommy217xxx
tommy217xxx's Avatar
Re: window crank handle will not come off
Heat it up a little. I would use a small plumbers torch.
TJ
76 gmc 1500 swb patina finish
Dropped 4/5, 350/4 speed
80 Chevy c10 lwb
305/350
tommy217xxx is offline   Reply With Quote
Old 02-20-2016, 06:36 PM   #3
TrailerTrash
TrailerTrash's Avatar
someone may have lost the clip and super glued it on there.
you could try some brake parts cleaner it might loosen it up
TrailerTrash is offline   Reply With Quote
Old 02-20-2016, 08:32 PM   #4
Wayne penn
I thought about some heat, haven't tried it yet for fear of destroying the door panel. I may try a heat gun with cardboard taped to the panel.
wonder if the brake cleaner may soften the vinyl?
Wayne
Old 02-20-2016, 08:33 PM   #5
tommy217xxx
I blow dryer on low heat might be safer. Hold it back if need be. Actually a plumbers torch probably isn't the best tool for the job. Lol.
TJ
80 Chevy c10 lwb
305/350
Old 02-21-2016, 12:43 AM   #6
dudevato
instead of the cardboard idea what about sheet metal? And maybe some damp cloth between the metal and the door panel?
dudevato is offline   Reply With Quote
Old 02-21-2016, 02:03 PM   #7
Gregski
Gregski's Avatar
dremel it off or cut notches in it to relieve the pressure on the splines, new handle is cheap only $10 bucks at local parts house
Gregski is offline   Reply With Quote
Old 02-23-2016, 08:35 PM   #8
68Timber
I know the pieces fit
68Timber's Avatar
^^this
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-23-2016, 08:57 PM   #9
dudevato
what about a very small hole in the center of the handle, right in the middle of the splined shaft then give it a squirt of your weapon of choice
Old 02-23-2016, 09:07 PM   #10
lilpoindexter
lilpoindexter's Avatar
Drill and tap the center of the handle, put a bolt in it, and press the handle off.
lilpoindexter is offline   Reply With Quote
